Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 09-17-2021, 10:28 AM   #113
Pete
Pete's Avatar
Drives: 22 BRZ
Originally Posted by Kona61 View Post
That looks sooo much better.
This chart has the opposite scaling problem of the first one, so the y-axis is very short. 0 torque is more than halfway up the chart, most of the Y-axis shows negative torque numbers.
Weird way to do it but does make for a better looking chart.
2013 FRS -> 2011 CTS-V -> 2006 Cayman S -> 2015 GTI -> 2022 BRZ
Pete is offline   Reply With Quote
Old 09-17-2021, 10:38 AM   #114
stilesg57
Drives: Shopping Mustang GTs and BRZs/86s
That dip is weird. Starts around 3500, hits its nadir at about 4300, gone by about 4500. It’s higher in the rev range than I’d hoped for; you're probably going to get dropped into it after every shift (and certainly every shift before redline).
They even circle it at about 6:45. It stood out to them too.
Body of knowledge continues: car makes low 190s whp give or take, axle back exhausts add a rounding error’s worth of HP.
I’m hoping a light application of FI can erase the dip and get me to ~270whp since that’s about what the 2014 Cayman S had that was the best matched engine/chassis I’ve ever personally driven. If this can make the same power at basically the same weight in the nicest chassis south of that Porsche, I think I’ll be happy.
stilesg57 is offline   Reply With Quote
Old 09-17-2021, 10:42 AM   #115
Stonehorsw
Stonehorsw's Avatar
Drives: 18 Brz (Sold) / 22 BRZ / 13 BRZ
HKS announced that their supercharger reaches 340hp (not to wheels I would assume). 270whp should be not hard with a good kit from edelbrok/harrop/jackson
Stonehorsw is offline   Reply With Quote
Old 09-17-2021, 10:48 AM   #116
OkieSnuffBox
Drives: '23 BRZ Limited
Well the Edlebrock on the previous gen hit 250whp and offered a 3/36k powertrain warranty.
So yeah, I wouldn't imagine 20 more wouldn't be a big deal.
Old 09-17-2021, 10:50 AM   #117
Pete
Pete's Avatar
Drives: 22 BRZ
I am waiting to see a dyno chart with headers and a tune on an otherwise stock car. That is all I am planning to do to the powertrain for a long time.
When/If Edelbrock gets a reliable kit together again for this gen I would find it hard to resist. But that takes a long time, years maybe.
Old 09-17-2021, 10:54 AM   #118
Stonehorsw
Stonehorsw's Avatar
I am with similar mindset. If a kit hits 230/240 whp with E85, then I will be probably jumping and buying the header/flex kit.
Old 09-17-2021, 12:57 PM   #119
Kona61
Kona61's Avatar
Drives: ‘22 CWP
Yea, I don't know why it's so difficult to present data properly on a chart lol.
I think at this point after having read reviews and whatnot, the torque curve is not a concern.
I think to put it this way: journalists who were specifically looking for a torque dip to criticize did not or minimally complained about it.
So I honestly am okay with it being there as long as how I think it feels correlates with what I've been hearing.
Kona61 is offline   Reply With Quote
Old 09-17-2021, 01:03 PM   #120
Dzmitry
Dzmitry's Avatar
Drives: 2018 Subaru BRZ Limited with PP
There you go, now everyone can calm down about the way the torque curve looks and how it compares. There's still about a 20 ft-lb drop there from around 19.5 to 22 Kgm but it just looks much nicer on a dyno like this and on a graph that is not so stretched. This gen is making more power and torque everywhere, you won't be feeling that dip.
Dzmitry is offline   Reply With Quote
Old 09-17-2021, 01:03 PM   #121
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Here's a screenshot where you can actually see the rpms.
Old 09-17-2021, 01:08 PM   #122
stilesg57
…journalists who were specifically looking for a torque dip to criticize did not or minimally complained about it.
Correction: “…journalists who were specifically told by the Toyota and Subaru marketing departments in a pre-drive presentation that the torque dip was addressed did not or minimally complained about it.”
My concern is that most of those peeps have demonstrated that their butt dynos aren’t nearly as well calibrated as their regurgitate-lines-fed-directly-to-them-from-the-marketing-department-that-flew-them-out-there dynos. Seeing the same verbatim quips show up again and again across dozens of reviews has me convinced those dynos are WELL tuned. Given the mounting evidence, I do think we can retire the “torque dip is nearly gone” line as bunk.
That said, man I hope you’re right. Or at least that FI will fill the hole like it seemed to on the FA20.
Old 09-17-2021, 02:07 PM   #123
SockMonkey
Drives: '13 BRZ Limited
Even just proper headers helped eliminate the dip on 1st gen, without a tune. I might go that route to help maintain warranty until I eventually supercharge it. The red is just headers, no tune, green is tune.
SockMonkey is offline   Reply With Quote
Old 09-17-2021, 02:18 PM   #124
Dzmitry
Dzmitry's Avatar
Curious where you got this dyno... that's an awful lot of gain up top without a tune, I don't know that I buy it.
EDIT: Second graph down is a little more realistic in terms of expectations for just a header without a tune.
https://www.ft86club.com/forums/showthread.php?p=938787
Old 09-17-2021, 02:35 PM   #125
Stonehorsw
Stonehorsw's Avatar
I do not see a dip there, but a plateau. (Second part for other user) Feeling may be very different from a dip, so we cannot assume that a jornalist would be able to feel that in a short eun, without running specific testing.
Let’s see how it feels when we can test drive (november?) and try to compare side by side vs gen1 (a colleague here kept his gen1 unmodified, which will be a good baseline)
Old 09-17-2021, 04:34 PM   #126
SockMonkey
Got it from this guys post, #38. "Bottom line is stock, middle is header/intake no tune, top is with tune."
https://www.ft86club.com/forums/show...t=79303&page=3
Typical Mustang Dyno Numbers? Rockz222 Engine, Exhaust, Transmission 6 07-11-2015 08:33 PM
Dyno numbers ogrowup Engine, Exhaust, Transmission 7 12-27-2014 08:04 AM
Average Stock Dyno Numbers? KONVERTER Engine, Exhaust, Transmission 23 10-12-2013 10:13 PM
Dyno numbers list from Evasive Motorsports Meet/Dyno Fish Southern California 29 02-24-2013 03:16 AM
dyno numbers seem low stealth_fighter Scion FR-S / Toyota 86 GT86 General Forum 9 02-02-2013 09:01 PM
