Old 09-28-2021, 10:48 PM   #80865
soundman98
ProCrastinationConsultant
soundman98's Avatar
This sounds like my Tribeca saga las fall/winter/spring...
i'm trying to remember what that was about...
all i know is i'm not topping $100 in parts. if this replacement carb doesn't fix the issue, i'm throwing a new motor at it. that puts my overall cost at around $270, which is just about half the cost of a new one.
soundman98 is offline
Old 09-28-2021, 10:58 PM   #80866
cjd
cjd's Avatar
Drives: 2017 BRZ
Just buy a new one, swap the motor, then return it. "Doesn't want to run, decided to go a different direction."
cjd is offline
Old 09-28-2021, 11:34 PM   #80867
soundman98
soundman98's Avatar
sometimes the point is the journey, not the destination
The Following 4 Users Say Thank You to soundman98 For This Useful Post:
cjd (09-29-2021), NoHaveMSG (09-29-2021), Spuds (09-29-2021), Ultramaroon (09-28-2021)
Old 09-29-2021, 12:36 AM   #80868
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
If you really want a refresher...
https://www.ft86club.com/forums/showthread.php?t=142845
Tldr:. Misfiring caused by a damaged coil pack that I missed on first look, thinking it was a fuel problem for a while.
Spuds is offline
soundman98 (09-29-2021), Ultramaroon (09-29-2021)
Old 09-29-2021, 01:14 AM   #80869
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Finally bought a new battery at Costco today. Maybe I'll put it in tomorrow.
Sapphireho is offline
humfrz (09-29-2021), Ultramaroon (09-29-2021)
Old 09-29-2021, 01:17 AM   #80870
NO! Then we would never know why it wouldn't start -
humfrz is offline
The Following 4 Users Say Thank You to humfrz For This Useful Post:
Sapphireho (09-29-2021), soundman98 (09-29-2021), Spuds (09-29-2021), Ultramaroon (09-29-2021)
Old 09-29-2021, 01:23 AM   #80871
They have Costco in Idaho? -
humfrz is offline
Old 09-29-2021, 01:34 AM   #80872
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Yea. Looks just like a Costco anywhere else.
Your photo makes me almost miss the old days when the corner parts store was a happening place. Hell, you went there every 3000 miles for points, condensor, rotor, cap, plugs, fuel filter, oil filter, air filter and oil. That was if everything was going well. Good times.
The Following 3 Users Say Thank You to Sapphireho For This Useful Post:
humfrz (09-29-2021), soundman98 (09-29-2021), Ultramaroon (09-29-2021)
Old 09-29-2021, 02:09 AM   #80873
Sapphireho
Famous Potatoes
Sapphireho's Avatar
@spike021, how are you and the pup doing?
Old 09-29-2021, 01:09 PM   #80874
spike021
spike021's Avatar
Not bad. We've had some ups and downs with a couple health related things but everything else has been pretty good.
He's currently losing his puppy teeth and fortunately I've found a few and decided to keep them (I don't know if that makes me weird or not ). But that means he's also teething, so that's been interesting.
Instagram: @spike.grc
spike021 is offline
The Following 4 Users Say Thank You to spike021 For This Useful Post:
humfrz (09-29-2021), Sapphireho (09-29-2021), soundman98 (09-29-2021), Ultramaroon (09-29-2021)
Old 09-29-2021, 01:12 PM   #80875
Sooo true -
In addition, the store/shop where I used to go as a kid, also had a small machine shop in the back, that would grind valves and mill heads.
Also, they were a source of information. For example, they introduced me to the plastic wire/tape to gauge how to shim piston rod bearings and to a miracle device to compress piston rings, so as to get the pistons back into the cylinders -
humfrz is offline
Old 09-29-2021, 01:14 PM   #80876
Hide your slippers!
humfrz is offline
spike021 (09-29-2021)
Old 09-29-2021, 01:18 PM   #80877
spike021
spike021's Avatar
Hide your slippers!
Fortunately *knock on wood* he's been pretty great with not destroying anything.
The most he's done was nibble a corner of my coffee table the first or second week I had him, and then about a month or two ago he nibbled part of a baseboard.
I try to leave out plenty of toys with different textures and supervise a lot. It makes my floor a bit messier than I prefer but I figure for right now it's not a terrible idea because then he's hopefully more interested in chewing that stuff since it's easily available. He's pretty well-trained (for now, anyway) not to nibble on things he shouldn't.
spike021 is offline
The Following User Says Thank You to spike021 For This Useful Post:
humfrz (09-29-2021)
Old 09-29-2021, 01:23 PM   #80878
Ohhhhhh ....... I hope it's just not being passive aggressive -
humfrz is offline
