Old 09-03-2021, 10:33 PM   #1
Phantom86
Phantom86's Avatar
Drives: Black Scion FRS (2016)
In need of electrical wisdom.
Hey guys! I have a 2016 scion FRS, I recently purchased some Vland headlights for it. I figured out the main bulb and turn signals. However, I was on my path to figure out the DRL’s but I tapped something it made a click and now I don’t have headlights nor taillights. The dash stays lit with the high beam “logo” when the car is completely shut off and locked with everything off. I’m a little nervous because electrical isn’t my strong suit and it is my daily driver for now. Any input would be great.
Phantom86 is offline   Reply With Quote
Old 09-03-2021, 10:59 PM   #2
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
Sounds like you blew a fuse.
My pubes are shaped like the number 86. There for I’m car. Derp
Count to muffens and call again.
I’m 40. So....... say hi to your sisters or daughters.
FR-S2GT86 is offline   Reply With Quote
Old 09-03-2021, 11:03 PM   #3
Ashikabi
Ashikabi's Avatar
That wouldn't cause the high beam light to be on while the key is off
Sent from my ONEPLUS A5010 using Tapatalk
Old 09-03-2021, 11:10 PM   #4
Wally86
Be Kind
Wally86's Avatar
Drives: 2020 86
The "click" might have been a fuse popping so I'd check those but only after you disconnect the headlights and sort your wiring issue.
The "GT" pic below should be FRS and the pic below that is the 86/BRZ.
Hopefully that helps!
[Insert clever signature here]
IG | WhiskyBlog | Photography
Wally86 is offline   Reply With Quote
Old 09-03-2021, 11:25 PM   #5
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
Ooh, yeah I overlooked that detail. However, he still could have blown a fuse which could explain the click noise and no headlights/taillights. The brights icon staying illuminated on the instrument cluster with everything else off could possibly indicate electrical damage.
Old 09-03-2021, 11:51 PM   #6
Ashikabi
Ashikabi's Avatar
Indeed
Old 09-04-2021, 12:28 PM   #7
Phantom86
Phantom86's Avatar
I have noticed that FRS’s are very electrically sensitive.. electrical damage seems next level. What would you think electrical damage means in this situation?
Old 09-04-2021, 02:32 PM   #8
soundman98
ProCrastinationConsultant
soundman98's Avatar
can't really know without knowing which wires were crossed, and what they connect to.
could be just a fuse, could be the entire wiring harness, could be the BCM. or could be all, or none of those things.
Old 09-04-2021, 02:52 PM   #9
LimitedSlip
Senior Citizen Member
LimitedSlip's Avatar
Drives: Then-1977 Celica GT Now-2017 860SE
A couple of thoughts:
Originally Posted by Phantom86 View Post
I have noticed that FRS’s are very electrically sensitive. . .
One might make that observation about any vehicle that is modified as frequently and extensively as the twins.
I’m a little nervous because electrical isn’t my strong suit. . .
This may be the case in many situations (not only automotive) that leads to "electrical sensitivity".
Just sayin' . . .
LimitedSlip is offline   Reply With Quote
Old 09-04-2021, 04:26 PM   #10
Phantom86
Phantom86's Avatar
High beam module?
Hey guys, my friend and I are still diagnosing electrical work. We are leaning towards a high beam module that leads into underneath the steering wheel. Has anyone ever heard of that? Or at least some sort of wire or device that controls when the high beams are activating.
In need of Wisdom Akatzu Scion FR-S / Toyota 86 GT86 General Forum 26 09-08-2021 09:06 PM
Words of Wisdom FR-S2GT86 Off-Topic Lounge [WARNING: NO POLITICS] 169 08-02-2021 06:11 AM
Words of Wisdom........? White64Goat Other Vehicles & General Automotive Discussions 2 08-13-2016 12:31 AM
Perrin cold air intake details! Words of wisdom? Engdrew Scion FR-S / Toyota 86 GT86 General Forum 28 03-26-2015 03:39 PM
With Age Comes Wisdom... Clembo Off-Topic Lounge [WARNING: NO POLITICS] 8 07-31-2013 05:08 PM
