Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 08-31-2021, 12:55 PM   #85
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
They added speaker, wiring and control module weight then add extra engineering expenses.
To make the car sound zoomy inside? Take off eh?
Old 08-31-2021, 12:59 PM   #86
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
NA first drive days for BRZ? This week?
I wonder if you can wire a pot on the ground wire of the speaker and use it as a volume knob.
Old 08-31-2021, 01:21 PM   #87
AnalogMan
AnalogMan's Avatar
Drives: 2019 BRZ Limited 6 speed Red
Is there a separate, dedicated speaker for the ‘engine sound’? I would assume it’s just piped in through the regular audio speakers, as I think it is on BMW’s.
A separate speaker would take only seconds to unplug. But piped into the audio system would take hacking (unless Subaru already enables turning it off).
AnalogMan is offline   Reply With Quote
Old 08-31-2021, 01:28 PM   #88
trippinbillies40
trippinbillies40's Avatar
Drives: '22 WRB
It is but it's behind the dash, so just really depends on how easy the wire is to get to.
trippinbillies40 is offline   Reply With Quote
The Following 3 Users Say Thank You to trippinbillies40 For This Useful Post:
AnalogMan (08-31-2021), timurrrr (08-31-2021), Yoshoobaroo (08-31-2021)
Old 08-31-2021, 02:18 PM   #89
Frost
CASC-OR T.A. Director
Frost's Avatar
Drives: '13 Prius, '22 BRZ
Originally Posted by trippinbillies40 View Post
I think you're making a lot of assumptions based on people that don't drive well. I've seen plenty of people drive loose cars into massive understeer. Also, you seem to contradict yourself. You say the GR86 is better for competition because of the oversteer, but then say you need to get an alignment to dial out some of the oversteer?
Well, there was more than one reviewer who outright said they weren't into the "dark arts of oversteer" and the roster of the journalists they brought seem to be far more tame in terms of describing the event.
You definitely can drive a loose car into understeer: just crank the steering suddenly and too much. No arguments there.
What my point is that Subaru seems to have gone the original BRZ vs FRS route and made the BRZ much less livelier with OEM equipment that I would otherwise have to change out.
Regardless of whether I buy a BRZ or GR86, I would do an alignment to maximize cornering speeds but if the BRZ limits my entry to understeer, I'll pick the GR86 for oversteer on entry and correct with contact patch management. If I buy a BRZ with that set up, I have to change the parts it came with (front and rear sway bar) which I get penalized for in Ontario Time Attack (as a modification).
GR86? Just the basic alignment which the BRZ would have gotten anyways.
Hope that clarifies that point.
Want the best quality track times for new personal bests? Come on out to Ontario Time Attack!!!
OTA LIVE TIMING LINK
Frost is offline   Reply With Quote
The Following User Says Thank You to Frost For This Useful Post:
DAEMANO (08-31-2021)
Old 08-31-2021, 02:56 PM   #90
bcj
Geo Tyrebighter Esq
bcj's Avatar
Yes. They seemed abnormally proud of it for some reason or other.
The Following 2 Users Say Thank You to bcj For This Useful Post:
AnalogMan (08-31-2021), WolfpackS2k (08-31-2021)
Old 08-31-2021, 03:11 PM   #91
SockMonkey
Drives: '13 BRZ Limited
Originally Posted by Blighty View Post
Remember, lotus, who are completely anal about weight reduction, have kept a heavy iron wheel knuckle across the elise, exige, evora... They believe in it, even though thing like the last evora is fully aluminium and composite materials - except the wheel knuck.
So I think there is something to consider about selecting older tech for specific reasons.
I've seen this brought up before but never justified beyond "But lotus does it". I'm not saying there isn't a benefit, but I can't think of one. What possible benefit does added, unnecessary un-sprung weight possibly have? People go to great lengths such as lighter rotors, calipers, and forged wheels to lower the un-sprung weight. So that can't possibly be the answer. And aluminum knuckles aren't known to fail. The only logical explanation is they wanted to save some $. I'm not saying that is wrong or bad, but they shouldn't pass it off like that wasn't the intention all along.
Unless I'm wrong and someone can give me a different explanation..
SockMonkey is offline   Reply With Quote
Old 08-31-2021, 03:31 PM   #92
DarkSunrise
DarkSunrise's Avatar
Probably that iron is a harder metal than aluminum. Theoretically, less deformation at the knuckle would equate to better steering feel and less loss of camber when cornering. That said, I’m also curious to hear more (and see empirical data if available) to see how much of a difference it really makes because a reduction in unsprung mass by switching to aluminum is really tempting.
2022 BRZ Build
2013 FR-S Build
The Following User Says Thank You to DarkSunrise For This Useful Post:
Blighty (09-01-2021)
Old 08-31-2021, 03:39 PM   #93
Yoshoobaroo
TRACKBREAD
I’d buy that if every single one of the links are connected by spherical bearings and there’s not a single bushing between the knuckles and the steering wheel. The stiffness of any metal knuckle is orders of magnitude higher than the bushings used in the suspension.
The Following 5 Users Say Thank You to Yoshoobaroo For This Useful Post:
Blighty (09-01-2021), Simmons (08-31-2021), SockMonkey (08-31-2021), timurrrr (08-31-2021), trippinbillies40 (08-31-2021)
Old 08-31-2021, 03:43 PM   #94
DarkSunrise
Yeah that’s a good point.
2022 BRZ Build
2013 FR-S Build
Old 08-31-2021, 03:48 PM   #95
SockMonkey
Exactly.. And if the knuckle was deforming enough to change steering feel, it's deforming enough to fatigue and would fail.
The Following User Says Thank You to SockMonkey For This Useful Post:
Old 08-31-2021, 04:21 PM   #96
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Is swapping sway bars between same-platform cars allowed in OTA?
Are front camber bolts allowed?
My intuition is that BRZ will be pretty neutral with some front camber, whereas the GR 86 will become too tail happy.
By "alignment to reduce oversteer", I presume you primarily mean toe?
Old 08-31-2021, 04:25 PM   #97
Stonehorsw
Stonehorsw's Avatar
Drives: 18 Brz (Sold) / 22 BRZ
Not a correct assumption.
Stonehorsw is offline   Reply With Quote
Old 08-31-2021, 05:06 PM   #98
SockMonkey
Are we talking in an actual race car or a cheap econobox someone might throw around an autox course with coil overs? Cuz I'm pretty sure in the later, it's a correct assumption, specially considering what Yoshoobaroo pointed out.
NA first drive days for GR86 first week of August Sport-Tech GR86 General Topics (2nd Gen 2022+ Toyota 86) 186 10-04-2021 05:53 PM
Wheels and tires Sale of The Week! Different wheels every 7 days! Corner3garage Wheels and Tires 77 05-07-2015 05:47 PM
Really Terrible week so far after turning 21 4 days ago :( KamakazeProject Scion FR-S / Toyota 86 GT86 General Forum 54 11-15-2013 09:59 PM
1 month, 20 days, and 1 week later... Plxdjake89 Scion FR-S / Toyota 86 GT86 General Forum 36 07-31-2012 06:07 AM
volkswagen power days monza -- test drive golf gti -- lancie Other Vehicles & General Automotive Discussions 0 06-21-2011 08:06 AM
