Old 08-01-2012, 05:05 PM   #1
WatchmaN
WatchmaN's Avatar
Drives: the girls crazy
Explanation on the different driving modes?
Could someone explain to me the different modes vsc,sport,snow ect.
What does it do and when to apply it? And when to take it off if you want to do something. No fancy explanation just the basics.
thanks
WatchmaN is offline   Reply With Quote
Old 08-01-2012, 05:08 PM   #2
yormaX
Rage your Dream
yormaX's Avatar
Drives: 2015 Scion FR-S
BLAM!
[ame="http://www.youtube.com/watch?v=j8qggahGNH0"]Toyota GT 86 Traction Control Demonstration [SKIDPAD] - YouTube[/ame]
yormaX is offline   Reply With Quote
Old 08-01-2012, 05:31 PM   #3
WatchmaN
WatchmaN's Avatar
yeah i saw all the video about it but still need more info, maybe i'm slow lol. But I know what I will use in the snow
Old 08-01-2012, 06:36 PM   #4
eriktherod
Drives: 2013 Scion FR-S Firestorm Red MT
Sport lets you hang the tail end out a little more while still pulling it in to avoid you spinning out completely. OFF off is as if the traction control didn't exist on the car to begin with.
I have yet to change it from the default ON setting. There's only been one time that I did something very stupid that even the traction control was probably facepalming at me. Fortunately, I was able to get it straightened out. (Think someone giving you directions, "the turn is up here.... like RIGHT HERE" and it practically being a 90 degree turn at a good 35mph, in third gear ).
eriktherod is offline   Reply With Quote
Old 08-01-2012, 06:39 PM   #5
empower-auto
Kouki-Monster
empower-auto's Avatar
We honestly need a better explanation. There' 3+ modes. 1 button lights up VSC Sport and another light. The other lights up trac off. If you hold down that button you get trac off and another light up which is true freedom to spin the wheels.
Just pushing trac off seems stupid because the car still corrects itself and you can't spin
Rich Anderson
EMPOWER AUTO
empower-auto is offline   Reply With Quote
Old 08-01-2012, 07:10 PM   #6
WatchmaN
WatchmaN's Avatar
thanks good start anybody else have more info or experiment.
Old 08-01-2012, 09:55 PM   #7
Nepenthe
Drives: 2013 Argento Silver Automatic FR-S
The following is my understanding. My understanding could be wrong but this is it.
All on
  • default setting when car is started
  • both TC and VSC are fully on
TC Off
  • hit the OFF button once
  • TC is off until car hits 31 mph, VSC is fully on
VSC Sport
  • hit the VSC Sport button
  • TC is fully on, VSC is in "VSC Sport" mode allowing some craziness
TC and VSC Off
  • hit the OFF button and the VSC Sport button
  • TC is off and will stay off (<---*I'm not certain of that*), VSC is in "VSC Sport" mode allowing some craziness
All Off
  • with car COMPLETELY STOPPED, hold the OFF button for 4 seconds
  • TC is off and will stay off, VSC is in "VSC OFF" mode (will still intervene at extremes)
Other
  • LSD -- Limited Slip Differential
  • EBD -- Electronic Brake Distribution
  • DBW -- Drive By Wire Throttle
  • EPS -- Electronic Power Steering
  • ABS -- Anti-lock Braking System
  • rear-wheel drive / 50/50 weight / low center of gravity
Snow
  • gears 2-6 only (no 1st gear)
  • softens throttle application / shifts
  • upshifts earlier / allows low RPMs / high gears / doesn't downshift as early
  • doesn't affect TC / VSC but sort of has a built in TC
Normal
  • all six gears
  • normal throttle / normal shifts / normal shift programming
Sport
  • to activate, must be in "D" mode (after activating, can switch to "M")
  • all six gears
  • normal throttle / more aggressive shifts / holds gears longer / downshifts earlier
All Nine Modes
  • D + Snow
  • D + Snow + Temporary Manual
  • D
  • D + Temporary Manual
  • D + Sport
  • D + Sport + Temporary Manual
  • M + Snow
  • M
  • M + Sport (must start out in "D" mode first)
Other
  • Idle mode -- first 30 seconds after turning on, wait for 1000 RPMs
  • AI Shift -- learns your shift patterns, only while in "D" mode
  • Cruise Control -- deactivates Sport
  • Air Conditioner -- button can be deactivated to leverage full HP
  • Sport mode -- can only be activated while in D mode
  • Rev matching -- on downshifts
Nepenthe is offline   Reply With Quote
Old 08-02-2012, 01:32 AM   #8
mashal
DADA
mashal's Avatar
Drives: 2013
Wow with all the book talk, let me make it simple
VSC , when you push that off it basically doesn't do much, it takes off the traction a bit and the stability won't be there to aid you and straighten out the car
Traction off is the same as VSC without turning of the stability/skid control , it just turns off traction , you still have the stability and skid control
Snow mode starts you off in 2nd gear, this is to prevent peels out in slippery conditions .. Hence the low torque in 2nd gear start
If you want full control and think you can handle this car at its full potential , hold down the traction button for 5 seconds , you have now turned off any aids the computer has to offer to you in handling the car.
mashal is offline   Reply With Quote
Old 08-02-2012, 03:06 AM   #9
D1cker
Drives: B9 S4/ND2
Nepenthe, so you're saying we can't fully turn the VSC off? I've been holding it down, but it still kicks in and it's a pain in my ass when I'm trying to get rowdy.
D1cker is offline   Reply With Quote
Old 08-02-2012, 03:14 AM   #10
eriktherod
You must be trying to get pretttty rowdy! I keep mine at the default setting and I still manage to break her loose from time to time, even for just a moment.
Old 08-02-2012, 06:58 AM   #11
dori.
Señor Member
dori.'s Avatar
Drives: white BRZ 6MT
You can pull a fuse to disable VSC/TC entirely but I think it also turns off ABS...
dori. is offline   Reply With Quote
Old 08-02-2012, 07:36 AM   #12
Nepenthe
Correct, short of pulling the fuse as mentioned, my understanding is that even if you hold the OFF button for four seconds while completely stopped, turning "off" both VSC and TC, that the VSC will still intervene at some point.
Autolock When Driving Bonburner Electronics | Audio | NAV | Infotainment 30 01-11-2014 11:21 AM
Driving Heaven Killerbee Off-Topic Lounge [WARNING: NO POLITICS] 22 01-10-2013 02:56 AM
Driving Shoes ZetaVI Other Vehicles & General Automotive Discussions 77 09-13-2012 01:42 AM
Driving too much! F3dzo Scion FR-S / Toyota 86 GT86 General Forum 15 07-15-2012 01:14 AM
Scion's Explanation of BRZ FR-S Limited Slip Differential stalon320 Engine, Exhaust, Transmission 5 06-22-2012 11:26 AM
