Old 09-01-2021, 05:02 PM   #15
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Originally Posted by Aztec View Post
To be more clear I am still on OEM sways. I just have the Perrin/Whiteline sitting in my garage staring me down.
I think I'll get them both installed using my prior thought process of keeping the stiffness proportional front and back and give it a shot. Worst case, I switch back to OEM or find a less stiff front bar and run the Perrin a bit softer.
Especially on a lift, sways can be swapped extremely easily so there is no harm in trying them out.
Thanks everyone for the quick responses
I would swap them for sure and set them on the softest setting for now if you have the time. Check your end link clearances. I would run a set of adjustable ones. I had issues with the fixed perrin rear endlinks pushing the top of the sway bar into the underside of the body when my car was lower. I run the Whiteline WHIKLC179 in the front and the WHIKLC182 in the rear.
Old 09-01-2021, 05:10 PM   #16
Aztec
Lost in the twisties
Aztec's Avatar
Drives: 2014 BRZ Dark Gray Metallic
I already have pre-shortened Whiteline front endlinks, but I don't have any rear end links currently. Once I get the car up on the lift i'll see if it becomes an issue and order some as necessary.
NEW CAR!🚨🏎️⛽
2014 BRZ: Edelbrock SC, CSG ZachTune, Jackson Radiator/Oil cooler, lightweight flywheel, CNT UEL, Berk OP/FP, Ark Grip Catback, Carbon fiber Driveshaft
Aztec's Build Thread
Aztec is offline   Reply With Quote
Old 09-01-2021, 06:05 PM   #17
ZDan
ZDan's Avatar
Drives: '23 BRZ
FWIW I'm running stock endlinks front and rear, no problemo...
Old 09-01-2021, 08:10 PM   #18
Calum
That Guy
Drives: 2013 asphalt FRS MT
Unless you're corner balanced and thus need adjustable end links to prevent preload, there really shouldn't be a reason to change them. (I'm 99.95 % sure @ZDan knows that, just adding to the conversation for others)
Sent from my Pixel 4a (5G) using Tapatalk
Old 09-06-2021, 09:50 PM   #19
Turdinator
Señor Member
Turdinator's Avatar
If you have the sways already I'd say chuck them on and see how you like it. Reading stuff online is a good knowledge base but it wont replace trying things yourself. I don't track my car but for hill climbs and spirited driving I haven't liked a stiffer rear sway. In slow tight corners it feel like it picks up an inside rear wheel.
1974 TA22 Celica
2013 86 GT
Old 09-07-2021, 01:15 PM   #20
norcalpb
norcalpb's Avatar
Never liked a stiffer rear myself. It would feel like lifting a tire as you said, but most annoyingly to me was how much the rear would step out under trail braking.
Old 09-07-2021, 02:54 PM   #21
ZDan
ZDan's Avatar
Drives: '23 BRZ
FWIW I'm running Eibach sways front and rear, front set to soft (+167%) and rear set to stiff (+153%). No probs with lifting a rear wheel or corner entry oversteer.
FS: Cusco Strut Bars and Power Braces, Hotchkis Sway bars armyoffoo Brakes, Suspension, Chassis 10 08-08-2018 08:28 AM
WTB: TRD Sway Bars bmacfrs Want-To-Buy Requests 10 04-26-2017 09:34 PM
FR-S stock sway bars compared to TRD bars babydriver Scion FR-S / Toyota 86 GT86 General Forum 3 12-01-2014 09:12 PM
brz and fr-s sway bars different? 1010110 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 08-03-2013 01:43 AM
FR-S/BRZ SWAY BARS & STRUT BARS @ NINJA AUTOSPORTS!!! NJA Brakes, Suspension, Chassis 18 04-07-2013 06:00 PM
