Old 08-03-2021, 12:19 PM   #1
msaikhan
Drives: frs
Rear Diff/subrace bushing replacement
2013 frs 155k
My rear diff bushing that connects them to subframe is cracked. I dont see any writeup on replacing the bushing.
Is it doable with bushing press kit from advance auto?(without dropping the whole subframe)
or do i need to burn and cut it out etc...
Also, please give me replacement options. (currently looking at oem)
msaikhan is offline   Reply With Quote
Old 08-06-2021, 03:57 AM   #2
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
Tangentially related, but I have a pair of OEM diff bushings new in bag if you are looking to buy some.
Whiteline claims you can do them on the car with some cutting. Not sure if a press kit is sufficient: www.whiteline.com.au/docs/install_guides/Z5294.pdf
EndlessAzure is online now   Reply With Quote
Old 08-06-2021, 09:26 AM   #3
Westen86
Purist
Westen86's Avatar
Drives: 2013 FRS - Hot Lava
I went with SuperPro 80k "street" durometer full replacement bushing. I have not installed them yet.
WTB: Everything Verus
RaceComp SS-1, Complete SuperPro bushings, TR Motorsport FF10 17x9 +45, GruppeS UEL, HKS Hi-Power V2, OFT(93/E85)
Westen86 is offline   Reply With Quote
Old 08-06-2021, 01:21 PM   #4
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Air saw the outer race of the bushing till you get a slit. Hit with punch till you get a lip, then air hammer the bastard out of there.
norcalpb (08-06-2021)
Old 08-06-2021, 01:50 PM   #5
norcalpb
norcalpb's Avatar
Another option is just replace the entire rear subframe. You’ll get new subframe bushings and diff bushings with it. I would look at shipping from the wholesale sites vs picking up at a dealer. Dealer may be cheaper in this instance.
https://parts.subaru.com/p/Subaru_20...0152CA000.html
The Following 2 Users Say Thank You to norcalpb For This Useful Post:
grumpysnapper (08-06-2021), Racecomp Engineering (08-06-2021)
Old 08-14-2021, 10:35 PM   #6
jeepmor
Drives: 84 CJ7, 08 Duramax, 2014 FRS
I've been looking at this lately. I think a clawed bearing puller and the right size socket, washer or pipe bit may work to press the bushing out if you have the clearances without pulling the full assembly down. That's a press through plan.
A pipe with the right diameter and a the right sized bolts, washer and nuts would be great. Refer to Cusco's steering bushing puller. It would pull it towards the wrench instead of away. Which may be needed here for clearances. I like this plan better, but don't see a simple jig to pull it off for these bushings.
Link for jig pull through reference.
https://www.enjukuracing.com/product...All%20Products
jeepmor is offline   Reply With Quote
Old 08-15-2021, 10:19 PM   #7
Turdinator
Señor Member
Turdinator's Avatar
I have to do this on my car also. I have been putting it off as I think to do it properly I'll need to drop the diff and reseating the drive shafts is a pain in the ass. From what I have read one bush is basically a slip fit and should come out easily but the other is a tighter fit and will requite a puller or some cutting.
1974 TA22 Celica
2013 86 GT
FS: Whiteline KDT925 poly rear diff bushing inserts SOLD pslater Canada Classifieds 3 11-02-2020 02:44 PM
Which is better? Reaplcing rear diff bushings? or installing rear diff brace? Frs30 Engine, Exhaust, Transmission 22 04-13-2020 10:23 AM
FS: Whiteline Positive Shift & Perrin Rear Shifter Bushing + Whiteline Front Diff Bus neilvosko Brakes, Suspension, Chassis 1 11-21-2016 02:44 PM
AVO Rear Diff Anti-tramp Bushing Install Pix Infamous Performance DIY (Do-It-Yourself) Guides 2 09-29-2014 04:48 PM
diff bushing questions mike the snake Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 08-25-2013 05:28 PM
