Old 09-14-2021, 10:23 AM   #85
Sasquachulator
Pavement Grey
Originally Posted by Spektyr View Post
Those are good points - I was looking at it from the perspective that I expect not to buy more summer tires once the PS3's wear down. And I can always change my mind and add wheels to whatever tires aren't currently mounted if I decide later that I want easier access to both sets.
Question for you - do you run the TPMS on both sets of wheels or just the factory wheels, and if so how does the car handle that?
Im not sure what tpms system the 86 uses, but in my Scion iM, i had the OEM wheels with the TPMS sensors, and the winters without any sensors.
I just lived with having that tire pressure light on all winter.
I imagine the 86 would act the same. You'd just have the TPMS light on all the time.
I probably doing the same thing this time around, the sensors are expensive.....
I dont think its a huge deal because the light only tells you that one of the tires has different pressure, and its not a system where it tells you what each individual tire pressure is.
The Following User Says Thank You to Sasquachulator For This Useful Post:
Dzmitry (09-14-2021)
Old 09-14-2021, 11:55 AM   #86
Dzmitry
Dzmitry's Avatar
Drives: 2018 Subaru BRZ Limited with PP
So currently, I have not purchased the new wheels yet, as I mentioned I look forward to doing this next year and putting summer tires on them. At this point, the warm weather will be fading, so there is no need for me to rush the purchase now.
As for the TPMS sensors, though I am a perfectionist, I actually don't have any in my current aftermarket wheels. So the light is always on. I have found found myself completely forget about it at this point after owning the wheels for about a couple years now. So based on that idea, I may not bother with them in the new wheels either. But if I was going to do it, I would just get them on both sets and let it be over with. No point in having TPMS on one set and not the other the way I see it.
Dzmitry is offline   Reply With Quote
Old 09-14-2021, 01:01 PM   #87
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
I'm going to guess that the GR86 will register 2 sets of TPMS like the new BRZ does, so having them in each set makes sense. We will also get tire pressures as well this time.
The Following 2 Users Say Thank You to dragoontwo For This Useful Post:
Spektyr (09-15-2021), Yoshoobaroo (09-14-2021)
Old 10-27-2021, 09:24 PM   #88
Jianlun
Drives: GR86 RC
No sure where to post this. But I was wondering whether the stock gr86 brz has pos or neg scrub radius. Maybe I reading too much into a marketing photo. But it does look slightly positive.
I am interested cos I wanna put my et42 tc105n onto the gr86 brz but dun want to f up the scrub radius ie steering feel and kickback (which I like hahah). worst is if it is slightly neg and the et42 offset ie 6mm more poke causes the scrub radius to become zero.
Jianlun is offline   Reply With Quote
Old 10-31-2021, 05:35 PM   #89
FrickingReallySlow
Drives: 2015 FR-S
So looking at all the press release it seems GR86 still gets 7inch wheel width instead of the 7.5 that the 2022 BRZ has in all trims. Is this an error or confirmed?
FrickingReallySlow is offline   Reply With Quote
Old 10-31-2021, 08:24 PM   #90
teppey
teppey's Avatar
Drives: BRZ (in near future)
They should come in 7.5"
teppey is offline   Reply With Quote
GR86 In R7 of the Toyota Gazoo Racing GT Cup + GR86 coming to Grand Turismo Sport Blighty GR86 General Topics (2nd Gen 2022+ Toyota 86) 28 07-18-2021 03:38 PM
Replace Only 1 Tire? / Spare Tire Question chermo12 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 07-28-2015 01:44 PM
best tire pressure gauge (tire pressure question) steveholt Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 19 03-21-2015 10:27 PM
Tire question poptopclk Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 14 05-07-2014 10:24 AM
tire question bkblitzed Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 07-16-2013 03:35 AM
