Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 11-04-2021, 12:24 PM   #29
LanceLane174
Drives: 2022 BRZ Limited WRB, MT
The US models had a prosthetic donut that fit in the well. Can't really call it a "tire".
The manual says not to travel over 50 miles on it.
I think some of the AUS models had a spare tire, but that needed a lump in the middle of the well cover.
A doughnut is all I need. I am just concerned about getting a flat that the fix a flat won't fix and then having to have my car towed 70 miles back home. Not having a spare is stupid.
LanceLane174 is offline   Reply With Quote
Old 11-04-2021, 08:36 PM   #30
wheelspeed
Large Member
Drives: Ford Flex, ZX9R, FLHTCUi, DRZ400S
Originally Posted by Sport-Tech View Post
Lol at having your manual torquing checked by a shop or dealer. From what I have seen they always use uncalibrated air hammers when mounting a wheel and never a torque wrench. Probably why my front rotors got warped, overtorqued.
Yeah, after any shop messes with my wheels, I break the lugnuts loose and retighten. Haven't used a torque wrench before, but at least loosen and then make normal lug-wrench-tightness instead of their ridiculous air tools on max torque.
- Have fun!
wheelspeed is offline   Reply With Quote
Old 11-23-2021, 03:05 PM   #31
LanceLane174
Can someone with a delivered BRZ comment on how much space there is in the spare wheel well? A lot of us need to decide if we can buy a spare and put it in there.
Old 11-23-2021, 04:09 PM   #32
Grif
Grif's Avatar
Drives: BRZ 2nd gen
A full size spare will fit the same as the previous generation. It will need the floor mat with a hole in it to fit. This was based on the preview model I looked at in Australia that had the full size spare fitted.
Note: You may need to put a jumper/towel in the wheel to stop small items from falling between the wheel spokes.
Photo of the previous generation example.
https://performancedrive.com.au/wp-c...pare-wheel.jpg
Grif is offline   Reply With Quote
Old 11-23-2021, 05:34 PM   #33
MyHybridBurnsGasAndTires
Drives: what
im not sure a space saver tire would fit under the carpet and imo^ that doesn't look like a great option. i'll stick with the tire goop.
MyHybridBurnsGasAndTires is offline   Reply With Quote
Old 11-23-2021, 06:19 PM   #34
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Has anyone tried to fit a space saver tire from the 1st gen in the 2nd gen?
Visually it looks like the 2nd gen should fit it without any problems.
Old 11-23-2021, 07:38 PM   #35
LanceLane174
If anyone has the dimensions, you can buy a doughnut for our car that is 4.9 inches wide. So hopefully that wouldn't make it too tall to fit when you take the foam thing out.
Here is the link.
https://ezsparewheel.com/products/17...heel-125-80r17
Old 12-03-2021, 02:53 PM   #36
Flarpswitch
Flarpswitch's Avatar
Drives: 2022 BRZ Ltd, 2025 Ascent Touring
I can't remember the last time I had a flat tire from a road hazard. Usually I will find a screw or nail on routine inspection and have the tire repaired. Other than that, about fifty years ago I was at a Grateful Dead concert and late into the evening when we returned to my 1959 Austin 850 Mini, I found two tires flat from sidewall punctures. There must have been a hundred other cars in the same situation. Fortunately, I had two spares mounted on ten inch wheels in the boot. I was on my way in short order. It must have been about 20 degrees out and I was not dressed to be outdoors. I gave a ride to a couple of stranded drivers. Their body heat helped inside that wretched car as the heater was a one fan speed recirculating unit that only protected your feet from frostbite. My thoughts on a repair kit vs. a full or compact spare? From experience, the only way you will never need them is if you have one or the other.
Flarpswitch is offline   Reply With Quote
Old 12-03-2021, 09:35 PM   #37
22 BRZ
22 BRZ's Avatar
Drives: 2022 Subaru BRZ 6MT IR
Just pulled a 4" roofing nail out of one of my tires - luckily I was close to home, and my portable air compressor, to get me to a shop. Punctured the tire in 2 places. Car only has 800km on it. I now have a small 12V compressor in the trunk...
2022 BRZed, Red, Base, Manual, Simple
22 BRZ is offline   Reply With Quote
Old 12-03-2021, 10:15 PM   #38
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
A compressor is a good idea to have anyways. Even with a spare tire, you might find it underinflated when it's finally time to use it.
For a couple of nail issues I had, a DIY tire plug kit has been useful.
One of those issues happened during a car control clinic, when an allegedly old nail left my friend's tire due to tire flexing, so the tire was losing pressure by the minute. Put the car on my scissor jack, pumped some air, plugged the tire — the tire was fine for a few weeks after that, and then decided to just put new tires on.
A scissor jack is included with '22s, right?
I once needed a spare when renting a car in a rural area.
Admittedly it was a stupid idea to drive that fast on an unpaved "highway"
I hit a stone that was in my "lane" in a blind corner...
The impact was so severe that the inside of the wheel barrel reached the caliper (the car didn't have a BBK),
and the stone caused some cosmetic damage to the rocker panel.
That being said, having a spare tire is beneficial for the piece of mind.
Will I buy a spare tire for the '22? Maybe, but not certain.
Old 12-03-2021, 11:18 PM   #39
2020BRZtS
2020BRZtS's Avatar
Drives: '20 BRZ tS (15/300) / '09 Scion tC
I'm willing to provide a spare from my 2020 to test with in SE PA. I don't think I can use my donut anyway with 18" rims and brembos. For science.
2020BRZtS is offline   Reply With Quote
Old 12-04-2021, 12:23 AM   #40
22 BRZ
22 BRZ's Avatar
Yeah the 22 does still have a scissor jack. I had taken it out, not really seeing the use for it without a spare wheel, but I take your point there. I'll throw it back in.
The Following User Says Thank You to 22 BRZ For This Useful Post:
timurrrr (12-04-2021)
Old 12-04-2021, 05:16 PM   #41
Rossman
Rossman's Avatar
Drives: '22 BRZ, '17 BRZ (prev '13 FR-S)
Thumbs up
Absolutely, I swapped the spare from my '17 BRZ into my '22 and put the tire repair kit into the '17. No problems at all.
Rossman is offline   Reply With Quote
The Following 3 Users Say Thank You to Rossman For This Useful Post:
bholliday (02-23-2022), Flarpswitch (12-10-2021), timurrrr (12-04-2021)
Old 02-22-2022, 10:31 PM   #42
wangson
wangson's Avatar
Drives: 2023 Toyota GR86 Trueno Blue
Can you post pics for us?
wangson is offline   Reply With Quote
Performance Package spare tire vs. regular spare JeremyR Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 67 09-22-2022 09:36 PM
FS: OEM Spare Tire zeal86 Wheels and Tires 7 12-08-2016 09:37 AM
WTB: Spare Tire kanundrum Want-To-Buy Requests 2 11-15-2016 11:30 AM
Replace Only 1 Tire? / Spare Tire Question chermo12 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 07-28-2015 01:44 PM
