Old 09-03-2021, 10:54 AM   #1
Jstyle
Jstyle's Avatar
Drives: 2020 86
Ebrake light keeps coming on
So on my drive home from the track last night the Ebrake light came on as I was driving home, then it turned off… Then came back on. Then off. Not sure what’s going on or where to even start looking. Any help would be awesome.
Jstyle is offline   Reply With Quote
Old 09-03-2021, 11:11 AM   #2
WNDSRFR
Drives: FR-S,GTI
Check your brake fluid level. It's probably low.
The Following User Says Thank You to WNDSRFR For This Useful Post:
humfrz (09-04-2021)
Old 09-03-2021, 12:08 PM   #3
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
And once you've checked the fluid level and confirmed that it's low, check the state of your brakes ASAP because unless there's a leak, then that fluid doesn't just vanish: If the reservoir is low with no leaks in the system and no repairs on the system have been made with it going without a refill, then that means all the caliper pistons are extended to near the brake wear limit.
Old 09-03-2021, 12:15 PM   #4
Jstyle
Jstyle's Avatar
Drives: 2020 86
Checked and it’s low. Gonna check the brakes this afternoon.
Old 09-03-2021, 03:15 PM   #5
Jstyle
Jstyle's Avatar
Drives: 2020 86
So the reason it’s low is NOT because I have a leak thankfully. It’s because my pads are shot from the track and the piston is so extended. I wish I would have checked that BEFORE I topped off the fluid.
Oh well…worse problems to have. I could ran down to metal.
Old 09-03-2021, 08:59 PM   #6
RZNT4R
That picture is a wonderful example of an argument I was having previously
https://www.ft86club.com/forums/show...=146387&page=2
Old 09-03-2021, 09:01 PM   #7
soundman98
ProCrastinationConsultant
soundman98's Avatar
rule of thumb for next time. brake fluid doesn't evaporate. it's hydroscopic, meaning it absorbs water, which lowers it's boiling point, and makes for a spongy pedal.
so if it's low, either it's time to change pads, or you have a leak.
either way, it's rarely worth topping off before investigating, as if you have a leak, you'll need to purge the system anyways to correct the leak, and if the pads are low, the level will go back up when you change the pads.
humfrz (09-04-2021)
Old 09-03-2021, 09:59 PM   #8
RZNT4R
And now is a good time to mention, if you've added fluid, suction a bit of it out before pushing your pistons back in so the reservoir doesn't overflow, and once the brakes have been replaced, adjust the fluid level to the max mark, so that the level warning works properly like it just did
The Following 2 Users Say Thank You to RZNT4R For This Useful Post:
soundman98 (09-04-2021), steve99 (09-04-2021)
Old 09-04-2021, 01:36 AM   #9
What is the difference between Hydroscopic and hygroscopic?
Hydroscopic has to do with viewing objects below the surface of water, for instance by means of an instrument (a hydroscope). Hygroscopic has to do with the ability of a substance to absorb water.
Yes, it's a slow day in Puyallup -
bcj (09-04-2021), soundman98 (09-04-2021)
Old 09-04-2021, 01:40 AM   #10
soundman98
soundman98's Avatar
it all sounds the same with marbles in your mouth
humfrz (09-04-2021)
Old 09-04-2021, 01:53 AM   #11
You got a ways to go to beat out Demosthenes. You may have the pebbles to put into your mouth ...... but, you don't have the ocean to speak over the roar of.
PS - isn't it past your beddy bye time? -
Old 09-04-2021, 01:57 AM   #12
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
Leave it to the brake Nazi.
My pubes are shaped like the number 86. There for I’m car. Derp
Count to muffens and call again.
I’m 40. So....... say hi to your sisters or daughters.
FR-S2GT86 is offline   Reply With Quote
Old 09-04-2021, 02:00 AM   #13
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
Pat Cashman couldn’t have said that any better.
The Following User Says Thank You to FR-S2GT86 For This Useful Post:
humfrz (09-04-2021)
Old 09-04-2021, 02:17 AM   #14
Welp, ya got me there. What does Pat Cashman have to do with it? -
2018 BRZ Boomerang light keep on when ebrake is up? ArthurBRZ Cosmetic Modification (Interior/Exterior/Lighting) 1 01-17-2021 12:48 AM
Traction control light coming on when tires are not slipping slacker221 BRZ First-Gen (2012+) — General Topics 21 06-17-2020 08:58 AM
E-Break light coming on? MatthewFRS Issues | Warranty | Recalls / TSB 11 04-13-2017 03:28 AM
TPMS light is NOT coming on. lupindub Issues | Warranty | Recalls / TSB 9 11-19-2015 06:51 PM
Door Unlocked dash light coming and going after installing subwoofer tbertran Electronics | Audio | NAV | Infotainment 0 01-01-2014 11:22 PM
