#211 |
2.1L 3SGTE
Drives: MR2 Turbo & Tacoma
1991 MR2 Turbo - 2.1L high compression stroker 3SGTE
2006 Tacoma 4x4 TRD Off Road - All-Pro front bumper, Old Man Emu shocks, Old Man Emu HD front coils, All-Pro leafs 1990 240SX Coupe - sold 2008 Civic Si Sedan |
#212 |
Drives: N/A
Here that would qualify as funny...
Personally, I do believe that N/A the FT-86 would be far more exciting than anything else I've driven in my short driving life. |
#213 |
Drives: 08 Tacoma TRD OFFROAD
I hope this car sounds good
#214 |
http://www.toyota-europe.com/innovat..._ii/index.aspx
sounds on the right side....I hope the production sounds like that. PERSONALLY I think that sounds amazing. And just out of curiosity, assuming the engine is 200hp how much torque(lb-ft) do you think this engine is MOST-LIKELY to have. Also how well do these engine respond to boost? I'm only looking to get maybe 270hp(assuming the 2700lb weight expectancy) |
#215 | |
Kuruma Otaku
175ish lb-ft if it's a 2.5L. Educated guesses on my part.
Because titanium. |
#216 |
Drives: TSX
oh that engine sound...
#217 |
Rocket Surgeon
Drives: PSM GGA OMG
It's impossible to say at the moment. The FB engine is all new, and the only version of it out in the wild right now is a low-spec n/a motor in the 2011 Subaru Forester. No one's gotten to play with a turbo'd version yet. But back in the olden days (before it was cheaper to just buy a used WRX or Sti) people were getting 200 awhp reliably (~270bhp, up from 175) from the stock 2.5RS motor. A few folks were running 15+ psi and making 300+ awhp on bone stock engines. So nothing is certain, but 270 bhp shouldn't be too much of an issue.
#218 | |
Is a Monster
Drives: AE86, MA70
If it peaks at 6800rpm: ~154 ft/lbs of torque If it peaks at 7500rpm: ~140 ft/lbs of torque |
#219 |
i dont really understand the boxer motor. i have yet to see any of the advantages the motor provides pay a significant dividends. the evos have tall i4s and i fail to see anything subaru have an advantage. it also makes things complicated with plumbing and having two cylinder heads. vettes seem low slung enough and they fit a 6l v8 under there...
#220 |
2.1L 3SGTE
however, the subarus you're referring to have the engines WAY farther forward than the evos. the ft86 will have the engine very very low, and very far back.
toyota understands how critical it is to get the CG low and centralized.
#221 | ||
Drives: N/A
V config engines are popular because they are compact especially for RWD chassis layouts. The V4 has become extinct/rare, the last V4 that I know of was the Ford Essex and that was almost 15 maybe 20 years ago now. So it only makes sense that instead of a standard straight 4 or making a V4 from scratch that Toyota used a flat 4 from Subaru to fit in such a compact layout. For a car as small as the FT-86, it makes a big difference. Compare 4 banger cars like the Miata, the Silvias, etc to a regular transverse econobox and the longitude engine takes a lot of extra sheet metal to surround those engines. At least that is how I understood their reasoning. |
#222 | |
Rocket Surgeon
Drives: PSM GGA OMG
It's lightweight: Expect an FB20 to weight less than 260 lb (without exhaust or accessories). It's short (height-wise): That sleek low hood and pointy nose are only possible because of the flat four. Because of stupid pedestrians in Europe, if the car had an inline or V engine the hood would be bulbous like the 370z. Minor bonus: There's no harmonic balancer, so lightweight aftermarket crank pulleys are perfectly fine for the motor. |
#223 |
Drives: 1964 Chevy Cheetah
150 ft/lbs is weak sauce. Definitely will not be buying if its that little. Rather buy the Focus ST at that point.
#224 |
Rocket Surgeon
Drives: PSM GGA OMG
It's an N/A 2 liter. Honestly, what were you expecting?
So I decided to be a little bit scientific about this torque business. As far as I know there are only two previous examples of Yamaha+D4s, the 2UR-GSE and the 2GR-FSE. The 2UR makes 373 ftlb from 5L (BMEP=184.4psi) and the the 2GR makes 278 ftlb from 3.5L (BMEP=196.4psi). If we assume that the FB will end up in the same range of BMEP, we're looking at 150-160 ftlbs. |
| engine swap thread | aspera | Engine Swaps | 231 | 03-15-2011 05:10 PM |
| Any issues with Subaru engine? | CyberFormula | Engine, Exhaust, Transmission | 10 | 06-26-2010 05:02 PM |
| Subie rear-engine student-rendering | Axel | Other Vehicles & General Automotive Discussions | 5 | 12-31-2009 09:12 AM |
| Accurate Engine Impressions | S2KtoFT86 | Other Vehicles & General Automotive Discussions | 1 | 12-16-2009 12:05 PM |
