Old 10-08-2019, 08:01 PM   #57
Ernest72
Originally Posted by Roadcone View Post
some older JDM cars the floor plans flexed like hell and they really could use seat rail bracing... not like that but they could use something.
That's subjective. I'm asking for objective.
My 04 turns on rails. All the braces and bushings really changed the car. But man the poly bush in my anti lift kit gets me every day. I feel every crack that is perpendicular to the car/road. Railroad crossings suck. Literally can shake loose fillings. And that ones a bitch to change. At least most of these braces you can just unbolt if they are harsh.
Old 10-14-2019, 12:07 AM   #58
Yoniyama
Drives: BRZ 2018
It is common for Toyota to add a fender brace to the A-post, many Lexus models (IS250, GS350, etc) have them OEM.
It is interesting that TRD only adds the fender brace and a stiffer v-brace in the engine bay for the 14r-60, for chassis re-inforcement.
I added a non-TRD front fender to A-post brace and it was a very worthwhile mod.
I think braces are becoming more popular, as a standard OEM fitment. If you look at certain GM models (eg the ATS) or BMW's, you will find a lot of braces already fitted. I read that GM claimed 30% improvement in chassis stiffness from the braces added to the ATS.
While I can't measure the incremental benefit of each brace, but in principle,added stiffness should generally lessen chassis flexing, hence fewer rattles down the road.
The only surprise is a quotation from Tada-san, in an interview of Supra, when he claimed that too much stiffness actually slowed the car down!
Yoniyama is offline   Reply With Quote
Old 10-17-2019, 08:37 AM   #59
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
Which one? How was installation?
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
Old 10-17-2019, 12:30 PM   #60
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Cite your source! Suspension stiffness maybe. Frame stiffness no.
A well-designed monocoque is the best road to stiffness.
Old 10-17-2019, 01:07 PM   #61
Yoniyama
Drives: BRZ 2018
See interview with Tada-san on the Supra:
[ame]https://www.youtube.com/watch?v=tmzNNckDm4s[/ame]
The chassis (not suspension) can be too stiff, according to Tada-san.
Old 10-17-2019, 07:14 PM   #62
EAGLE5
Dismember
EAGLE5's Avatar
I cannot make it through 20 minutes of video for that.
Old 10-17-2019, 08:01 PM   #63
Yoniyama
Drives: BRZ 2018
Please see photo attached.
The Following 3 Users Say Thank You to Yoniyama For This Useful Post:
kevaughan (09-21-2021), norcalpb (10-17-2019), venturaII (10-18-2019)
Old 10-18-2019, 07:58 PM   #64
Ernest72
I can say that I remember my butt Dyno feeling the fender cowl braces I did from turn in concepts on my 04 WRX. But who knows?
Old 09-21-2021, 05:49 AM   #65
AndMsc
Drives: MY2018 GT86 EU
Originally Posted by norcalpb View Post
Are you talking about the rear v bars from the 14r60?
https://www.japanparts.com/parts/detail/?id=53517
AndMsc is offline   Reply With Quote
The Following User Says Thank You to AndMsc For This Useful Post:
SuperTom (03-06-2022)
Old 09-22-2021, 05:37 PM   #66
AndMsc
Do you think this does anything?
https://www.japanparts.com/parts/detail/?id=53482
It seems to brace a single part.
Old 09-22-2021, 05:52 PM   #67
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
That seriously has to be a joke. It looks like it mounts from one subframe mounting point to the other on the rear of the car. So it is bracing the mounting bolts together
AndMsc (09-22-2021)
Old 09-22-2021, 06:01 PM   #68
AndMsc
Exactly. Does it make sense? I mean does it give any benefit to brace the mounting bolts together?
Old 09-22-2021, 06:03 PM   #69
AndMsc
And this do you thing links the top of the shocks to the top of the trunk frame?
Old 09-22-2021, 06:09 PM   #70
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Exactly. Does it make sense? I mean why would one brace the mounting bolts together?
I mean I guess that is a long bolt passing through a tall bushing and could help. I couldn't imagine it is doing that much.
Looks like it bolts to upper mount for the rear shocks. There are two studs from the shock mount that poke up into the trunk right there. I don't believe there is anything else they could bolt to in that location.
AndMsc (09-22-2021)
Agency Power Chassis Braces and Strut Bar? megamarines Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 07-17-2015 10:23 PM
DIY Lower Chassis Braces vividracing DIY (Do-It-Yourself) Guides 0 04-08-2015 01:30 PM
TB Performance Products Chassis Braces TB Performance Products Brakes, Suspension, Chassis 6 08-20-2013 07:58 PM
Carbing Chassis Braces ttknf Suspension | Chassis | Brakes -- Sponsored by 949 Racing 23 08-14-2012 05:04 PM
Coilovers, swaybars, chassis braces and more! No Limit Motorsport Brakes, Suspension, Chassis 0 08-05-2012 11:31 AM
