Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 08-29-2021, 10:37 AM   #71
Ohio Enthusiast
Drives: 2018 BRZ
But cars don't care about wet bulb temperature, as they don't rely on evaporative cooling (well, at least the vast majority of cars don't). Cars use simple heat exchangers and these are governed by temperature differential and medium flow rate (air in our case), regardless of humidity.
The Following 3 Users Say Thank You to Ohio Enthusiast For This Useful Post:
Blighty (08-29-2021), DocWalt (08-30-2021), timurrrr (08-29-2021)
Old 08-29-2021, 10:54 PM   #72
Blighty
Drives: WR Blue Pearl 2022 Subaru BRZ
Ahh yes - of course they dont.
Blighty is offline   Reply With Quote
Old 08-30-2021, 10:17 AM   #73
Tokay444
Originally Posted by s30series View Post
If I changed my oil every two track days I wouldn't worry about 270degree oil as well.
Some of us use the BRZ as a track car AND a daily driver and that just isn't practical. Millers Nanodrive is not cheap oil
I don't know what a "track season" is. I go every chance I can get throughout the year.
You know whats nice? Boosting the shit out of my outback over and over while laughing in the dadwagon and seeing oil temp get up to mid 230s....then lay off for a second and instantly goes back down....cause Millers isn't cheap for that sucker either
I track and daily and change my oil after every track day.
Old 08-30-2021, 10:19 AM   #74
Tokay444
Thinking an oil cooler prolongs the life of the oil in severe usage scenarios is laughable. I’d still do the oil change with or without the cooler.
The Following User Says Thank You to Tokay444 For This Useful Post:
stilesg57 (08-30-2021)
Old 08-30-2021, 10:36 AM   #75
Frost
CASC-OR T.A. Director
Frost's Avatar
Drives: '13 Prius, '22 BRZ
Yep. Abuse is still abuse. kW of heat generated is still being passed through the oil and passed out to atmo. Same path, same abuse.
Want the best quality track times for new personal bests? Come on out to Ontario Time Attack!!!
OTA LIVE TIMING LINK
Frost is offline   Reply With Quote
The Following User Says Thank You to Frost For This Useful Post:
Tokay444 (08-30-2021)
Old 08-30-2021, 02:19 PM   #76
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
That is extremely excessive.
I don't disagree with ZDan on the fact that good oil can handle heat... If you're changing oil that often just because of heat you're doing it wrong.
I tracked my GT350 a bunch and it was at ~285F all day long for 20+ minute sessions. I wasn't worried about it because it was using 5w50 oil.
Stock 0w20 isn't going to work on the twins for heavy track use.
Old 08-30-2021, 03:16 PM   #77
Tokay444
I'm NOT changing it just because of heat.
Old 08-30-2021, 03:41 PM   #78
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Well, my oil would get pretty dark after one track day without a cooler back when I was a beginner.
15+ track days of experience later, I have an oil cooler and the oil is mostly clear when I change it once every 3 track days.
The Following User Says Thank You to timurrrr For This Useful Post:
TommyW (08-30-2021)
Old 08-30-2021, 03:59 PM   #79
Tokay444
Oh yeah?
Is that supposed to be some sort of empirical data point?
Old 08-30-2021, 08:39 PM   #80
Kona61
Kona61's Avatar
Drives: ‘22 CWP
Oh yeah?
I mean, color is a data point… For example, you can clearly tell burnt ATF vs new simply by the color, or old oil vs new.
Kona61 is offline   Reply With Quote
Old 08-30-2021, 10:54 PM   #81
zeroomega
zeroomega's Avatar
Drives: Supra MKV, FR-S
I feel oil change per 3 track days is a bit too frequent. It won't do any harm but it bumps run cost and nuances a bit. I have some used oil analysis reports from Blackstone Lab after tracking 5 track days with 5w30 oil with oil cooler and I can share to you if you are interested. All the metrics from the reports were pretty good. Blackstone lab folks suggested me to run the oil a bit longer, which I did and I am waiting for my latest report from them.
zeroomega is offline   Reply With Quote
Old 08-30-2021, 11:03 PM   #82
Blighty
If you can afford it, and are happy to do it, then replacing oil after every track day would be ideal you would imagine?
The Following User Says Thank You to Blighty For This Useful Post:
Tokay444 (08-31-2021)
Old 08-30-2021, 11:11 PM   #83
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Yup, I'm aware that it's most likely too frequent.
It's just that it aligned well with my recent schedule of track days, autox'es and maintenance to do oil these changes "while at it".
I figured I'd rather do an extra change to be on the safer side.
Not scientific by any means
Old 08-30-2021, 11:21 PM   #84
TommyW
TommyW's Avatar
Drives: '13 Whiteout
But reeks of common sense.
TommyW is offline   Reply With Quote
Water Temp problem dejxx Forced Induction 10 07-29-2015 02:26 AM
FS: BNIB Prosport Guages (Water Temp / Exhaust Gas Temp) AtlasMick Interior Parts (Incl. Lighting) 2 03-31-2015 05:47 PM
STRI DSD SLM II Gauges (boost/oil temp/oil press/water temp/egt) BNIB ziptiedae86 Interior Parts (Incl. Lighting) 0 10-29-2013 11:50 PM
