Old 10-31-2021, 06:01 PM   #1
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
Unhappy Bad vibration after new clutch
Help
I can't figure out why my transmission just vibrates between 3.2k-2.5k rpm after installing the new clutch. Inspected everything & they look great.....
I was so annoyed I changed a transmission.......it got better but it's still there.
Is it possible that the new flywheel is out of balance?
The Following User Says Thank You to chaoskaze For This Useful Post:
humfrz (11-01-2021)
Old 11-01-2021, 12:53 AM   #2
Originally Posted by chaoskaze View Post
Help
Please clarify.
You installed a new clutch and now the transmission vibrates? How do you figure its not the new clutch that is vibrating?
When you replaced the clutch did that include the pressure plate?
Did you replace the TOB?
So, you implied that you replaced the flywheel too. Is that so?
If you didn't replace the flywheel, did you at least have the flywheel resurfaced?
Come back.
chaoskaze (11-03-2021)
Old 11-01-2021, 01:26 AM   #3
Please clarify.
Engine and transmission vibrate as a single unit. Yes, it's possible that the flywheel is out of balance. Either way, still need to pull it all apart again.
chaoskaze (11-03-2021), humfrz (11-01-2021)
Old 11-01-2021, 02:29 AM   #4
Old 11-01-2021, 03:02 AM   #5
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Stock flywheel or lightweight flywheel? I had a similar issue, but it was related with the lw flywheel. Went back to a complete stock flywheel and clutch-kit and now I don't have any vibrations at all.
The Following User Says Thank You to nikitopo For This Useful Post:
Old 11-01-2021, 12:08 PM   #6
Iffen you don't take it apart on purpose sooner, it'll take itself apart later.
chaoskaze (11-03-2021), humfrz (11-07-2021), soundman98 (11-01-2021)
Old 11-06-2021, 01:39 PM   #7
Rabrooks
Rabrooks's Avatar
Drives: 2020 Subaru BRZ
is it possible you got the crank sensor wheel on backwards or correct but not fully tight
Rabrooks is offline   Reply With Quote
Old 11-06-2021, 02:41 PM   #8
It wouldn't start if backward. Not tight? That's a disturbing thought. Yikes!
Old 11-15-2021, 09:10 PM   #9
Turdinator
Señor Member
Turdinator's Avatar
Help
Does it do it with the clutch pressed in or the car in neutral or only when driving?
1974 TA22 Celica
2013 86 GT
Old 12-25-2021, 03:09 AM   #10
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
Unhappy
Merry Xmas, It only does it when it's in gear in between 3.1k to 2.5k especially as the rpm drop naturally.
I drove like 200 miles since I posted, my friend drove it & said it's not much...
I don't know if I'm just used to it now or I have habits to not drive in the rpm it vibrates now. I'm starting to think it's more like a resonance instead of vibration.
Old 01-20-2022, 10:41 AM   #11
Originally Posted by fekog45261 View Post
In my opinion, this is only the fault of a poorly pressed clutch ...
OK Bot/Spammer.
x808drifter (01-20-2022)
Old 01-20-2023, 05:55 AM   #12
Viver
Drives: BMW e46
Originally Posted by RoarDonald View Post
https://vodsfera.pl/diuna/
This is a pain for my ears. Unfortunately, our vehicles have various problems. It's like being revealed with a human being with time.
mee too bruh, me too... I recently bought a car and had to replace most things in it
Viver is offline   Reply With Quote
Old 01-20-2023, 06:28 AM   #13
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
Reported last years hidden spam link.
The Following 3 Users Say Thank You to dragoontwo For This Useful Post:
sato (09-23-2023), Ultramaroon (01-20-2023), x808drifter (01-20-2023)
Old 01-21-2023, 10:01 AM   #14
dragoontwo
dragoontwo's Avatar
This thread brings all the reported spam to the yard.
The Following 2 Users Say Thank You to dragoontwo For This Useful Post:
Ultramaroon (01-21-2023), x808drifter (01-22-2023)
Driveline vibration at low RPM after clutch swap johunn Engine, Exhaust, Transmission 5 10-31-2021 06:11 PM
Vibration after Clutch Replacment AT-JeffT Engine, Exhaust, Transmission 12 03-10-2020 08:09 PM
1-2 second clutch vibration while incriminati Issues | Warranty | Recalls / TSB 9 12-28-2019 05:12 PM
BRZ Funny vibration on clutch pedal jason_srdet Issues | Warranty | Recalls / TSB 2 08-08-2014 08:45 PM
Vibration/Noise when clutch is depressed Ravenlokk Issues | Warranty | Recalls / TSB 17 12-02-2013 10:15 AM
