Old 04-11-2017, 09:52 PM   #1
MatthewFRS
E-Break light coming on?
Hey guys, so I was driving earlier and I had to come to a quick stop to turn because someone was giving me bad directions, not gonna name names.... but anyway, while braking my ebrake light turned on. I've never seen it before I was just wondering if it's normal. I have an automatic 13' FRS. Thank you!
MatthewFRS is offline   Reply With Quote
Old 04-11-2017, 10:38 PM   #2
steve99
Originally Posted by MatthewFRS View Post
Hey guys, so I was driving earlier and I had to come to a quick stop to turn because someone was giving me bad directions, not gonna name names.... but anyway, while breaking my ebreak light turned on. I've never seen it before I was just wondering if it's normal. I have an automatic 13' FRS. Thank you!
Check Brake fluid level the light may be dual purpose brake fluid level and also E brake off switch.
Old 04-12-2017, 08:51 AM   #3
stevesnj
stevesnj's Avatar
What's an e-break?
My 2016 Build thread
Old 04-12-2017, 09:13 AM   #4
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
brake*
Current DD: M235i
8RZ is offline   Reply With Quote
Old 04-12-2017, 09:36 AM   #5
jasonojordan
Drives: 2013 satin white brz limited
The parking brake light comes on even when the parking brake is not applied if you are low on fluid. Start thre.
jasonojordan is offline   Reply With Quote
Old 04-12-2017, 11:13 AM   #6
humfrz
........read the whole thread before you post .......
humfrz for @Tcoat
Old 04-12-2017, 11:36 AM   #7
jasonojordan
humfrz for @Tcoat
I did but people are more then likely to try something when multiple people recommend it. Thats my experience with forums anyways.
Old 04-12-2017, 11:50 AM   #8
humfrz
Well now, that is sometimes true ....... however, @steve99 had done spoke and when folks see the "picture of the ocean" ...... they listen up and heed.
(humfrz for @Tcoat - jest ah messen wich ya - )
It's a slow day, here in Puyallup - it's spring break and all three granddaughters are here for all day ...... "one needs ah spankin, one needs ah huggen and the 9 month old needs a diaper change" ---- and ma-ma is in the shower ........
humfrz
Old 04-12-2017, 11:54 AM   #9
Icecreamtruk
Drives: Track preped NA FRS
E-brake light came on during braking for me every time my pads were worn down below 30% or so. Im willing to bet its the same for you. I've gone thru near 6 sets of front pads, light comes on every time without fail when they were down and due to replacement.
Old 04-12-2017, 02:31 PM   #10
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
First thing I'd do is to check the E to see if in fact you did break it.
Old 04-12-2017, 02:32 PM   #11
MatthewFRS
Ha..ha?
Old 04-13-2017, 02:28 AM   #12
humfrz
You must have rode the long bus and @MatthewFRS rode the short bus .....??
humfrz
How to Install 4th Break Light? F1 Style Rear Bar nova.86 Cosmetic Modification (Interior/Exterior/Lighting) 10 12-22-2017 07:08 AM
Decent 3rd break light kits? WallsAndFoundations Cosmetic Modification (Interior/Exterior/Lighting) 6 10-14-2014 05:40 PM
iJDMTOY flashing 4th break light ReaperX43 Cosmetic Modification (Interior/Exterior/Lighting) 0 09-19-2014 09:57 AM
Third break light went out.. david_gom3z Issues | Warranty | Recalls / TSB 2 01-25-2014 03:10 PM
