Old 09-27-2021, 04:40 PM   #80837
soundman98
ProCrastinationConsultant
soundman98's Avatar
OK, well then, just bite down on a stick, pull the plug wire off and hold it in your hand while standing in a puddle of water and give the starter rope a big yank.
Spark works
Spark tester started falling, grabbed the uninsulated part!
I shoulda gotten the stick and some water!
soundman98 is offline
humfrz (09-27-2021)
Old 09-27-2021, 04:41 PM   #80838
soundman98
soundman98's Avatar
I had hoped it was the case, hence my attempt at a non-judgemental response.
On a brighter note, looks awfully damn heavy! Surprised at how little she's squatting. Looks great.
That was 850 pounds
Ultramaroon (09-27-2021)
Old 09-27-2021, 05:01 PM   #80839
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
That reminds me, I need to do a scrap run. I probably have 6 tons.
NoHaveMSG is offline
soundman98 (09-27-2021)
Old 09-27-2021, 07:16 PM   #80840
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
West Texas sucks balls for driving through
MS, CSCS, TSAC-F, CPT
weederr33 is offline
Old 09-27-2021, 07:48 PM   #80841
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Captain Snooze is offline
The Following 6 Users Say Thank You to Captain Snooze For This Useful Post:
NoHaveMSG (09-28-2021), ScoobsMcGee (09-28-2021), soundman98 (09-27-2021), spike021 (09-28-2021), Ultramaroon (09-28-2021), weederr33 (09-27-2021)
Old 09-27-2021, 07:59 PM   #80842
nextcar
Guilt free parts vulture!
Drives: 2024 GR86 Trueno Halo 6MT
That was 850 pounds
Eh... we routinely see these here in San Diego on their way to Tijuana...
Originally Posted by drewbot
Pull out
nextcar is offline
The Following 2 Users Say Thank You to nextcar For This Useful Post:
Old 09-27-2021, 09:01 PM   #80843
soundman98
soundman98's Avatar
Spark works
ok, the spark tester paid for itself. that magneto worked without the spark plug installed, just the tester to ground. but didn't work how it was supposed to, connected inline with the magneto, and spark plug, indicating that it wasn't a strong enough spark. apparently i had a bad, new magneto...
had another one i originally ordered that was an entirely different style, didn't think it would work, but it bolted up, and the spark checker confirmed it worked right.
motor fired right up on starting fluid. but didn't seem to be sucking fuel.
got the fuel trims setup so it would run with a really lumpy idle, but high speed didn't exist.
then it all stopped, plug fouled, starting fluid stopped working, and i went back to square one. i can get it to hiccup and jump once in a while if i slam the valves shut and swing them open, but that's it anymore...
now i'm getting suspicious of the chinesium carb i got...
i'm somewhere near $80-100 in parts into this.. a new motor is about $160... i'm leaning towards the motor to just make it work
frustrating. i've never had this much issues getting a motor to work.. i've rescued close to a dozen other small motors under similar circumstances with nothing more than a spark plug, and sometimes a little carb work...
Spuds (09-28-2021)
Old 09-27-2021, 09:38 PM   #80844
ok, .
Now, tell me if you timed the magneto ......
humfrz is offline
Old 09-27-2021, 10:18 PM   #80845
soundman98
soundman98's Avatar
i did think about it. it bolts up to 2 bolts on a parallel vertical plane with the magnet/crankshaft with up/down slots to adjust it's distance from the crank. all i can do is run it backwards, which makes for less of a spark.
magnet is riveted to the flywheel, so i can't adjust it's location either.
humfrz (09-28-2021)
Old 09-28-2021, 01:03 AM   #80846
Just has to be gapped to the magnet. Sheet or two of paper. The closer you can get without contact, the better.
Ultramaroon is offline
soundman98 (09-28-2021)
Old 09-28-2021, 07:40 AM   #80847
spcmafia
spcmafia's Avatar
Drives: 2018 Subaru BRZ
Dude this absolutely sucks, my car is covered in small dents now. Is not even a full fall season yet.
I have no idea what to do. Maybe park on the street for the remainder of the season.
spcmafia is offline
The Following User Says Thank You to spcmafia For This Useful Post:
humfrz (09-28-2021)
Old 09-28-2021, 08:41 AM   #80848
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
PDR? Get a padded cover? Parking somewhere not under a tree is a good plan for now if it is available.
Spuds is offline
soundman98 (09-28-2021), spcmafia (09-28-2021)
Old 09-28-2021, 09:48 AM   #80849
ScoobsMcGee
Junior Senior with Cheese
ScoobsMcGee's Avatar
You know it is going to be an interesting day when you wake up at 5 am with the song Margaritaville stuck in your head.
ScoobsMcGee is offline
Old 09-28-2021, 01:29 PM   #80850
spcmafia
spcmafia's Avatar
I have mostly heard bad things about covers, how condensation can build and affect the paint. But I'm more likely going to park the car on the street until the tree goes bald. After that I just have to worry about the giant dying branches hanging on top of the cars.
spcmafia is offline
Spuds (09-28-2021)
