#80865 |
ProCrastinationConsultant
i'm trying to remember what that was about...
all i know is i'm not topping $100 in parts. if this replacement carb doesn't fix the issue, i'm throwing a new motor at it. that puts my overall cost at around $270, which is just about half the cost of a new one.
#80866 |
Drives: 2017 BRZ
Just buy a new one, swap the motor, then return it. "Doesn't want to run, decided to go a different direction."
#80867 |
sometimes the point is the journey, not the destination
| The Following 4 Users Say Thank You to soundman98 For This Useful Post: |
#80868 | |
The Dictater
Drives: '13 Red Scion FRS
https://www.ft86club.com/forums/showthread.php?t=142845 Tldr:. Misfiring caused by a damaged coil pack that I missed on first look, thinking it was a fuel problem for a while. |
| The Following 2 Users Say Thank You to Spuds For This Useful Post: | soundman98 (09-29-2021), Ultramaroon (09-29-2021) |
#80869 |
Famous Potatoes
Drives: '15 ultramarine
Finally bought a new battery at Costco today. Maybe I'll put it in tomorrow.
| The Following 2 Users Say Thank You to Sapphireho For This Useful Post: | humfrz (09-29-2021), Ultramaroon (09-29-2021) |
#80870 | |
| The Following 4 Users Say Thank You to humfrz For This Useful Post: |
#80871 | |
#80872 |
Famous Potatoes
Yea. Looks just like a Costco anywhere else.
Your photo makes me almost miss the old days when the corner parts store was a happening place. Hell, you went there every 3000 miles for points, condensor, rotor, cap, plugs, fuel filter, oil filter, air filter and oil. That was if everything was going well. Good times. |
| The Following 3 Users Say Thank You to Sapphireho For This Useful Post: |
#80874 | ||
He's currently losing his puppy teeth and fortunately I've found a few and decided to keep them (I don't know if that makes me weird or not ). But that means he's also teething, so that's been interesting.
Instagram: @spike.grc
| The Following 4 Users Say Thank You to spike021 For This Useful Post: |
#80875 | |
In addition, the store/shop where I used to go as a kid, also had a small machine shop in the back, that would grind valves and mill heads. Also, they were a source of information. For example, they introduced me to the plastic wire/tape to gauge how to shim piston rod bearings and to a miracle device to compress piston rings, so as to get the pistons back into the cylinders - |
| The Following 2 Users Say Thank You to humfrz For This Useful Post: | soundman98 (09-29-2021), Ultramaroon (09-29-2021) |
#80876 | |
| The Following User Says Thank You to humfrz For This Useful Post: | spike021 (09-29-2021) |
#80877 | |
Fortunately *knock on wood* he's been pretty great with not destroying anything.
The most he's done was nibble a corner of my coffee table the first or second week I had him, and then about a month or two ago he nibbled part of a baseboard. I try to leave out plenty of toys with different textures and supervise a lot. It makes my floor a bit messier than I prefer but I figure for right now it's not a terrible idea because then he's hopefully more interested in chewing that stuff since it's easily available. He's pretty well-trained (for now, anyway) not to nibble on things he shouldn't.
| The Following User Says Thank You to spike021 For This Useful Post: | humfrz (09-29-2021) |
#80878 | |
| Language Rant Part Deux | MuseChaser | Off-Topic Lounge [WARNING: NO POLITICS] | 43 | 04-23-2017 07:55 PM |
| Random thoughts thread | MrVito | Off-Topic Lounge [WARNING: NO POLITICS] | 37188 | 02-25-2016 10:00 AM |
| Random Rubber Part | OoLong | BRZ First-Gen (2012+) — General Topics | 8 | 01-28-2014 10:31 AM |
| Crew Carshow : Part Deux 9/7/13 | saiyajinimports | Great Lakes | 0 | 08-17-2013 05:18 AM |
