Old 09-13-2021, 02:18 PM   #1
DMichael
Drives: No 86 yet
For the MT, what do Track and Sport modes actually do?
I've watched every video review I can find but don't see an explanation for this other than the dash display changes.
What do Track and Sport modes actually do for the manual transmission models other than change the dash display?
DMichael is offline   Reply With Quote
The Following 2 Users Say Thank You to DMichael For This Useful Post:
dowroa (09-14-2021), JesseG (09-13-2021)
Old 09-13-2021, 02:38 PM   #2
trippinbillies40
trippinbillies40's Avatar
Drives: '22 WRB
Don't believe there's a sport mode on the MT, just track mode. Track mode allows more slip angle in the Vehicle Dynamics Control before making corrective actions. You can get more sideways than full tc/vdc, but it'll bail you out if you cross the line.
From my testing with a '17 BRZ PP, it really feels like it kicks in based on rate of change on yaw as opposed to just total yaw, as I was able to hold some pretty crossed up slides at a track day without interference from the car. So if the '22 system is similar, it's a nice learning tool for people new to track driving.
I think sport mode is just on ATs and affects shifting habits of the car.
trippinbillies40 is offline   Reply With Quote
The Following 2 Users Say Thank You to trippinbillies40 For This Useful Post:
Old 09-13-2021, 02:59 PM   #3
spcmafia
spcmafia's Avatar
Drives: 2018 Subaru BRZ
I believe for both MT and AT, sport mode/ track mode give you partial full control of the vehicle with some level of assist if things go south. Compared to pedal dance mode where you are in full control of the vehicle.
spcmafia is offline   Reply With Quote
Old 09-13-2021, 03:32 PM   #4
Westen86
Purist
Westen86's Avatar
Drives: 2013 FRS - Hot Lava
"Sport" is on the early generation, AT and MT. "Track" is on the facelift generation, also AT and MT. They both turn off Traction Control but retain some Stability Control. Track is just a little looser with the interference, lets you slip a little more than the early cars. There is a thread about swapping ABS modules between the two that has better information.
WTB: Everything Verus
RaceComp SS-1, Complete SuperPro bushings, TR Motorsport FF10 17x9 +45, GruppeS UEL, HKS Hi-Power V2, OFT(93/E85)
Westen86 is offline   Reply With Quote
Old 09-13-2021, 03:42 PM   #5
JesseG
JesseG's Avatar
Drives: 2016 Scion FR-S
You can also defeat (almost) all traction control by holding down the Traction button correct? In the MT equipped cars. And there is a pedal dance that really disables everything on the first gen. Interesting to see if the second gen will allow the same. I never had the need to disable everything, but I think some guys/gals like to do that on track.
JesseG is offline   Reply With Quote
Old 09-13-2021, 08:58 PM   #6
RippedManiac
Jedi
Drives: Pikachu BRZ
On the Kouki 17+,
Normal mode - you swing it into a corner, it slides for like a foot then traction control steps in to "catch" you. Feels like mom pulling on your shift before you run off.
Track mode gives you more slip time (not distance) before it steps in and "catches" you.
Also opens up the throttle more. idk maybe placebo effect.
Hold down traction control for 5 seconds and its all off. Like the pedal dance on the Zenkis. Pure hoonery.
RippedManiac is offline   Reply With Quote
The Following User Says Thank You to RippedManiac For This Useful Post:
JesseG (09-14-2021)
Old 09-14-2021, 05:04 AM   #7
LancePower
Drives: 2020 BRZ tS
I thought the Pedal Dance also disabled ABS.
Where holding the Traction button does not.
LancePower is offline   Reply With Quote
Old 09-14-2021, 07:17 AM   #8
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Originally Posted by RippedManiac View Post
On the Kouki 17+~
~Hold down traction control for 5 seconds and its all off. Like the pedal dance on the Zenkis. Pure hoonery.
I think you’re referring to mode 4 (see 1st post in the link). The only difference between Zenki and Kouki cars here is that the brake LSD is now off on Koukis. There is some lack of consensus on whether the traction and stability control are actually off or on a really low interference setting. Problem is that only Subaru has the testing hours (and equipment) to know for sure. Then again for most people the difference on the 2017+ cars between mode 4 and pedal dance is imperceptible either way. Pedal dance is for sure 100% off.
https://www.ft86club.com/forums/showthread.php?t=140946
The Following 2 Users Say Thank You to Yoshoobaroo For This Useful Post:
dowroa (09-14-2021), JesseG (09-14-2021)
Old 09-14-2021, 08:12 AM   #9
DMichael
Drives: No 86 yet
Thanks for the info guys!
Old 09-14-2021, 02:48 PM   #10
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Ah, yet another thread on this topic.
We should really just have a wiki for things like that: a lot of people not knowing stuff, the stuff being complicated, and virtually nobody actually remembering all the exact details.
I believe pedal dance also turns off EBD?
Surprised that thread doesn't mention EBD on its first page.
The Following User Says Thank You to timurrrr For This Useful Post:
Yoshoobaroo (09-14-2021)
Old 09-14-2021, 02:55 PM   #11
DMichael
Drives: No 86 yet
What is EBD?
Old 09-14-2021, 05:34 PM   #12
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Originally Posted by DMichael View Post
What is EBD?
Electric brake distribution. Moves brake bias around based on a joke number of factors.
Old 09-14-2021, 06:13 PM   #13
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
No. No way to disable abs short of pulling the fuse.
Spuds (09-16-2021)
Old 09-15-2021, 02:04 AM   #14
LancePower
Drives: 2020 BRZ tS
I must have been thinking of EBD.
Track mode vs. VSC sport alex87f Scion FR-S / Toyota 86 GT86 General Forum 9 10-30-2018 10:47 PM
Automatic Acceleration in Manual vs Auto modes kavanagh Engine, Exhaust, Transmission 41 08-04-2014 09:19 AM
Whether on the Track or on the Streets, Brake Better with FR Sport FRSport.com Brakes, Suspension, Chassis 0 03-28-2014 12:35 PM
Anyone have the radio switching modes during hard cornering?? silvercar CANADA 4 07-08-2013 12:49 PM
Explanation on the different driving modes? WatchmaN Scion FR-S / Toyota 86 GT86 General Forum 11 08-02-2012 07:36 AM
