Old 08-24-2021, 05:03 PM   #29
ayau
Drives: Some rust bucket
none of this matters. just an e-peen contest.
Old 08-24-2021, 05:18 PM   #30
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
To get those numbers you are banging gears and slamming the clutch as fast as possible. Definitely not good for the drivetrain, but the odd occasion probably won't do much harm.
You can see in the car and driver YouTube video of the 2017 86 getting a 6.2 second 0-60 he had to launch the car at around 4000rpm with revs going up when clutch dumping, then basically flat foot shifting and slamming the clutch between gears.
Old 08-24-2021, 09:58 PM   #31
ermax
ermax's Avatar
Originally Posted by timurrrr View Post
In my experience, the most precise way to measure a 0–60 in our cars is to
  • log the speeds from the ABS sensors of the the front wheels from the CAN bus
    (50 updates per second, 0.02s time precision)
  • find what data is coming from those ABS sensors at a constant 60 mph when driving
    in a straight line (highway?) and using an external GPS as a speedo
Using front ABS sensors instead of any data from the rear wheels eliminates wheel slip
from the calculations.
And then GPS is really good at measuring constant speed,
but really bad when measuring changing speed.
This is how I tested my 2013 MT on E85 and gutted cats. I don’t recall the exact numbers but it was right at 6s. This is also with RT615K+ tires.
Old 08-25-2021, 10:42 AM   #32
FlyingJett
Drives: Scion frs
With the new one it will be possible to do from idle.
Btw, I have seen in one video 6.9s from launch for GR86. I hope it is just very bad driver
FlyingJett is offline   Reply With Quote
Old 08-25-2021, 12:38 PM   #33
stilesg57
Drives: Shopping Mustang GTs and BRZs/86s
Redline Reviews’ on-street 0-60s were pretty slow.
Does go to show there are magazine / perfect conditions / pro drivers numbers and then what most people will actually be able to pull off in everyday conditions numbers, and those can be as much as a second apart.
This almost always favors turbos and AWD btw. That setup is a proven recipe for straight line speed with normal people and conditions. I seem to recall a C&D test about 20yrs ago where they let several members of the public drive a couple cars while they were testing a group of them and the old 227hp bugeye WRX was faster for more people than the 350hp C5 Vette was.
stilesg57 is offline   Reply With Quote
The Following User Says Thank You to stilesg57 For This Useful Post:
~el~jefe~ (08-26-2021)
Old 08-25-2021, 01:13 PM   #34
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
... as well as an automatic transmission and launch control.
An STI will probably also be a second or two slower if you launch it without a clutch dump at high-ish revs.
The Following User Says Thank You to timurrrr For This Useful Post:
stilesg57 (08-25-2021)
Old 08-29-2021, 11:37 PM   #35
mazeroni
Drives: 2013 Scion FR-S Series 10
Keep in mind it was 100 degrees at the track and they said very humid, plus the cars had been running laps all day.
So probably a fair amount of power loss from the weather and heat soak impacting performance. I know I'm not alone in finding our cars feel much punchier in cooler weather and sluggish in the summer. On a 70 degree day with dry weather 6,1 is likely easy without too aggressive a launch.
mazeroni is offline   Reply With Quote
The Following 2 Users Say Thank You to mazeroni For This Useful Post:
Dzmitry (08-31-2021), FlyingJett (08-31-2021)
Old 08-31-2021, 11:37 AM   #36
Dzmitry
Dzmitry's Avatar
Drives: 2018 Subaru BRZ Limited with PP
Yeah, being on such a light platform for the first time for me, it amazes me all the little differences I pick out. I definitely notice power changes in the following scenarios:
Temperature changes
Adding a passenger
Running A/C
Dzmitry is offline   Reply With Quote
The Following 2 Users Say Thank You to Dzmitry For This Useful Post:
Celica00 (08-31-2021), mazeroni (08-31-2021)
Old 08-31-2021, 11:59 AM   #37
Celica00
Celica00's Avatar
Drives: 86
Temperature changes
Adding a passenger
Running A/C
Yep. Wife always gives me a look when I turn off the A/C as she knows I'm about to do something stupid.
Celica00 is offline   Reply With Quote
The Following 10 Users Say Thank You to Celica00 For This Useful Post:
ACT86 (09-01-2021), daiheadjai (09-24-2021), DriveDriftDogfight86 (09-08-2021), Dzmitry (08-31-2021), FlyingJett (08-31-2021), Jianlun (09-01-2021), mazeroni (08-31-2021), stilesg57 (08-31-2021), Stonehorsw (08-31-2021), WolfpackS2k (10-18-2021)
Old 08-31-2021, 09:31 PM   #38
Lantanafrs2
Drives: 2013 frs red
He gets a 6.37 but hes not cranking on it.
Lantanafrs2 is offline   Reply With Quote
Old 09-17-2021, 08:44 PM   #39
Skunk
Drives: RSX Type-S
Oof.
As a former blobeye WRX owner (basically the same car) who has driven a C5, I can confirm that's BS lol. Not in a million years. Maybe, *maybe* like in 60ft time or something but no-way-no-how are you killing a C5 in any kind of race.
Skunk is offline   Reply With Quote
Old 09-17-2021, 08:57 PM   #40
WC-BRZ
Drives: Black BRZ
Also, doesn't help that he's a professional dork and totally dresses (and acts) like a 40 yr old virgin.
For the love of God, that thumbnail...the cringe
WC-BRZ is offline   Reply With Quote
The Following 3 Users Say Thank You to WC-BRZ For This Useful Post:
Dadhawk (09-18-2021), Lantanafrs2 (09-17-2021), s30series (09-19-2021)
Old 09-18-2021, 11:33 AM   #41
Simmons
Simmons's Avatar
Drives: 2024 GR86/ 2015 FRS
A/C doesn't run at full throttle.
2024 GR86 71 STR/ 2015 FRS 71 STX
Sponsors Xero-Limit//Karcepts
Simmons is offline   Reply With Quote
The Following User Says Thank You to Simmons For This Useful Post:
Yoshoobaroo (09-18-2021)
Old 09-18-2021, 11:34 AM   #42
Celica00
Celica00's Avatar
Drives: 86
My car didn't get that memo
The Following 3 Users Say Thank You to Celica00 For This Useful Post:
Dzmitry (09-18-2021), Sport-Tech (09-18-2021), Yoshoobaroo (09-18-2021)
PP Brembo front rotor weight, lighter-weight alternatives? ZDan Suspension | Chassis | Brakes -- Sponsored by 949 Racing 30 02-14-2022 07:03 PM
GR86 In R7 of the Toyota Gazoo Racing GT Cup + GR86 coming to Grand Turismo Sport Blighty GR86 General Topics (2nd Gen 2022+ Toyota 86) 28 07-18-2021 03:38 PM
ADVAN GT 18" Concave Face ** Actual Wheels Pics and Weight Pics RavSpec Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 11-20-2014 11:16 PM
Weight Reduction vs. Weight Distribution (for track use not for drag..etc) glamcem Tracking / Autocross / HPDE / Drifting 21 07-01-2014 11:38 AM
Actual Weight For FRS??? DanPO Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 03-22-2012 05:07 PM
