Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > Marketplace > Members Classifieds > Audio/Visual, Electronics, Infotainment, NAV
Old 11-02-2021, 04:13 PM   #1
HeresMyMind
HeresMyMind's Avatar
Drives: 2013 WRB BRZ Limited
Focal 165AS component speakers & amp
SOLD!!
-B
HeresMyMind is offline   Reply With Quote
Old 11-10-2021, 09:49 PM   #2
ymshulman
Drives: '17 BRZ
So… Can you clarify what pieces in the photo are included? Also, do you know why Crutchfield says this is not compatible with the BRZ?
ymshulman is offline   Reply With Quote
Old 11-10-2021, 10:28 PM   #3
soundman98
ProCrastinationConsultant
soundman98's Avatar
crutchfield indicates that only 5-1/4"-6.5" woofers(doors) and 3/4"-1" tweeters(upper dash) fit in our vehicles. it also says there's no rear speakers in this vehicle.
so the midrange is 'not compatible', despite being fully bolt-in.
crutchfield always airs on the side of extreme caution in terms of their installation instructions, and their compatibility list will always reflect that.
this focal system is a very nicely put together system. it does take a little extra effort in terms of wiring and setup, but it's well worth it for the final result.
ymshulman (11-10-2021)
Old 11-10-2021, 10:30 PM   #4
ymshulman
Drives: '17 BRZ
So this includes the 3 way speakers in the photo, crossovers, subwoofer, amp? Or not everything in the photo?
(And these replace door speakers, and two speakers in the dash - tweeters plus midrange?)
Sorry I’m pretty new to car audio.
Old 11-10-2021, 10:32 PM   #5
ymshulman
Drives: '17 BRZ
Sorry, wrote too quickly, didn’t see that you were being helpful and weren’t the OP!
Old 11-10-2021, 10:40 PM   #6
soundman98
soundman98's Avatar
i just got to it first
yes, the 6.5" woofers would replace the door speakers, the 3.5" replace the dash midranges, and the tweeters would replace the dash tweeters.
you would need to re-wire from the radio to the crossover box(it directs the frequencies to the right speakers), and run 3 new wires per side to the respective speakers.
The Following 2 Users Say Thank You to soundman98 For This Useful Post:
alphasaur (11-10-2021), ymshulman (11-10-2021)
Old 11-10-2021, 10:42 PM   #7
ymshulman
Drives: '17 BRZ
And the factory amplifier is not enough to power them, right? (Since it just powers the door speakers?) Would need to use an aftermarket amp?
Old 11-10-2021, 11:45 PM   #8
soundman98
soundman98's Avatar
the factory amp has filtering built into that makes it only amplify low frequencies. so it's not compatible without some extreme internal circuit board modification that's much more complex than installing an aftermarket amp.
there's a thread in the car audio section where one guy started digging into what it'd take, but we all sorta lost interest in it because it's not just a simple bypass, and requires significant circuit board work..
you can power these off a factory or aftermarket radio by splicing into the speaker wires just behind the radio. but using an amplifier is what i generally prefer to get the best sound of upgraded speakers.
ymshulman (11-11-2021)
Help with Installing Component Speakers Pizzachicken Electronics | Audio | NAV | Infotainment 8 12-13-2019 09:40 PM
3 Way component speakers, amp and DDX916WS Recoil6 Electronics | Audio | NAV | Infotainment 20 03-15-2017 09:12 PM
Anyone have Focal Access 165 A3 3-Way Component Speakers? Project86 Electronics | Audio | NAV | Infotainment 1 07-24-2014 07:32 PM
Thoughts on component speakers? Griever423 Electronics | Audio | NAV | Infotainment 10 06-30-2014 08:52 PM
Lets Talk Component Speakers Skippman Electronics | Audio | NAV | Infotainment 34 01-09-2014 01:29 PM
