Old 03-25-2015, 11:41 PM   #1
Engdrew
Drives: 013 ft86
Perrin cold air intake details! Words of wisdom?
Hey all!
I just got my Perrin cold air intake today in the mail and decided to get it into my car right when I got home. I assembled it just right and looks nice.
My concerns are whether I need a tune, seeing as though they "claim" it does not need one. And if so, where should I look? No CELs or anything. I got to play around with it a little today and it almost seems as though I've lost some power when I punch it. Reasonings? Or am I just being anal? (I previously had just stock intake).
Appreciate the feedback guys
Engdrew is offline   Reply With Quote
Old 03-25-2015, 11:45 PM   #2
Lonewolf
Lonewolf's Avatar
Drives: Moped
After you've checked for leaks...disconnect the negative battery terminal for 30 minutes. Reconnect the battery then drive around like a bat out of hell.
The car will then relearn aif/fuel trims for the next 50 miles or so...then you should feel the difference.
The Following 4 Users Say Thank You to Lonewolf For This Useful Post:
Engdrew (03-25-2015), Jrryjms07 (03-26-2015), Tcoat (03-26-2015), Teseo (03-26-2015)
Old 03-26-2015, 03:49 AM   #3
Engdrew
Drives: 013 ft86
The problem I also have is that there is non of that growl sound? It's as if I didn't even install anything lol... Is that the inlet housing that makes the mean deep growl? I was positive that the CAI did that? I have no sound output either.
Old 03-26-2015, 03:56 AM   #4
Engdrew
Drives: 013 ft86
Power* output
Old 03-26-2015, 05:34 AM   #5
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
You should drive with steady throttle if the car is learning fuel trims.
Unless you mean just go for a long drive when you said "like a bat out of hell".
Old 03-26-2015, 06:04 AM   #6
headlikeahole
headlikeahole's Avatar
Drives: Ultramarine toyobaru
Did you change or remove the sound tube? It could be that the perrin intake doesn't resonate as much as as a traditional air box. Or it could be that the airflow is smoother and does't resonate through the sound tube as well.
headlikeahole is offline   Reply With Quote
Old 03-26-2015, 08:38 AM   #7
pinski
Stole my avy from zGrinch
pinski's Avatar
Drives: 2015 Audi S3
I believe the Perrin intake deletes the sound tube.
2015 Audi /S3 | Panther Black | DSG
Gone...2014 BRZ, 2010 Lexus IS F-Sport, 2006 Mazda MX5, 1997 Mustang GT
pinski is offline   Reply With Quote
Old 03-26-2015, 09:02 AM   #8
Calavera
Calavera's Avatar
Drives: Scion FR-S Whiteout
You can keep the stock inlet and sound tube with it.
If my calculations are correct, when this baby hits 88 miles per hour... you're gonna see some serious shit.
Calavera is offline   Reply With Quote
Old 03-26-2015, 09:38 AM   #9
Ridgerunr
Drives: 2015 Series Blue
Had the same issue your are having after installing my Perrin, just drive it a few days the ecu will figure it out. I drive almost 100 miles a day to and from work, it took 2 or 3 days before it felt right. Now it feels a lot better and has a nice sound when you step on it. I do not have the sound tube anymore.
Ridgerunr is offline   Reply With Quote
Old 03-26-2015, 09:49 AM   #10
Engdrew
Drives: 013 ft86
Thumbs down
I feel like that deep sound after install should be a given? And I don't have it. I understand waiting for the ECU to figure the airflow out. But that crazy growl that everyones getting from installing their Perrin CAI is M.I.A with me...
Old 03-26-2015, 09:54 AM   #11
Timmy_Jones
Spun
Drives: 23' Supra
Seems right, I wouldn't expect more than a 2-5HP gain, if that. Not something you could detect.
Timmy_Jones is offline   Reply With Quote
Old 03-26-2015, 10:49 AM   #12
headlikeahole
Not unless you buy the Perrin inlet tube to go with it. the normal perrin CAI doesnt remove the sound tube.
Old 03-26-2015, 10:56 AM   #13
Engdrew
Drives: 013 ft86
So the hollow growl that everyone is getting from the Perrin CAI is the inlet tube/housing? Or did I mess up my install?
Old 03-26-2015, 11:03 AM   #14
pinski
pinski's Avatar
Oops - I was thinking of the inlet tube. Perrin even includes a little plastic cap to cover up the hole on your firewall.
FS: TX Perrin Cold Air Intake - New Anh5oi Engine, Exhaust, Bolt-Ons 4 12-12-2014 10:45 AM
FS: Perrin 2.5" cold air intake b34ny Engine, Exhaust, Bolt-Ons 2 09-15-2014 12:56 AM
HELP! Engine Sound after Perrin Cold Air Intake OBLCDio Engine, Exhaust, Transmission 6 09-08-2014 04:57 PM
Perrin Cold Air Intake FRS_Jack Want-To-Buy Requests 0 12-16-2013 01:36 PM
Perrin cold air intake Tyson Engine, Exhaust, Transmission 5 02-15-2013 12:06 PM
