#99 | |||
Drives: '23 BRZ
Pretty likely that Subaru and/or Toyota have repeatedly tested this engine to redline (oil temp goes up with revs) with factory fill 0w20. Still, for repeated track usage, with oil temps at 270-275F, IMO it's a good idea to run 30 weight at least. The manual even mentions running higher viscosity for sustained high temperature environment and/or usage. Again, viscosity of 5w30 at 275F is about the same as 0w20 at 250F. Quote:
For track-dedicated cars that see much longer stints (full races or endurance), yeah, you might want to run a cooler, if just for some additional margin so you can tolerate more and not have to back off in a race, particularly if being in traffic affects cooling airflow. My car is my daily-driver and sees usage in sub-freezing winter months. Even with a thermostat, these cars with aftermarket added-on oil coolers likely won't get oil up to temp ever for those months. Not good... And for me, on track I'm never in a lot of traffic (if I find myself in a "train" it's no biggie to just pull in and drive down pit road), my oil temp never tries to "run away" on me during the stints I run. For *me*, the more conservative approach is to just run 5w30 at ~272F and not worry about running an oil cooler. |
#100 | |
CASC-OR T.A. Director
Drives: '13 Prius, '22 BRZ
Want the best quality track times for new personal bests? Come on out to Ontario Time Attack!!!
OTA LIVE TIMING LINK |
#101 |
Drives: Crapcan
Reading this thread reminds me I really need to get my test setup working and logging correctly.
#102 | |
Not horsepower but it can lead to it!
#103 |
Drives: Crapcan
If I can get the damn thing logging and communicating correctly it would answer a lot of questions.
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | ZDan (08-31-2021) |
#104 |
Drives: Supra MKV, FR-S
I just want to point out Toyota factory backed 86 Cup racecar suggests to use 10w60 oil with oil cooler. I bet they know what they are doing. I won't 10w60 since I still drive my car on the street occasionally, 10w60 would require a lot of time for warming up. But it also means Toyota racing engineers know 0w20 is not suitable for long time racing and oil temperature will be an issue.
For me, I prefer to set up my car with more margins. The oil can definitely withstand over 270F without disintegration, but making the engine running under normal temperature will likely to reduce the chance of breaking it. An used FA20 engine costs a lot nowadays due to the stupid valve spring recall. I run Jackracing's dual radiator/oil cooler to increase cooling capacity of both oil and engine coolant and it can keep the oil temperature below 240F under 110F ambient temperature when driving hard on track for 30mins. Is that good enough? I don't know. But without the oil cooler, the oil temperature will probably reach 270F and engine will start to cut timing (which is also bad for lap times). There have been a lot of 86 race cars have spun rod bearing issues in racing applications due to oil starvation if you search the ft86 forum. In my local area, one of the 86drive challenge racers's recently has engine replaced due to spun rod bearing in cylinder 3. The car did have oil cooler and running 5w30 oil. But it's a 2013 model with valve spring recall so it might be related to the poor recall work. The car logged over 40 track days after the recall. This type of issues are so common on ft86 cars. If lowering the oil temperature and increase oil weight a bit can help lower the chance of engine breakages, I guess you should do it. |
#105 |
Drives: '22 BRZ
I'm just... not going to bother.
#106 |
Drives: '23 BRZ Limited
#107 |
Setrab publishes this data for their oil coolers online. It’s pretty easy to find. It’s not an industry secret or anything.
2022 BRZ Build 2013 FR-S Build |
#108 | |
Drives: '12 C63 P31, '23 GRC
Past: (2) 2000 MR2 Spyder, 2017 GTI Sport, 2006 Porsche Cayman S, Supercharged 2013 BRZ-L, 2007 Honda S2000, 1992 Integra GS-R |
#109 | ||
Drives: 2022 GR86
I didn't notice much change in how quickly the oil warms up at ~0ºC temperatures after installing an oil cooler with a thermostat (Jackson Racing Dual Oil Cooler / Radiator). Have you tried using thinner oils for winter? 0w-20 or 0w-30? |
#110 | ||||
Drives: '23 BRZ
For me, with 90%/10% street/track, and track sessions usually ~15 minutes, I run 5w30, might consider 5w40 next year (just ordered Redline 5w30 which will cover me for last couple of track events this year). Quote:
#111 | |
Drives: '23 BRZ
I've seen more than one thread about oil with an oil cooler and thermostat never getting up to temp. Also that one Savagegoose guy, he went to trouble to install a cooler, then his oil wouldn't heat up enough in winter so he removed it, and after he reinstalled it started leaking... I believe most setups ensure there's always *some* flow through the cooler even with thermostat closed so the oil in there gets cycled around and heated up regularly. |
#112 | |
Drives: 2022 GR86
| Water Temp problem | dejxx | Forced Induction | 10 | 07-29-2015 02:26 AM |
| FS: BNIB Prosport Guages (Water Temp / Exhaust Gas Temp) | AtlasMick | Interior Parts (Incl. Lighting) | 2 | 03-31-2015 05:47 PM |
| STRI DSD SLM II Gauges (boost/oil temp/oil press/water temp/egt) BNIB | ziptiedae86 | Interior Parts (Incl. Lighting) | 0 | 10-29-2013 11:50 PM |
