Old 08-02-2021, 12:24 PM   #43
M0nk3y
Originally Posted by rice_classic View Post
I'm not behind cavitation (yet).
I think obvious culprits needs to be looked at like head gasket or thermostat.
I'm racing with 6 degrees advanced over stock on 100 oct (doesn't burn as cool as E85), in a draft on a 90 degree day on an OEM radiator and temps aren't a concern.
Just pulled my data from Portland: 90 degree day, lots of time drafting, 30 minute sprint race. Never saw a water temp above 210.2F on the hottest lap. Oil peaked at 244.4 on that lap as well with center mounted greddy oil cooler. This was with 0w-40 oil.
Another data point. Out of all of the open lapping I've done, I haven't reached beyond 205F with a center mount oil cooler (in my car Perrin).
I've seen steady state around 199-201 which a couple peaks and dips along the way. Oil temp is sub 230F even on hot and humid days
Kyle H. - #89 STX
Old 08-02-2021, 02:04 PM   #44
CSG Mike
CSG Mike's Avatar
Yeah, my monkey brain was stuck in "what else" mode and not "what if" mode. I know boosted guys running stock cooling setups with no issues so it kind of left me going WTF and figured I would ask the hive mind. Took the car out for a drive. Still no oil in the coolant or vise versa. On the street water temps sit in the 160's even on a 90F ambient day as long as I am moving. Pretty sure now the thermostat is not opening up all the way when hot. It should be here this week.
Boosted cars running stock rads without issue are the exception, not the norm. Either there is extensive supporting mods, or the driver is not as experienced, perhaps both.
In the case of my car, while I'm on a stock radiator, I have every other supporting modification known to man, including a fully ducted cooling stack and a divorced oil cooler.
I do eventually overheat; my threshold is between 107F and 115F. Under 107F, I don't overheat at all, over 115F, I overheat for sure. I don't know exactly what the threshold is, because I haven't run any track days with a temp between 107F and 115F to find out.
At 107F, I don't overheat with the heater off; at 115F I overheat, even with the heater going full blast.
The above data is at my high boost setting (~360whp).
Old 08-04-2021, 09:48 AM   #45
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
Sounds like it's stuck
Sounds like Schrodinger's thermostat: It's neither closed nor open.
Old 08-21-2021, 11:48 AM   #46
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Thermostat change yielded no improvement. 70-75f ambient. Still hitting 235 in a 25 min session. Water pump is next. I am also going to test and verify my sensors with a thermocouple.
Old 08-21-2021, 02:25 PM   #47
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Bad temp sensor
Old 08-21-2021, 03:16 PM   #48
Bad temp sensor
Had the same with my Eclipse! Ran like shit until I figured it out. Well done!
Old 08-21-2021, 10:05 PM   #49
blsfrs
blsfrs's Avatar
What sensor?
Bad temp sensor
Was it the oem to the dash gauge or aftermarket to oil or coolant gauge?
Old 08-21-2021, 10:07 PM   #50
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Aftermarket coolant gauge.
Old 08-31-2021, 06:25 PM   #51
Aztec
Lost in the twisties
Aztec's Avatar
Drives: 2014 BRZ Dark Gray Metallic
Glad you got it figured out!
Going off your thread title, I want to chime in on my setup.
I'm curious how my Edelbrock performs on the track with heat management. I have the Jackson Racing Rad/OC combo unit along with hood vents.
I do feel like the system can get heat soaked, and i'm curious what else I can do to mitigate that. Again, the heat soaking is fairly anecdotal as I am not currently datalogging while it is happening. (only had the new BRZ for 4 weeks)
That said, I have some track days/hillclimbs coming up in September so I want to get ahead of any heat issues. Picked up an OBDLink MX+ Bluetooth unit that will help monitor temps.
NEW CAR!🚨🏎️⛽
2014 BRZ: Edelbrock SC, CSG ZachTune, Jackson Radiator/Oil cooler, lightweight flywheel, CNT UEL, Berk OP/FP, Ark Grip Catback, Carbon fiber Driveshaft
Aztec's Build Thread
Aztec is offline   Reply With Quote
Old 08-31-2021, 07:05 PM   #52
CSG Mike
CSG Mike's Avatar
AIM Solo 2 DL.
You can show coolant, oil, and intake temps simultaneously, as well as more track data if you want.
You can also do the same with Ecutek Connect, and any old phone you have, and a phone mount.
More powerful fans and a good fan shroud can help.
Old 08-31-2021, 07:39 PM   #53
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I'd just monitor it on your first time out and see what it does. What app are you using to track it?
Old 09-01-2021, 12:49 AM   #54
Aztec
Aztec's Avatar
OBDLink for diagnostics, Dash Command for live data, Racechrono for track telemetry. Considering an external GPS because ORP doesn't have the best GPS signal using just a phone.
I also just picked up a dji action cam for in-car POV
NEW CAR!🚨🏎️⛽
Old 09-01-2021, 01:44 PM   #55
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I also just picked up a diji action cam for in-car POV
I am using the XGPS160. That is what the holder on my dash is for.
Maybe @timurrrr can comment it, but I thought you could show OBD data on racechrono. It will log the data, I haven't messed with it a bunch yet as far is getting the displays setup.
Engine Management Q2 Forced Induction 9 12-04-2017 05:37 PM
heat management, CF hood alternative Reaper Forced Induction 70 07-05-2017 01:22 AM
Rotrex vs Turbo (AVO) for Track use (transient response, IATs, heat management, etc) glamcem Forced Induction 56 08-25-2014 06:07 PM
Top half car covers for cabin heat management on track dp1 Scion FR-S / Toyota 86 GT86 General Forum 2 06-26-2014 11:08 AM
Avo turbo heat management on track ICantAffordAnLFA Forced Induction 18 09-09-2013 11:00 AM
