#15 |
Drives: 2014 Scion FR-S
Sub'd, thank you for posting and updating us! Excited to see more.
Charlotte, NC
14 Firestorm Red FR-S |
#16 |
Drives: 2015 FR-S
Does the red and green paint on the rotors turn a different color at different temps to give you a max temp during a session?
#17 |
![]() ![]() ![]() ![]() CSG FLA V2 prototype installed, corner balanced, and aligned. Car now rides even smoother for most road elements, with the HBS manifesting only over (very) large dips, where it's definitely guaranteeing preventing any sort of bottoming out. Drove around on a loop identical to what I do when doing local testing for OEMs. Will need to test balance at the track, as there's no way to do it safely on the street, but... I'm excited. Last edited by CSG Mike; 11-03-2021 at 05:05 PM. |
#18 | |
430C for green to turn white 610C for pink (red) to turn white. The CP is designed as a street pad when it comes to friction, but has the capacity to handle race temps. It pairs well with lower grip tires, but stickier tires designed for track/race use should be paired with a pad designed for that grip level, such as a C1/C2/C21, etc. The rotors turned the green paint white while driving on stock tires. No blatent use of ABS. |
#19 |
#20 |
#21 |
#22 |
You guys better send Mike a bunch of Uber Eats or Door Dash gift cards
2013 Series 10 FRS #553
#23 |
#24 | |
Drives: 2023 BRZ
Director of Rocky Mountain 86CUP
#25 | |
Also is it confirmed that first gen coilovers are a direct fit on this second gen? BBKs?
2022 BRZ Build 2013 FR-S Build |
#26 | |
BBK still TBD. Aluminum vs Steel wheels, engine blocks, and now, knuckles. Probably little to no real real world difference. If the Aluminum knuckle was flexing like that, it's fatigue life would be very, very short. |
#27 |
| Tags |
| nowforitbs |
| Mike's 2022 BRZ on SoWS, 10 hours after taking delivery. | CSG Mike | BRZ Second-Gen (2022+) — General Topics | 25 | 11-04-2021 11:22 PM |
| Mike's 2022 BRZ on SoWS, 10 hours after taking delivery. | CSG Mike | Tracking / Autocross / HPDE / Drifting | 5 | 11-02-2021 05:57 PM |
| Mike's CS FR-S build | mikef | Member's Car Journals | 6 | 04-25-2013 09:11 AM |
| Mike @ LSD Motorsports | JDMenrique | User/Vendor/Sponsor Reviews, Feedback, Comments | 0 | 04-06-2013 07:13 PM |
| Mike at Czp | _F-R-S_ | User/Vendor/Sponsor Reviews, Feedback, Comments | 0 | 12-01-2012 09:01 PM |
