#80837 | |
ProCrastinationConsultant
Spark tester started falling, grabbed the uninsulated part! I shoulda gotten the stick and some water!
| The Following User Says Thank You to soundman98 For This Useful Post: | humfrz (09-27-2021) |
#80838 |
That was 850 pounds
| The Following User Says Thank You to soundman98 For This Useful Post: | Ultramaroon (09-27-2021) |
#80839 |
Drives: Crapcan
That reminds me, I need to do a scrap run. I probably have 6 tons.
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | soundman98 (09-27-2021) |
#80840 |
Airborne at your service
Drives: '17 BRZ Series.Yellow
West Texas sucks balls for driving through
#80841 |
Because compromise ®
Drives: Red Herring
| The Following 6 Users Say Thank You to Captain Snooze For This Useful Post: | NoHaveMSG (09-28-2021), ScoobsMcGee (09-28-2021), soundman98 (09-27-2021), spike021 (09-28-2021), Ultramaroon (09-28-2021), weederr33 (09-27-2021) |
#80842 | |
Guilt free parts vulture!
Drives: 2024 GR86 Trueno Halo 6MT
Eh... we routinely see these here in San Diego on their way to Tijuana...
| The Following 2 Users Say Thank You to nextcar For This Useful Post: | soundman98 (09-27-2021), spike021 (09-28-2021) |
#80843 | |
had another one i originally ordered that was an entirely different style, didn't think it would work, but it bolted up, and the spark checker confirmed it worked right. motor fired right up on starting fluid. but didn't seem to be sucking fuel. got the fuel trims setup so it would run with a really lumpy idle, but high speed didn't exist. then it all stopped, plug fouled, starting fluid stopped working, and i went back to square one. i can get it to hiccup and jump once in a while if i slam the valves shut and swing them open, but that's it anymore... now i'm getting suspicious of the chinesium carb i got... i'm somewhere near $80-100 in parts into this.. a new motor is about $160... i'm leaning towards the motor to just make it work frustrating. i've never had this much issues getting a motor to work.. i've rescued close to a dozen other small motors under similar circumstances with nothing more than a spark plug, and sometimes a little carb work...
| The Following User Says Thank You to soundman98 For This Useful Post: | Spuds (09-28-2021) |
#80844 |
#80845 |
i did think about it. it bolts up to 2 bolts on a parallel vertical plane with the magnet/crankshaft with up/down slots to adjust it's distance from the crank. all i can do is run it backwards, which makes for less of a spark.
magnet is riveted to the flywheel, so i can't adjust it's location either.
| The Following User Says Thank You to soundman98 For This Useful Post: | humfrz (09-28-2021) |
#80846 | |
| The Following User Says Thank You to Ultramaroon For This Useful Post: | soundman98 (09-28-2021) |
#80847 |
Drives: 2018 Subaru BRZ
Dude this absolutely sucks, my car is covered in small dents now. Is not even a full fall season yet.
I have no idea what to do. Maybe park on the street for the remainder of the season.
| The Following User Says Thank You to spcmafia For This Useful Post: | humfrz (09-28-2021) |
#80848 |
The Dictater
Drives: '13 Red Scion FRS
PDR? Get a padded cover? Parking somewhere not under a tree is a good plan for now if it is available.
| The Following 2 Users Say Thank You to Spuds For This Useful Post: | soundman98 (09-28-2021), spcmafia (09-28-2021) |
#80849 |
Junior Senior with Cheese
You know it is going to be an interesting day when you wake up at 5 am with the song Margaritaville stuck in your head.
| The Following User Says Thank You to ScoobsMcGee For This Useful Post: | soundman98 (09-28-2021) |
#80850 | |
I have mostly heard bad things about covers, how condensation can build and affect the paint. But I'm more likely going to park the car on the street until the tree goes bald. After that I just have to worry about the giant dying branches hanging on top of the cars.
| The Following User Says Thank You to spcmafia For This Useful Post: | Spuds (09-28-2021) |
| Language Rant Part Deux | MuseChaser | Off-Topic Lounge [WARNING: NO POLITICS] | 43 | 04-23-2017 07:55 PM |
| Random thoughts thread | MrVito | Off-Topic Lounge [WARNING: NO POLITICS] | 37188 | 02-25-2016 10:00 AM |
| Random Rubber Part | OoLong | BRZ First-Gen (2012+) — General Topics | 8 | 01-28-2014 10:31 AM |
| Crew Carshow : Part Deux 9/7/13 | saiyajinimports | Great Lakes | 0 | 08-17-2013 05:18 AM |
