| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
#43 |
Addicted
Drives: 2013 Asphalt FR-S 6MT
Don't want to beat a dead horse but there is a lot of back and forth between threads.
Do the OEM washers, that come with car, for transmission and differential fluid need to be replaced? In other words, are they flat or crush? From what I am reading they are flat so no they don't. But a lot of people seem to be buying them?
Phantom Supercharger | Tsudo Cat-Back Exhaust | K&N Drop-in Filter | Winjet Headlights | Opti-coated | 35/20 Tint | Radar/Dashcam Hardwired | OFT tuned | OEM Audio+ Reference 400CF | Uber Sound Deadened | LED DRL strips | JPM Coachworks Kneepads
#44 |
Drives: toyota gt86 1st edition
crush
#45 |
and manual advide for changing them. but if you are in a hurry you can flip them (just one time)
#46 |
Drives: MDX, Camry
transmission washers do not need to be replaced. differential washers do. they seem to be of one-time use to me.
#47 |
Legendary Member
Drives: HyperBlue BRZ
my subaru dealer is too far, ya'll think I can order these at the toyota dealer? lol
#48 |
Drives: FR-S 10 Series
I think I got my last pair from Toyota on Amazon. Or if you want to upgrade to magnetic drain plugs from ft86speedfactory, they'll come with washers. But to answer your question, I'm sure a Toyota dealer would have them or have them ordered for you.
#49 | |
Wheels for Brains
Subaru 1215710010 Diff Drain Gasket 11126JB000 Diff Fill Gasket 17008AA050 Transmission Gaksets 803916010 Oil Drain Gasket Toyota TOY1215710010 Diff Drain Gasket SU00300122 Diff Fill Gasket SU00303626 Transmission Gaksets SU00302159 Oil Drain Gasket |
#50 | |
Drives: '14 FRS TT5
Follow my NASA TT5 build here: JHill Motorsports
#51 | |
Drives: 2017 PP BRZ
Check out this website https://parts.westcoasttoyotalb.com/...u00300122.html |
#52 |
Drives: 2016 Scion FRS Release Series 2#439
Here in the Toronto area we may as well just spend the money at the stealership. I visited at least 10 auto parts stores and found no metal "crush" washer/gaskets anywhere. Did get some 18mm fibre crush washers at PartSource in Markham eventually.
Edit: Broke down and visited Dixie Toyota in Mississauga today. Picked up two 18mm crush washers for CA$2.20 each. I should have called them first and saved much chasing around to parts stores.
#53 | |
Dumb question, but does the MT6 gearbox use the same crush washer as the AT ? 17008AA050 Last edited by daniloneil8; 08-23-2021 at 03:12 PM. |
#54 | |
It seems sizes and part numbers changed in 2017. I need 2013 MT fill and drain plug washer |
#55 |
Got the size for the motor oil drain plug crush washer
Manufactured in Japan | Specification: 16.10mm Inside Diameter X 20.52mm Outside Diameter X 2.23mm Thick OIL PAN GCA16X21A - Hollow Aluminum Crush Gasket https://www.belmetric.com/hollow-cru...et-p-8397.html TRANNY GA18X24X2.0 - Aluminum Gasket THICK https://www.belmetric.com/aluminum-g...ck-p-3051.html DIFF GCA18X24 - Copper hollow crush gasket https://www.belmetric.com/hollow-cru...et-p-6154.html Last edited by daniloneil8; 08-23-2021 at 05:08 PM. |
| The Following 2 Users Say Thank You to daniloneil8 For This Useful Post: | nomtimesthree (03-23-2024), radroach (08-24-2021) |
#56 |
I can confirm this what I use on my 2013. Order extra's so its 1 order and your done for a while.
2013 Series 10 FRS #553
| Washer Mod? | 636 | Engine, Exhaust, Transmission | 64 | 02-20-2018 04:08 PM |
| Pressure Washer $60 at super store | Aznek | CANADA | 6 | 09-10-2012 11:08 AM |
| Engine oil drain plug washer | BMWDavid | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 3 | 06-28-2012 11:28 AM |
| front washer? | Filipino Royale | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 06-21-2012 02:06 PM |
| Man Crush A Friend's Car With A 100-ft Axe | ichitaka05 | Off-Topic Lounge [WARNING: NO POLITICS] | 11 | 01-19-2012 03:31 PM |
