Old 09-03-2021, 03:56 PM   #15
CSG Mike
CSG Mike's Avatar
Originally Posted by Vesartis View Post
Pics
They definitely aren't sturdy. I bent the little triangle of the dust shield but I think ideally you want to take them off. I don't run them since switching to CSG pads, since they ended up makin the braking feel inconsistent.
Ducting is always a last resort. It introduces thermal stress from the temperature swings that you ideally want to avoid.
Real world example: Porsche RS-R GT-LM cover up the brake duct as much as possible and use the absolute bare minimum. Look at photos from different track to see different levels of open-ness on the duct. Sebring? Big opening. Long Beach? Medium opening. Watkins? Small opening.
The Following 4 Users Say Thank You to CSG Mike For This Useful Post:
Cephas (09-23-2021), soundman98 (09-03-2021), TommyW (09-03-2021), Vesartis (09-03-2021)
Old 09-03-2021, 04:54 PM   #16
ZDan
ZDan's Avatar
Drives: '23 BRZ
Try the CSG C2 front and rear. Yes, non-staggered.
I'm running front rear (without ABS), like 'em a lot...
This is after being disappointed with XP10, Winmax W5, PMu CR, etc.
Great but not too grabby bite, consistent performance over wide temperatures, not too too loud, dust is not bad, they're fairly durable, and pretty streetable as well.
Old 09-03-2021, 07:56 PM   #17
Jstyle
Jstyle's Avatar
Drives: 2020 86
That's a very entry level, beginner setup, which you're clearly FAR beyond, if you've already realized and learned how to modulate FADE, let alone just braking.
If you want to get even more life and capacity, go CE2 front C2 rear.
How long should pads be lasting me? I have been eyeing those for a while.
Jstyle is offline   Reply With Quote
Old 09-03-2021, 08:02 PM   #18
CSG Mike
CSG Mike's Avatar
Life varies by driver, car prep, track, conditions, etc., but typically if you're needing to replace pads every 5 track days or less, you can probably use an upgrade.
You can also look at it as 8 hours of track time or less, you can probably use an upgrade.
With brakes, too much is often safe, but not enough results in both dangerous situations as well as having expensive paperweights.
Old 09-03-2021, 08:07 PM   #19
soundman98
ProCrastinationConsultant
soundman98's Avatar
interesting, hadn't considered the thermal stress angle.
has anyone done testing to putting the ducting behind the radiator, which would pre-warm some of the air but still maintain a positive air flow?
Old 09-03-2021, 09:03 PM   #20
CSG Mike
CSG Mike's Avatar
Let's say your radiator has 100% efficiency (it doesn't), and warms the air to 180F. That's still a huge difference from a 800F rotor.
50F, 100F, or 180F, is still all a huge difference to a 800F rotor.
You're better off using a smaller amount of air (it'll all mix anyways), rather than "warmer" air.
Old 09-03-2021, 09:34 PM   #21
Icecreamtruk
Drives: Track preped NA FRS
As a drop of extra info. I removed my ducts when I went to a BBK setup. My discs were cracking by the time I got to replace my pads on OEM size, I didnt want to risk the more expensive 2 piece rotors crack as fast, considering pads would last much more than before. So far, I change rotors with pads as a precaution, but they could still go on. (lastting about 2-3 times as much as before the BBK).
Icecreamtruk is offline   Reply With Quote
The Following 2 Users Say Thank You to Icecreamtruk For This Useful Post:
soundman98 (09-03-2021), Takumi788 (09-22-2021)
Old 09-21-2021, 12:49 PM   #22
Nickel
Nick
Drives: 2013 10 Series GT86 #182 of 2500
Damn, this is surprising. I just put on new XP8's F&R with new blank rotors for the street and the stopping power is almost as comparable to my 2016 Mustang GTPP with 6 piston brembos and 15" rotors, but they don't bite anywhere near as hard. Still, I've put them through their paces on the street, but I plan to track the car next year and was hoping they would hold up. I guess we'll see.
2013 Scion FR-S 10 Series MT #182 of 2500/2007 BMW Z4 3.0si Coupe/2016 Yamaha FZ-09/2022 Ford Mustang Mach 1 Handling Package MT Recaro 700A (#N3956)/2023 Toyota Camry XSE
Instagram: @the_white_comet_of_zion
Nickel is offline   Reply With Quote
Old 09-21-2021, 01:07 PM   #23
Jstyle
Jstyle's Avatar
Drives: 2020 86
So after going with PMU Club racers on the front I’m sold on their ability to not fade. I was really pushing them hard all day long for a 2 day in the 90’s by the second day and they kept asking for more.
The longevity is a bit in question because I’m not sure they’re going to last long. This is after just a 2 day.
The Following User Says Thank You to Jstyle For This Useful Post:
soundman98 (09-21-2021)
Old 09-21-2021, 10:54 PM   #24
CSG Mike
CSG Mike's Avatar
You've already faded them, just not catastrophically.
You MIGHT get 3 more days out of them, but likely will be having issues on the 4th an 5th day.
Old 09-22-2021, 01:01 PM   #25
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
What tires are you running? Any suspension mods? N/A engine?
blsfrs is online now   Reply With Quote
Old 09-22-2021, 01:11 PM   #26
Jstyle
Jstyle's Avatar
Drives: 2020 86
245/40/17 Falken 660's
Fortune 500
Just headers and a tune as far as engine goes
Old 09-22-2021, 01:59 PM   #27
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
PMU pads seem to crumble like that. There is a localish guy to me with a stock performance package car with SX2's. He had the same issue with the Club Racer pads.
Old 09-22-2021, 09:22 PM   #28
blsfrs
blsfrs's Avatar
Fortune 500
How do you like the Fortune 500's. I've been eyeballing the 510 as an upgrade from stock.
How to identify different types of brake fade? jonnyozero3 Tracking / Autocross / HPDE / Drifting 8 01-14-2019 08:52 PM
Brake Fade life tofurun Suspension | Chassis | Brakes -- Sponsored by 949 Racing 14 08-30-2016 02:47 PM
Brake Fade/Cooling? TommyC Tracking / Autocross / HPDE / Drifting 10 02-03-2016 01:44 PM
Brake Fade RAWR BRZ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 09-27-2012 03:56 PM
Odd brake pedal feel, fade? yomny Suspension | Chassis | Brakes -- Sponsored by 949 Racing 27 09-11-2012 12:29 PM
