Old 10-02-2021, 12:56 PM   #1
marineguy_88
Drives: 2013 brz
No VVT values in ecutek. VVT not engaging
I had a rebuild done and got a fresh tune. When i start and drive the car the VVT never engages. I also have no values regarding vvt, OCV etc except i do get some values in the VVT exhaust and retard angle. every other VVT related value shows n/a. Im trying to figure out what the problem is. Ive tried reflashing, driving with engine braking etc but to no avail. Ive heard the recommendation of a new ECU but am looking for other solutions as well. Any help would be appreciated
marineguy_88 is offline   Reply With Quote
Old 10-02-2021, 02:19 PM   #2
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
After my experience with this, I would take the intake cam gears off and see if either of the spring loaded oil pressure regulator doors have come loose. I was chasing this for a while on mine. Upon my rebuild, I discovered that one of my intake cams had come apart internally. The small door is pinched in place and shouldn't be loose- if it comes loose, you cannot repair it, and it will not hold the spring or oil pressure the way it is supposed to. This causes VVT issues.
Old 10-02-2021, 11:52 PM   #3
That plate is only to hold the parts together before it's mounted to the camshaft. That's it. If it falls apart on disassembly, no biggie. Put it back together and peen the edges a touch.
vvt
Reverse Lockout not Engaging Gray Fox Issues | Warranty | Recalls / TSB 16 01-30-2022 03:35 PM
Clutch Squeal When Engaging MotoX16 Engine, Exhaust, Transmission 1 09-26-2019 08:40 PM
AIT relocation - Bias resistor values - HKS SC - ECUTEK Trap63 Forced Induction 5 04-02-2019 07:14 AM
Omni 3bar map sensor values for ecutek Agent_D Software Tuning 9 07-17-2017 09:32 PM
Thud when engaging 1st anyone else? earthsscum Engine, Exhaust, Transmission 47 06-13-2012 07:26 PM
