Old 10-18-2021, 11:39 PM   #1
Darknd666
Drives: 2017 86
Torque damper
I came across a torque damper from a website that sells japanese parts. Looks like a torque damper however, i have not a clue as to where in gods green earth it bolts to. The part makes no sense as these engines dont really move in the same way that others do and its low center of gravity only helps that matter. Im just curious is all. Ive ordered whiteline trans insert and differential bushing inserts to get rid of some of the drivetrain slop. Id be willing to review this so called damper to satiate others interests as well and be a guinea pig. Here is the link:
https://www.rhdjapan.com/silk-road-s...e-zn6-zc6.html
Note that some of the photos look like generics of dampers for other jdm vehicles they make them for, but this is labeled specifically for the ZN6 platform aka the gist of this entire forum.
Im sure there are better parts that are commonly used to achieve a mild reduction in drivetrain slop. Hence why i went with the inserts first but those are for the rear end of the vehicle im almost positive this attaches to the engine and the chassis somewhere but with turbo goin on under the hood theres not a lot of real estate pending the kit we go with.
Darknd666 is offline   Reply With Quote
The Following User Says Thank You to Darknd666 For This Useful Post:
kevaughan (03-09-2024)
Old 10-19-2021, 12:57 AM   #2
gpvecchi
gpvecchi's Avatar
http://silkroad-jp.com/application/f.../etdmn.zn6.pdf
Enjoy!
The Following User Says Thank You to gpvecchi For This Useful Post:
Old 10-19-2021, 01:44 AM   #3
This might help.
https://www.thedailystar.net/shift/s...act-or-fiction
Bubba rule of thumb is that if you don't know what it does or where it goes - ya don't need it -
The Following 3 Users Say Thank You to humfrz For This Useful Post:
JD001 (10-19-2021), kevaughan (03-09-2024), soundman98 (10-19-2021)
Old 10-19-2021, 08:59 AM   #4
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
I'd like to see a video of an engine during a hot lap. How much does it actually move?
Old 10-19-2021, 09:02 AM   #5
Ohio Enthusiast
Drives: 2018 BRZ
Do note that this appears to also brace the brake cylinder, which requires a mirrored part between right-hand drive and left-hand drive cars. It's not clear from the instructions @gpvecchi posted whether or not that's some additional bracing this kit does or if it's needed to get it to work at all, but I'd be cautious with fitting this on a LHD car.
The Following 2 Users Say Thank You to Ohio Enthusiast For This Useful Post:
kevaughan (03-09-2024), NLSP (10-19-2021)
Old 10-19-2021, 06:48 PM   #6
Turdinator
Señor Member
Turdinator's Avatar
Our motor moves around a surprising amount from cornering loads as well as torque on the stock mounts. I don't thing there is any problem with that though. Unless it causes something to rub etc
1974 TA22 Celica
2013 86 GT
Old 10-19-2021, 06:57 PM   #7
NLSP
NLSP's Avatar
Drives: 2014 Ultramarine FR-S
To reduce engine movement, probably better off with something proven like the TRD or STI engine mounts for a mild upgrade, or the Cusco engine mounts for a more hardcore upgrade.
And as @Ohio Enthusiast mentioned, fitting a part intended for a RHD car onto our LHD cars may not work anyway since the engine bays are mirrored.
The Following User Says Thank You to NLSP For This Useful Post:
Old 10-20-2021, 11:42 AM   #8
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
If you want those I also have some fuses to sell you.
Old 10-21-2021, 03:55 PM   #9
Darknd666
Drives: 2017 86
There still isnt anything in the way though the brake booster is on the other side if its mirrored, the engine and chassis are in the same place, right?
Old 10-21-2021, 07:58 PM   #10
Darknd666
Drives: 2017 86
My goal is to keep my air filter from rubbing, but all these changes may reduce driveline slop and gain a lil torque in the process. I dont want completely solid just stiffer. Plus my 3 inch overpipe rattles on the frame a little.
Old 10-21-2021, 08:03 PM   #11
Darknd666
Drives: 2017 86
This might help.
Thank you for that insight, i will go the mainstream route and just upgrade mounts slighty piece by piece until i achieve desireable decreased engine and drivetrain slop and still have a comfortable ride with mild NVH increase.
humfrz (10-22-2021)
Engine torque damper ? Simon99 Scion FR-S / Toyota 86 GT86 General Forum 41 03-05-2023 10:23 AM
Calculate torque when using a crows foot on torque wrench BirdTRD DIY (Do-It-Yourself) Guides 0 10-11-2015 04:02 PM
FRS VS BRZ Damper (strut) kilohercas FR-S / BRZ vs.... 1 09-24-2015 03:19 AM
Requested torque and Calculated torque nickw14 Software Tuning 3 06-13-2015 04:09 AM
