Drives: Whiteout track car; lava donor
Left turns feels like rear camber is changing?
This is weird. At moderate to fast speeds turning left, mid-turn it feels like the rear wants to step out (right).
Turn in, car takes a set. Then suddenly, the rear wants to wash out. I’m getting my track alignment redone tomorrow. But I’m concerned that something is worn out, or is sticking, then breaking free (spherical joint on the racer x sway bar end links?). Does this sound familiar to anyone? Can bad toe in rear alignment cause this? It isn’t reproducible Turning right. Very high speed at the bottom Valkyrie hill at ORP counter clockwise was no problem 2 Sundays ago. |
#2 |
Drives: 2013 Blue Subaru BRZ. 6 Spd manual
Definitely sounds like a toe problem. You’re alignment guy will tell you right away. Does it behave oddly under braking vs accelerating?
| The Following User Says Thank You to BlueWhelan For This Useful Post: | Four_wheel_drifts (08-17-2021) |
#3 |
Drives: Subaru BRZ
Maybe get your ball joints checked. I had a bad one and the car would feel like the suspension geometry changed mid-corner. VSC light would activate too. We felt like it was steering from the rear and looked for issues with the rear, not the case.
The ball joint could explain the left turn only nature as well. Sent from my SM-G973F using Tapatalk |
| The Following User Says Thank You to Purist For This Useful Post: | Four_wheel_drifts (08-17-2021) |
#4 |
[QUOTE=BlueWhelan;3457386]Definitely sounds like a toe problem. You’re alignment guy will tell you right away. Does it behave oddly under braking vs accelerating?
I haven't noticed it much under braking. Accelerating, yes, as I think about it. |
#5 |
[QUOTE=Purist;3457390]Maybe get your ball joints checked. I had a bad one and the car would feel like the suspension geometry changed mid-corner. VSC light would activate too. We felt like it was steering from the rear and looked for issues with the rear, not the case.
The ball joint could explain the left turn only nature as well. Front ball joint? The behavior your describing sure sounds like it. I run with the predecessor to the trac box all the times, so my VSC light never comes on. |
#6 | |
Drives: Subaru BRZ
[QUOTE=Four_wheel_drifts;3457402]
Side point for the younger players: When your car doesn't feel right, get it checked. Could've ended very badly for me. Sent from my SM-G973F using Tapatalk |
| The Following User Says Thank You to Purist For This Useful Post: | Four_wheel_drifts (08-18-2021) |
#7 |
Purist: Side point for the younger players: When your car doesn't feel right, get it checked. Could've ended very badly for me. Totally! Turns out the 22mm nut on aftermarket rear toe link was loose. When I was under the car, I didn’t have enough leverage on my own to move the suspension. Once I got a helper to grab and shake the wheel back and forth with me under the car, it became obvious. I check many nuts and bolts back there before every track weekend, but not those. ANOTHER point on the check list. Thanks for your help, guys. P.S. I checked the front ball joints first. They are tight. |
#8 |
Drives: Subaru BRZ
Glad you got it sorted.
Because community ![]() Sent from my SM-G973F using Tapatalk |
| Traction control turns on crazy when turnin left but not right? | Nah | Issues | Warranty | Recalls / TSB | 58 | 09-13-2020 02:57 PM |
| Popping/creaking noise in hard left turns | TheLaughingMan | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 1 | 09-20-2019 05:01 PM |
| car feels funny after changing to summer tire/wheels | theman233 | Issues | Warranty | Recalls / TSB | 4 | 04-02-2017 01:48 AM |
| Humming noise on left turns. | kphan | Issues | Warranty | Recalls / TSB | 10 | 10-27-2016 11:49 AM |
| New front sway, a little unstable on left turns | loading_please_wait | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 2 | 07-20-2015 07:38 PM |
