Old 11-02-2021, 11:24 AM   #15
GraysonGreene
GraysonGreene's Avatar
Drives: 2014 Scion FR-S
Sub'd, thank you for posting and updating us! Excited to see more.
Charlotte, NC
14 Firestorm Red FR-S
GraysonGreene is offline   Reply With Quote
Old 11-02-2021, 02:24 PM   #16
FrickingReallySlow
Drives: 2015 FR-S
Does the red and green paint on the rotors turn a different color at different temps to give you a max temp during a session?
FrickingReallySlow is offline   Reply With Quote
Old 11-02-2021, 11:28 PM   #17
CSG Mike
CSG Mike's Avatar
CSG FLA V2 prototype installed, corner balanced, and aligned.
Car now rides even smoother for most road elements, with the HBS manifesting only over (very) large dips, where it's definitely guaranteeing preventing any sort of bottoming out. Drove around on a loop identical to what I do when doing local testing for OEMs.
Will need to test balance at the track, as there's no way to do it safely on the street, but... I'm excited.
Old 11-02-2021, 11:30 PM   #18
CSG Mike
CSG Mike's Avatar
Exactly that.
430C for green to turn white
610C for pink (red) to turn white.
The CP is designed as a street pad when it comes to friction, but has the capacity to handle race temps. It pairs well with lower grip tires, but stickier tires designed for track/race use should be paired with a pad designed for that grip level, such as a C1/C2/C21, etc.
The rotors turned the green paint white while driving on stock tires. No blatent use of ABS.
Old 11-02-2021, 11:31 PM   #19
CSG Mike
CSG Mike's Avatar
Originally Posted by Lightened View Post
Wondering if your current CSG Spec Touring 86 Comp Exhaust by MXP fits?
Asking for a friend
I suspect it does. I might grab mine off my 17 to try fitting on the 22.
Old 11-02-2021, 11:32 PM   #20
CSG Mike
CSG Mike's Avatar
Originally Posted by dragoontwo View Post
Are the rear tow points the same distance apart? Asking for Slambert twin hitch compatibility.
My very imperfect/imprecise measurement with a tape measure says yes.
Old 11-02-2021, 11:33 PM   #21
CSG Mike
CSG Mike's Avatar
Originally Posted by Frost View Post
Where did you get those temperature indicator stickers and what brand/model are those?
From CSG.
I use a mix of AP, Alcon, and Omega, based on whatever is available.
Old 11-02-2021, 11:36 PM   #22
jflogerzi
jflogerzi's Avatar
You guys better send Mike a bunch of Uber Eats or Door Dash gift cards
2013 Series 10 FRS #553
Old 11-02-2021, 11:37 PM   #23
CSG Mike
CSG Mike's Avatar
Originally Posted by villainous_frx View Post
Designed with the '22 in mind, or bolt on from the 12-20 cars? Either way, super excited to see where this goes!
Probably both, actually.
Old 11-03-2021, 08:44 AM   #24
Pat
Pat's Avatar
Drives: 2023 BRZ
Old 11-03-2021, 12:49 PM   #25
DarkSunrise
DarkSunrise's Avatar
Car now rides even smoother for most road elements, with the higher spring rates manifesting only over (very) large dips. Drove around on a loop identical to what I do when doing local testing for OEMs.
Any thoughts on the aluminum knuckle? Toyota made some stink that they were sticking with the heavier iron knuckle due to steering feel but wondering if that’s just marketing nonsense.
Also is it confirmed that first gen coilovers are a direct fit on this second gen? BBKs?
2022 BRZ Build
2013 FR-S Build
Old 11-03-2021, 02:29 PM   #26
CSG Mike
CSG Mike's Avatar
Almost any coilover should be a direct fit.
BBK still TBD.
Aluminum vs Steel wheels, engine blocks, and now, knuckles. Probably little to no real real world difference. If the Aluminum knuckle was flexing like that, it's fatigue life would be very, very short.
Old 11-03-2021, 02:38 PM   #27
CSG Mike
CSG Mike's Avatar
You gave me an idea. Let's see where it goes.
Old 11-03-2021, 02:44 PM   #28
ayau
Drives: Some rust bucket
@CSG Mike any particular reason you chose the BRZ over the GR86?
nowforitbs
Mike's 2022 BRZ on SoWS, 10 hours after taking delivery. CSG Mike BRZ Second-Gen (2022+) — General Topics 25 11-04-2021 11:22 PM
Mike's 2022 BRZ on SoWS, 10 hours after taking delivery. CSG Mike Tracking / Autocross / HPDE / Drifting 5 11-02-2021 05:57 PM
Mike's CS FR-S build mikef Member's Car Journals 6 04-25-2013 09:11 AM
Mike @ LSD Motorsports JDMenrique User/Vendor/Sponsor Reviews, Feedback, Comments 0 04-06-2013 07:13 PM
Mike at Czp _F-R-S_ User/Vendor/Sponsor Reviews, Feedback, Comments 0 12-01-2012 09:01 PM
