| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
Drives: FR-S RS 2.0
Recommendations for analog torque wrench for wheels?
Today at the HPDE event at Poconos, someone's wheel came off during the race. This scared the shit out of me and i want to carry a torque wrench with me when ever I go to a track.
Any recommendations? I am specifically looking for a decent analog for torque-ing and twerking wheels. Thanks in advance |
#2 |
Drives: 2018 BRZ
I'm pretty happy with my EPAuto click-type torque wrench from Amazon. 1/2 drive with a range of 25 to 250 ftlbs bought for around $40. I haven't verified its calibration, but it feels consistent over time and about right on the torque, so probably good enough.
I know the bar style are actually pretty accurate and cheaper, and for lug nuts they might be easy enough to read. But I can't imagine using them in a tight spot, lying on my back and working overhead. A click-type is much easier to use. |
#3 |
has a funny hat
Drives: 2014 BRZ Limited
some years back Car Craft had an article testing torque wrenches and the Harbor Freight 1/2" 20-150lb/ft clicker type was essentially as accurate as any competing mechanical torque wrench and unbeatable for the price at what I believe was ~$20 (I think it's $25 now). I've had an HF for over a decade and it's still accurate tested against my neighbor's digital wrench.
Keep in mind, all mechanical torque wrenches need the adjuster backed off after use. Leaving the spring loaded during storage will rapidly decrease the accuracy. |
| The Following 3 Users Say Thank You to pope For This Useful Post: |
#4 |
Drives: Crapcan
CDI
They are unbranded snap-on torque wrenches. About 120-150 on amazon. Sent from my iPhone using Tapatalk
#5 | |
Drives: 2013 BRZ Sport-Tech
Yes, there's 1 (or 2) numbers that the torque should be but how many times through history have people tightened up the bolts with just a tire iron and going 'good enough' and never had an issue? Realistically there's a wide range of torque values which will keep your wheels on just fine. On topic: I got one like this on sale for about $50 several years ago. https://www.canadiantire.ca/en/pdp/m...9643p.html#srp Though I see a cheaper option here which is probably equally as good https://www.princessauto.com/en/1-2-...t/PA0008533168 |
#6 |
Drives: 2016 HyperBlue
This one is very nice, and much easier to read than my HF one that I have owned for years.
TEKTON 1/2 Inch Drive Click Torque Wrench (25-250 ft.-lb.) |
| The Following 2 Users Say Thank You to nathand For This Useful Post: | MuseChaser (08-20-2021), Wally86 (08-17-2021) |
#7 | |
Be Kind
Drives: 2020 86
I have all three tektons (1/2, 3/8, 1/4) and they've done me very well. As stated above, just make sure to follow the storing instructions.
#8 |
Wheels for Brains
Whatever you do, DON'T TORQUE THE WHEELS RIGHT AFTER YOU COME OFF HOT AFTER A SESSION.
-You'll end up snapping studs. Everything expands slightly when hot and will seem like they can take some more tightening. However if you cinch them down when they're hot, they will eventually contract and have additional preload on them. This can lead to over-torquing and snapped studs Torque them when they are cooled off, or before your first session. |
| The Following 8 Users Say Thank You to EndlessAzure For This Useful Post: | churchx (08-20-2021), CrowsFeast (08-24-2021), Jdmjunkie (08-20-2021), jflogerzi (08-28-2021), NoHaveMSG (08-20-2021), Ohio Enthusiast (08-20-2021), soundman98 (08-20-2021), Wally86 (08-24-2021) |
#9 | |
Torque before your first session and them leave them alone! If for some reason you have to torque while hot (things happen), loosen them off and let the car sit while it cools down, then re-torque. |
#10 | |
Feeling like thinking....
Drive like everyone's life around you depends on it...
| The Following User Says Thank You to MuseChaser For This Useful Post: | Wally86 (08-24-2021) |
#11 | |
Drives: Crapcan
Pretty sure this is why a Zupra lost a wheel at a TT event about a month ago. He was about two turns ahead of me when it came of on a slight turn at about 115.
#12 | |
Drives: 2016 BRZ Limited
| The Following User Says Thank You to blatantanomaly For This Useful Post: | Wally86 (08-24-2021) |
#13 | |
Drives: 2016 Subaru BRZ
I use their inch pound torque wrench, no complaints! Been using it for years. My go to torque wrench is a craftsmen that I bought from sears a long, long time ago. |
#14 |
Drives: 2017 BRZ
CDI for the reason noted above.
I also have a Tekton around. Not as nice, and I'm less confident over time... But it gets the job done in a pinch.
| Recomend torque wrench | jflogerzi | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 29 | 06-08-2017 06:38 AM |
| Torque wrench necessary for putting on wheels? | redwing634 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 61 | 11-27-2016 01:59 PM |
| Calculate torque when using a crows foot on torque wrench | BirdTRD | DIY (Do-It-Yourself) Guides | 0 | 10-11-2015 04:02 PM |
| torque wrench | dcfr | CANADA | 13 | 05-15-2014 01:28 PM |
| Torque wrench... Vendors welcome | Freeman | Off-Topic Lounge [WARNING: NO POLITICS] | 8 | 01-23-2013 05:30 AM |
