Old 01-27-2016, 05:28 PM   #1
TommyC
Drives: 2016 BRZ
Brake Fade/Cooling?
I plan to do a few HPDE events every year, and will be upgrading to stainless lines, high temp fluid, and dedicated track pads.
How well do the OEM calipers/rotors hold up to fade? I haven't dug into things yet as I just picked up the car and it is winter here, but it doesn't look like there are OEM cooking ducts.
I'm hard on brakes (I've melted DTC 60s on a heavier car without ventilated brakes). I would prefer not to have to run ducting for only doing a handful of events a year, but if others have had issues I'll bite the bullet since it will be cheaper than replacing glazed/warped rotors and cracked pads.
I'll be running 17x8 Kosei wheels with 235 R Comps on the track.
TommyC is offline   Reply With Quote
Old 01-27-2016, 05:31 PM   #2
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
Just upgrade your pads and fluid for your first event and see what you think she needs from there.
The Following 2 Users Say Thank You to go_a_way1 For This Useful Post:
stevesnj (01-27-2016), Toyarzee (01-27-2016)
Old 01-27-2016, 05:34 PM   #3
Toyarzee
Shibby!
Toyarzee's Avatar
Drives: '14 White FR-S, '01 turbo mini taco
Stock calipers work well enough. Stock rotors are vented and work fine as well, until you chew them up with aggressive pads. Track pads and fluid on stock everything and 235 r compounds here and no issues after a year of tracking. New brake lines on this new of a vehicle is also unnecessary unless you're very picky with feel.
Toyarzee is offline   Reply With Quote
Old 01-27-2016, 06:19 PM   #4
Based on your experience, start with a similar pad to the DTC, along with fluid, and see how you do. If you're fading that, then the only solution is to examine your driving to see if there are any corrections that can be made there (unlikely with your experience), or get a BBK.
Ducting will help a little, but a BBK is the real solution.
Blizzard (02-02-2016)
Old 01-28-2016, 06:43 PM   #5
ka-t_240
I run dtc60, haven't had any issues other than slight abs activation. No fade or anything like that.
ka-t_240 is offline   Reply With Quote
Old 01-28-2016, 07:07 PM   #6
TommyC
Drives: 2016 BRZ
Thanks. Any other modifications to the car? Or did you just slide in the pads and hit the track?
Old 02-02-2016, 06:49 PM   #7
Pat
Pat's Avatar
Drives: 2023 BRZ
The Togue Factory brake duct kit will make a significant difference. I run DTC-60s with good fluid and the ducts. Is it as good as a BBK? No. But for me, it is the difference between having confidence my car will stop (mostly) consistently during a 20 minute session and going back in after a few laps.
Without the ducts I would have to bleed my brakes after every other session. With them I can go several days at least.
Also, keeping operating temps down with a BBK keeps operating costs down. If you have a chunk of change to spend and know you'll be doing many days every year for at least a few years, go with a BBK.
The TF duct kit is a nice middle ground that is a great value.
The Following User Says Thank You to Pat For This Useful Post:
CSG Mike (02-02-2016)
Old 02-03-2016, 12:18 AM   #8
ka-t_240
I have stainless lines and RBF600 fluid. I pulled the stock rotors to put in some centric blanks after about 15k miles, a bunch of auto-x and 3-4 track days. I have them sitting around as spares in case i ever crack a rotor at the track.
No cooling, brake bias, or other mods.
Car has suspension, exhaust, and is currently tuned on e85.
Old 02-03-2016, 02:19 AM   #9
CounterSpace Garage
CounterSpace Garage's Avatar
Drives: Subaru BRZ / Toyota 86 Experts
Brake pads, that have an elevated heat capacity, are the most important part of fade prevention. Application is key to setting up the car properly. If you are looking to improve your braking capacity, please don't hesitate to contact us!
CounterSpace Garage is offline   Reply With Quote
The Following User Says Thank You to CounterSpace Garage For This Useful Post:
wparsons (02-03-2016)
Old 02-03-2016, 08:54 AM   #10
ka-t_240
Completely agree. The track I race the most has 2 very high speed straights in your sharper corners with minimal run off, sadly I've seen too many cars boil the fluid and play tag with walls.
Old 02-03-2016, 01:44 PM   #11
CounterSpace Garage
Brake pads and brake fluid are always important items to add. For the track, we use pads developed for track use and brake fluid that is developed for racing/endurance racing. Quality of fluid for use on your car can be used for just a limited capacity -or- just use the best and not worry about that capacity issue...let us know if you are looking for a setup that'll keep your confidence high on track.
How to identify different types of brake fade? jonnyozero3 Tracking / Autocross / HPDE / Drifting 8 01-14-2019 08:52 PM
Recognizing Brake Fade with Data Analysis GSpeed Tracking / Autocross / HPDE / Drifting 25 07-06-2015 12:42 AM
Project Mu - Brake Pads, Rotors and Brake Cooling Duct - FREE SHIPPING! eauto Brakes, Suspension, Chassis 255 10-15-2014 01:45 PM
Brake Fade RAWR BRZ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 09-27-2012 03:56 PM
Odd brake pedal feel, fade? yomny Suspension | Chassis | Brakes -- Sponsored by 949 Racing 27 09-11-2012 12:29 PM
