Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 10-07-2021, 09:03 PM   #29
Jegan_V
Drives: 2023 Subaru BRZ
Originally Posted by Lelandjt View Post
Wouldn't a high performance all-season tire be the ideal tire in cool, rainy conditions? So it's not useless, just not good in hot/dry or cold/snowy. If you live in a place that rarely has those conditions but is often mild temperatures and wet are there rain specific tires that are better? When I had my STi in the high mountains of Colorado my summer tires were the highest performance all-seasons I could find because that car rarely saw temps above 75°, frequently saw 32-55°, and saw about as much wet pavement as dry. For winter I had a set of snow tires on other wheels.
If you don't have to deal with freezing rain, then you won't be seeing the worst problems of using all seasons. My issue with all seasons is when you frequently have temps going below and above 32F. They're already less effective when that cold vs. winters and now you're telling them to deal with ice. You need every advantage possible when dealing with ice, heck even winter tires are not perfect during that but at least you equipped your tires as best as you could to give yourself as much braking and traction possible.
You absolutely can get through a nasty winter on all seasons, I've done it several years, but those weren't my own vehicles. The thing is I've also experienced the limits of all seasons and that's why I never recommend them for 4 season use in a place where freezing winters is a thing. I however choose safety over convenience with a compromise when it comes to tires which means 2 sets of tires. Want a winter tire that's for every season? Go with an all weather one, they're fantastic but expensive.
As for the michelin crossclimate2 just posted, that's an all weather tire and that I have no qualms about that for safety.
Jegan_V is offline   Reply With Quote
Old 10-08-2021, 12:58 PM   #30
Lelandjt
Drives: '04 STi, '12 Mazda 3 Hatch
So are we all in agreement that all-season tires are actually cool weather and rain tires? Are there summer tires that are better in rain or 35-65° temps than something like Pilot Sport 4S?
Lelandjt is offline   Reply With Quote
Old 10-11-2021, 10:04 PM   #31
bobka7914
Drives: ‘22 BRZ, ‘18 Crosstrek
I ended up by purchasing Continental ExtremeContact DWS 06+, set of 4 $565.79 at Mavis tire Quakertown Pennsylvania. When the Limited comes in early next year, the dealership will road force balance and mount the Conti tires, taking off the Michelin summer tires.
I am considering purchasing a set of 4 wheels through TireRack for the summer tires. My research indicates 18 x 7.5 for a Limited automatic. However TireRack does not have that size available. Can you help me out with some suggestions or alternatives?
Thanks!
bobka7914 is offline   Reply With Quote
Old 10-11-2021, 11:05 PM   #32
LanceLane174
Drives: 2022 BRZ Limited WRB, MT
Thanks!
You can get 18 by 8 with no issues. But if I were you I would keep the summer tires on the oem rims and put the DWS on the new ones. Then I would tires that are a little wider for that wider wheel which is better in the snow.
LanceLane174 is offline   Reply With Quote
The Following User Says Thank You to LanceLane174 For This Useful Post:
bobka7914 (10-12-2021)
Old 10-12-2021, 01:46 AM   #33
Midnightsky
Midnightsky's Avatar
Drives: 2022 BRZ WRB
Explain why that is better in the snow? My experience has been(fwd at least) that slightly skinner tires cut thru the snow better. Does that change with rwd?
Midnightsky is offline   Reply With Quote
Old 10-12-2021, 02:50 PM   #34
LanceLane174
I think I got it backwards on thicker tires being better in the snow. What I meant was that if you are insisting on staying with tire rack and getting 8 inch wide wheels then I would not put the oem tires on them. Some here will tell you that isn't too much stretch, but if that is how they wanted the car to handle then they would have put these tires on 8 inch wide wheels.
If you find 7.5 inch wheels then it doesn't matter. But if you look at 8 inch wheels they tell you that the perfect size on that wheel is a tiny bit wider than our oem tires. But our oem tires are still within spec to go on an 8 inch wheel.
I went back and forth with all of this for the past 2 months. And now I am just putting All Seasons on and selling the summer tires that come with the car.
If I drive it for a few months and just have to have the summer tires then I will find 7.5 inch wheels so that it has the same feel that Subaru intended. But that's just me. I have driven 2 of the first generation cars and fell in love with how they handled so I don't want to mess with that too much.
Old 10-12-2021, 03:13 PM   #35
saluki89
Drives: 2020 Outback XT, 2022 BRZ
Does anyone know what Subaru will charge for their 18” wheels that are standard on the Limited? Just curious.
saluki89 is offline   Reply With Quote
Old 10-12-2021, 05:47 PM   #36
azndavepgh
Drives: 2022 BRZ
MSRP is $398.40 each. You're better off buying them used or going aftermarket.
https://parts.subaru.com/p/Subaru__B...8111CC050.html
azndavepgh is offline   Reply With Quote
Old 10-12-2021, 06:05 PM   #37
soundman98
ProCrastinationConsultant
soundman98's Avatar
2 differing theories.
first theory is that narrower is best to cut through the snow to the hard surface beneath for maximum traction.
2nd theory is that wider is best for maximum floatation on the top of the snow.
the main difference i've noticed it in is slushy roads, narrower is definitively better, as the slush just jams up the tread, and slips unless you get to and grip the road surface beneath it. but for area's that remain cold enough that they sand the roads instead of salt them, and it just becomes a hardpack instead of a mixture of ice/slush, i've always felt that wider is better to increase the overall contact patch.
Midnightsky (10-12-2021)
Old 10-12-2021, 06:14 PM   #38
Midnightsky
Mine might be for sale as I want 16's anyway.
Old 10-13-2021, 06:57 PM   #39
wheelspeed
Large Member
Drives: Ford Flex, ZX9R, FLHTCUi, DRZ400S
I'd prefer skinny tires for snow around Pittsburgh where they salt. These cars will only be driven in a few inches at most, and better to cut through that to the street or hardpack snow below. 4x4 offroad guys like wide tires for mud for floatation so they don't sink up to their axles in a mud bog, but I doubt anyone will be driving a brz through 4 inches of unplowed snow.
Maybe it depends where you are. I visited Edmonton, Canada one week in January and it was -40 one morning and the snow was almost sticky it was so cold! (Fun fact, -40 is the same in F or C.) And it seemed they just used sand up there. Maybe wide snow tires are okay up there.
- Have fun!
wheelspeed is offline   Reply With Quote
The Following User Says Thank You to wheelspeed For This Useful Post:
soundman98 (10-13-2021)
Old 10-13-2021, 07:06 PM   #40
Lantanafrs2
Drives: 2013 frs red
I can tell you that the low cost all seasons you get at shithouses like tire kingdom suck. Mine make noise and are wearing quickly despite reasonably mature driving and a spot on alignment
Lantanafrs2 is offline   Reply With Quote
Old 10-13-2021, 07:59 PM   #41
azndavepgh
Drives: 2022 BRZ
This video is pretty good:
Old 10-13-2021, 09:13 PM   #42
PhatFreshPrince
PhatFreshPrince's Avatar
Drives: 2022 BRZ Limited SBP
Okay, I watched the video. It really made me appreciate living in the south. If I want to splurge, I can get summer tires that are really sticky and run them until they are bald. Or get the tires with the longest warranty that does not break the bank. I could not imagine having two sets of tires.
PhatFreshPrince is offline   Reply With Quote
How bad are all season tires? Johnny Horsepower Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 83 07-07-2021 02:15 PM
2013 frs/brz OEM wheels & all season tires & winter tires fuhuan26 Wheels and Tires 1 09-30-2019 12:27 PM
All season tires matthewl Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 105 01-23-2014 09:46 AM
All-Season Tires? Little_Red_FR-S Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 41 12-15-2013 11:19 AM
All Season Tires? DTM Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 32 01-15-2013 02:19 PM
