Old 06-30-2014, 04:48 PM   #1
Griever423
Drives: 2020 BRZ PP
Thoughts on component speakers?
Hey guys, I wanted to run a couple things by you audiophiles here on the board.
I've been dying to upgrade my stock stereo system but have been holding off for a while but I REALLY need an upgrade, at the very least a sub. Going off the fact that our factory HU does not have any preouts I decided in order to get the best sound I would need to replace the head unit and door speakers as well if I was going to upgrade. I've got the sub/box combo picked out that I want to use, now it's down to door speakers.
My question is: would it be worth it to mess with adding a midrange driver in the factory location? I know some have expressed concerns because of the shallow mounting depth and lack of airspace behind the driver would affect it's performance and SQ. The midranges I'm considering are from Addictive Audio. They're 3" midrange drivers and are marketed to be specifically for OEM location applications. They have passive crossovers wired in, and I would be using these with the Addictive Audio components.
I know everyone's ears are different and quality is subjective, but I really like how the front stage sits with the factory speakers and am wanting to keep that when I upgrade. What are y'alls thoughts on the matter?
Griever423 is offline   Reply With Quote
Old 06-30-2014, 04:52 PM   #2
mit_peid
Boosted Noob
mit_peid's Avatar
Drives: '13 FRS MT KW SC, '05 4Runner 4WD
I'm happy I upgraded the front stage with some MB quart components that set me back about $120 for a set. But I got an aftermarket pioneer and decent external amp too. If you want to keep the OEM head unit I recommend the OEM+ lineup of upgrades.
mit_peid is offline   Reply With Quote
Old 06-30-2014, 04:55 PM   #3
Griever423
Drives: 2020 BRZ PP
I will not be keeping the OEM head unit. I will be running 2 amplifiers, one 4 channel and one mono for the sub.
Those MB components, did you just replace the door woofers and the tweeters or were there 3 sets of speakers?
Old 06-30-2014, 04:59 PM   #4
mit_peid
Boosted Noob
mit_peid's Avatar
Just the 2 sets - the door speakers and a pair of tweeters. I don't think you'd get that much more midrange in the 3.5" range of speakers. I considered upgrading the rear speakers but just kept the stock speakers there being driven by the head unit - provided a decent amount of fill. I'm running a single 4 ch amp - two channels for the components and two bridged for my 10" sealed sub.
Old 06-30-2014, 05:28 PM   #5
Griever423
Drives: 2020 BRZ PP
Ya I had planned on leaving the rear alone. No one sits back there anyway and the speakers are so small and underpowered that they don't make that much difference. The midranges I'm considering buying are not expensive, but I've learned with Addictive's speakers that inexpensive with them doesn't mean cheap. $80 for the pair and a little more work running speaker wire back to the amp. That is of course if they fit in the stock location without much modification. If I have to get to messing with it or pay someone to install it would mean a lot of $$$ for what might be a small gain.
Old 06-30-2014, 05:43 PM   #6
SuperKazRacing
Drives: 2013 RED FR-S
I WENT ALL ALPINE !1!
It's AWESOME,but I also used 60ft of DYNAMAT in the car....
SuperKazRacing is offline   Reply With Quote
Old 06-30-2014, 06:02 PM   #7
Chimera
Drives: FRS
I am running kappa 62.11i and a ktp-445u + jl 10 in power wedge + pioneer Hu. I'm pretty satisfied.
Old 06-30-2014, 06:31 PM   #8
Griever423
Drives: 2020 BRZ PP
I checked out your build thread, that enclosure looks perfect for me. Which one is it? And where did you buy it?
Old 06-30-2014, 06:56 PM   #9
cnk
Drives: '13 DGM BRZ Limited
He's using a JL Audio pre-assembled enclosure with sub.
http://www.crutchfield.com/S-s2D2L32...10-JXWXv2.html
Sent from my SAMSUNG-SM-N900A using Tapatalk
cnk is offline   Reply With Quote
Old 06-30-2014, 08:39 PM   #10
mit_peid
Boosted Noob
mit_peid's Avatar
Yeah I'm using the most economical pre-assembled JL enclosure. IMO way more than enough bass for our little cars - just make sure you're giving it enough power. And dynamating will help with SQ too.
Old 06-30-2014, 08:52 PM   #11
Chimera
Drives: FRS
Yes. I have the 250w amp, and that enclosure. I currently do not have dynamat, and you can really tell if you run test tones. I run my doors with 125 hpf to reduce rattles.
Anyone have Focal Access 165 A3 3-Way Component Speakers? Project86 Electronics | Audio | NAV | Infotainment 1 07-24-2014 07:32 PM
Lets Talk Component Speakers Skippman Electronics | Audio | NAV | Infotainment 34 01-09-2014 01:29 PM
Replaced front speakers with component set - sound is worse AlexTheGreek Electronics | Audio | NAV | Infotainment 37 04-15-2013 09:58 PM
Thoughts on the BRZ radio/gps/speakers - Should we upgrade? dorkymork Electronics | Audio | NAV | Infotainment 21 01-30-2013 11:04 AM
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 02:12 PM
