Old 10-25-2021, 10:36 AM   #1
steverife
Drives: 2016 Scion FRS
SCCA Solo November Fastrack - Heavy Twin content
https://cdn.connectsites.net/user_fi...pdf?1634845995
2022 GR86 and BRZ to STX got TYFYI'd. Existing cars safe. For now.
2013-16 cars full prep move from CSP to DSP out for member comment. Comments to www.soloeventsboard.com.
steverife is offline   Reply With Quote
The Following 3 Users Say Thank You to steverife For This Useful Post:
nathand (10-25-2021), RT-BRZ (10-25-2021), strat61caster (10-25-2021)
Old 10-26-2021, 07:17 PM   #2
Locust
Custom User Title
Locust's Avatar
Drives: 2015 Scion FR-S, 2012 OB Evo X MR
Send a message via AIM to Locust
At some point new cars need to be ST classed. I can understand not classing immediately but look at the Toyota Supra. Does it have an ST class yet? No. And it's been out for almost 3 years now. This classing philosophy is hurting the club and hurting membership. It's hard to get new members when half the classes are stuck in the 90s.
LOCUST
2015 FR-S (STX) and 2012 Evo X MR
Instagram:
LocustAutoX
Sponsors:
DSGPerformance Drift Office Evil Apex Racing
Locust is offline   Reply With Quote
Old 10-27-2021, 09:15 AM   #3
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Yes, it has a proposed ST class. It was too fast for STU so they made a new class. They recognized the issue and are fixing it.
The ACs and SEB are doing a good job, if you want to bitch about stuff, go bitch about national office.
Old 10-27-2021, 02:55 PM   #4
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Yeah I agree that the supra looks a bit too quick for STU, most of those cars are ~300whp and around 3,100 lbs rwd or 3400 lbs awd while the Supra in ST trim should be nearing 400whp at 3,100 lbs. I think it looks faster on paper then the real world would turn out to be, there's only so much power that's useful in autocross on 200tw tires but it's a dimensionally smaller car then the 86 and coilovers and alignment should significantly up it's game from BS trim.
As above there's a proposal kicking around to make a faster ST class or put faster cars into STU, I don't recall where the preference is because I can't afford it either way and haven't been paying attention lol.
The Supra and other cars of similar capability are also not made in huge numbers, one thing I do appreciate about the SCCA is that they try to not make a car with only a few thousand on the road as the car to have. There are less then 10k supras in the us right now most with a fairly hefty price tag when you can get into a built Stu car for under $30k if you're savvy.
Edit: 4 banger Supra might be a good fit for Stu
ineedyourdiddly
Old 10-27-2021, 03:09 PM   #5
CSG Mike
CSG Mike's Avatar
The Supra is quite wide, which is a huge detriment in AutoX.
timurrrr (11-05-2021)
Old 10-27-2021, 03:49 PM   #6
strat61caster
3" wider and a 4" shorter wheelbase then an FR-S.
Width impacts are course dependent whether there are more slaloms or offsets/sweepers.
ineedyourdiddly
Old 10-27-2021, 03:59 PM   #7
CSG Mike
CSG Mike's Avatar
I mean, if I were choosing and building a car to be competitive, it would be a ND Miata....
Old 10-27-2021, 06:36 PM   #8
steverife
Thing about the Supra is that David Marcus has went out and won everything but nats in that car the last couple years and I still can just about count the number of Supras that I've seen at an autocross with one hand.
The Following User Says Thank You to steverife For This Useful Post:
RT-BRZ (10-27-2021)
Old 10-27-2021, 07:59 PM   #9
RT-BRZ
RT-BRZ's Avatar
Drives: 2013 Subaru BRZ
This for sure. Maybe in California they are running a lot of the Supras but I've only ever seen two in our region and the surrounding ones.
RT-BRZ is offline   Reply With Quote
Old 10-27-2021, 08:31 PM   #10
strat61caster
Not really, nobody committed showing up in NorCal, can also count on one hand the supras I've seen at an autocross.
ineedyourdiddly
Old 10-27-2021, 09:18 PM   #11
RT-BRZ
RT-BRZ's Avatar
Then that makes me a little sad. I actually like the Supra but it's just too expensive for me at this point in life. I've been impressed with the ones I've seen but I just don't see many.
The Following User Says Thank You to RT-BRZ For This Useful Post:
strat61caster (10-27-2021)
Old 10-27-2021, 11:28 PM   #12
Locust
Custom User Title
Locust's Avatar
Proposed classing going into 3rd year of the car being out doesn't mean it's classed *yet*. I didn't say the committees aren't doing the best they can so please don't put words into my mouth. I am of the opinion that autocross classing with SCCA needs a complete rework from the ground up. The "Fun With Cars" mantra only goes so far as "Fun With Certain Cars". It completely takes the fun out of picking a car you want to drive and showing up to race with it.
I spent years as a recruiting chief trying to bring new people into this sport and the SCCA. It's difficult to tell someone their new model car doesn't have a class yet so they have to run time only or jump into something ridiculous like XP.
It's less popular than many other cars but there is also a loose relationship between favorable/available classing of a car and the number of people who will drive that car at an SCCA autocross.
LOCUST
Instagram:
LocustAutoX
Sponsors:
The Following User Says Thank You to Locust For This Useful Post:
RT-BRZ (10-28-2021)
Old 11-02-2021, 10:16 PM   #13
cmiovino
cmiovino's Avatar
Drives: 2017 BRZ PP, 2004 WRX
I haven't seen any Supras at any events here in PA in three different regions. I'd say likely too expensive, but at one point we had 8+ CTRs showing up in DS.
Glad to see STX is safe for now. I think the twin is going to be putting down some crazy fast times once modified to ST trim, likely on par with STR. Problem is, it's not a roadster, so it doesn't technically fit there by name.
STU doesn't seem to fit either, but that would be the other option. Again, just happy it's not in STX... yet.
I have a 2017 with the PP and eventually want to go to STX and be competitive. DS is difficult with tons of CTRs and national champs in them... and many of them are ditching them this upcoming year already. They can't seem to stay in a car more than a year or two.
cmiovino is offline   Reply With Quote
Old 11-02-2021, 10:22 PM   #14
strat61caster
There are coupes in str.
ineedyourdiddly
The Following 2 Users Say Thank You to strat61caster For This Useful Post:
DocWalt (11-03-2021), RT-BRZ (11-03-2021)
November Fastrack BRZZZZZZZZZZ Tracking / Autocross / HPDE / Drifting 19 10-27-2014 02:29 PM
2014 SCCA Solo Nationals/Pro Solo Finale thread edj Tracking / Autocross / HPDE / Drifting 206 09-19-2014 11:34 AM
SCCA SOLO August Fastrack. Scooby South Tracking / Autocross / HPDE / Drifting 12 07-22-2013 05:03 PM
Solo content: should STX Twin be setup like S2k, RX-8, MX-5? GTB/ZR-1 Tracking / Autocross / HPDE / Drifting 18 03-05-2013 04:38 PM
November Fastrack xwd Tracking / Autocross / HPDE / Drifting 2 10-23-2012 06:26 PM
