Old 08-18-2021, 10:03 AM   #15
Trueweltall
Trueweltall's Avatar
Drives: 2016 Subaru BRZ
Hey OP, if you do install the KillerB pickup and you don't want to worry about RTV killing your engine check out "Permatex 51813 Anaerobic Gasket Maker", it'll stay liquid and not clog your oil passages. I've used it so seal up a motorcycle case and valve cover, great stuff. I can't understand why anyone would use regular RTV for this application.
Trueweltall is offline   Reply With Quote
The Following 3 Users Say Thank You to Trueweltall For This Useful Post:
FrickingReallySlow (08-18-2021), Jdmjunkie (08-18-2021), jeepmor (08-19-2021)
Old 08-18-2021, 01:22 PM   #16
FrickingReallySlow
Drives: 2015 FR-S
Awesome thanks for the tip! Haven't done it yet currently scheduled for 30th at the shop. When you say it'll stay liquid isn't that bad also for possible oil leaks? or you're saying before it cures its very liquid
FrickingReallySlow is offline   Reply With Quote
Old 08-19-2021, 09:09 AM   #17
Trueweltall
It only cures due to a lack of oxygen, for example between the two mating surfaces where you want it. It cures solid just like RTV except whatever squeezes out into your oil pan won't, it'll just cycle through with your oil until your next change. Whereas if you used RTV the excess would cure inside your oil pan and block your pickup or worse.
AT-JeffT (08-19-2021), FrickingReallySlow (08-19-2021), jeepmor (08-19-2021)
Old 08-30-2021, 03:10 PM   #18
FrickingReallySlow
Drives: 2015 FR-S
Dropped the pan today. TDLR: "3.6 Roentgen, not great not terrible"
It looks like a previous owner dropped the pan before me and resealed it and looking at the oil pickup pictures, maybe ~15%? of the screen was blocked by some small sealant. Oil pan looks really clean though. KillerB installed.
I also always prime my oil pump for 5 secs before starting in the morning and stay <5K rpm, I'd like to think that may have offset any damage. I don't care about my $50 starter
Do your Job KillerB!
The Following User Says Thank You to FrickingReallySlow For This Useful Post:
bcj (08-30-2021)
Old 08-30-2021, 10:15 PM   #19
soundman98
ProCrastinationConsultant
soundman98's Avatar
how do you prime the oil pump? fuel cut switch?
Old 08-31-2021, 12:32 AM   #20
FrickingReallySlow
Drives: 2015 FR-S
Simple hold down the throttle during ignition. Also comes in handy if you’re ever at risk of hydrolock
soundman98 (08-31-2021)
Old 08-31-2021, 12:45 AM   #21
villainous_frx
Off to the track!
villainous_frx's Avatar
Drives: '14 Lava 86, '13 WRB BRZ
Thanks that's a good observation! The pieces are all super thin and look like flakes which I was raking my mind thinking where sealant could be that thin and break off, guess my rotating parts made them that way.
Do you know what these tubes are for in the oil pan? are these gallery drains from the heads or somewhere else?
Late to the party, but I just got a fresh pan from Toyota (mine rusted through), those have a rubber gasket that you can buy as a separate part, or come with the pan if you buy a new one.
villainous_frx is offline   Reply With Quote
Old 08-31-2021, 12:22 PM   #22
FrickingReallySlow
Drives: 2015 FR-S
They are separate gaskets you have to buy
Engine failure michael_basden Member's Car Journals 5 10-06-2018 05:58 PM
Engine failure Geex Issues | Warranty | Recalls / TSB 19 07-01-2018 03:57 PM
Perrin Filter Failure tofurun Engine, Exhaust, Transmission 13 07-18-2016 10:36 PM
direct injector Failure , sand in the engine and on the engine aagun Issues | Warranty | Recalls / TSB 3 05-26-2014 02:46 AM
Will I get a check engine light on if the engine bay has a direct injection failure? Astroboy Engine, Exhaust, Transmission 7 03-29-2014 06:16 PM
