#85 |
Geo Tyrebighter Esq
Drives: '13 scion fr-s
They added speaker, wiring and control module weight then add extra engineering expenses.
To make the car sound zoomy inside? Take off eh?
"I gotta rock." -- Charley Brown |
#86 |
TRACKBREAD
NA first drive days for BRZ? This week?
I wonder if you can wire a pot on the ground wire of the speaker and use it as a volume knob.
#87 |
Drives: 2019 BRZ Limited 6 speed Red
Is there a separate, dedicated speaker for the ‘engine sound’? I would assume it’s just piped in through the regular audio speakers, as I think it is on BMW’s.
A separate speaker would take only seconds to unplug. But piped into the audio system would take hacking (unless Subaru already enables turning it off). |
#88 | |
Drives: '22 WRB
| The Following 3 Users Say Thank You to trippinbillies40 For This Useful Post: |
#89 | |
CASC-OR T.A. Director
Drives: '13 Prius, '22 BRZ
You definitely can drive a loose car into understeer: just crank the steering suddenly and too much. No arguments there. What my point is that Subaru seems to have gone the original BRZ vs FRS route and made the BRZ much less livelier with OEM equipment that I would otherwise have to change out. Regardless of whether I buy a BRZ or GR86, I would do an alignment to maximize cornering speeds but if the BRZ limits my entry to understeer, I'll pick the GR86 for oversteer on entry and correct with contact patch management. If I buy a BRZ with that set up, I have to change the parts it came with (front and rear sway bar) which I get penalized for in Ontario Time Attack (as a modification). GR86? Just the basic alignment which the BRZ would have gotten anyways. Hope that clarifies that point.
Want the best quality track times for new personal bests? Come on out to Ontario Time Attack!!!
OTA LIVE TIMING LINK |
| The Following User Says Thank You to Frost For This Useful Post: | DAEMANO (08-31-2021) |
#90 |
Geo Tyrebighter Esq
Yes. They seemed abnormally proud of it for some reason or other.
| The Following 2 Users Say Thank You to bcj For This Useful Post: | AnalogMan (08-31-2021), WolfpackS2k (08-31-2021) |
#91 | |
Drives: '13 BRZ Limited
Unless I'm wrong and someone can give me a different explanation.. |
#92 | |
2022 BRZ Build 2013 FR-S Build |
| The Following User Says Thank You to DarkSunrise For This Useful Post: | Blighty (08-31-2021) |
#93 | |
TRACKBREAD
I’d buy that if every single one of the links are connected by spherical bearings and there’s not a single bushing between the knuckles and the steering wheel. The stiffness of any metal knuckle is orders of magnitude higher than the bushings used in the suspension. |
| The Following 5 Users Say Thank You to Yoshoobaroo For This Useful Post: | Blighty (08-31-2021), Simmons (08-31-2021), SockMonkey (08-31-2021), timurrrr (08-31-2021), trippinbillies40 (08-31-2021) |
#94 | |
| The Following User Says Thank You to DarkSunrise For This Useful Post: | Yoshoobaroo (08-31-2021) |
#95 | |
| The Following User Says Thank You to SockMonkey For This Useful Post: | Yoshoobaroo (08-31-2021) |
#96 | |
Drives: 2022 GR86
Are front camber bolts allowed? My intuition is that BRZ will be pretty neutral with some front camber, whereas the GR 86 will become too tail happy. By "alignment to reduce oversteer", I presume you primarily mean toe? |
#97 |
Drives: 18 Brz (Sold) / 22 BRZ / 13 BRZ
#98 |
| NA first drive days for GR86 first week of August | Sport-Tech | GR86 General Topics (2nd Gen 2022+ Toyota 86) | 186 | 10-04-2021 04:53 PM |
| Wheels and tires Sale of The Week! Different wheels every 7 days! | Corner3garage | Wheels and Tires | 77 | 05-07-2015 04:47 PM |
| Really Terrible week so far after turning 21 4 days ago :( | KamakazeProject | Scion FR-S / Toyota 86 GT86 General Forum | 54 | 11-15-2013 08:59 PM |
| 1 month, 20 days, and 1 week later... | Plxdjake89 | Scion FR-S / Toyota 86 GT86 General Forum | 36 | 07-31-2012 05:07 AM |
| volkswagen power days monza -- test drive golf gti -- | lancie | Other Vehicles & General Automotive Discussions | 0 | 06-21-2011 07:06 AM |
