Northwest AK, ID, OR, WA
Old 08-13-2021, 02:33 PM   #29
HSUBLU
Drives: 2017 BRZ WR Blue
Troll Miata is best Miata
You've seen mine. It's a different breed compared to Decay's.
Edit: that sounded a lot dirtier than I meant it to.
HSUBLU is offline   Reply With Quote
Old 08-13-2021, 02:59 PM   #30
Sur
Sur's Avatar
Drives: GEN-1-86-MT-FI / 2022 KTM RC 390
I get 25.4 mpg. But mostly only drive in the city. Work is about 6 minutes away. So lots of stop and go for me.
Sur is offline   Reply With Quote
Old 08-13-2021, 03:15 PM   #31
Ducati.Femme
Drives: 2017 BRZ Limited - Pearl White
Yeahhh, that'll kill the mpg's for sure. Since I work from home, the travelling I do is mostly along 26/217 and or up to Seattle. The whole 'set it and forget it' is the way of life with cruise control and myself. lol HOWEVER.. I mean one MUST merge "at least up" to freeway speeds, so on ramps are a girl's best friend. haha
Ducati.Femme is offline   Reply With Quote
The Following User Says Thank You to Ducati.Femme For This Useful Post:
Ultramaroon (08-13-2021)
Old 08-13-2021, 03:15 PM   #32
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Mine shows 23.8 but that is pretty skewed. I have barely street driven my car except to go get lunch this summer. I think I went through about 70-80 gallons of E85 the last 4 track days.
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post:
Aztec (08-26-2021), Decay107 (08-13-2021)
Old 08-13-2021, 03:23 PM   #33
Aztec
Lost in the twisties
Aztec's Avatar
Drives: 2014 BRZ Dark Gray Metallic
I really wish this wasn't on Aug 28th. Got a family reunion to go to.
I would like to show off my new toy! Sold my FRS two weeks ago and I have a Edelbrock SC BRZ right now, putting 4.875 FD gears in it next week
I'm down to do another meet up sometime, i'll keep an eye on the forums
NEW CAR!🚨🏎️⛽
2014 BRZ: Edelbrock SC, CSG ZachTune, Jackson Radiator/Oil cooler, lightweight flywheel, CNT UEL, Berk OP/FP, Ark Grip Catback, Carbon fiber Driveshaft
Aztec's Build Thread
Aztec is offline   Reply With Quote
The Following 2 Users Say Thank You to Aztec For This Useful Post:
NoHaveMSG (08-13-2021), Ultramaroon (08-13-2021)
Old 08-13-2021, 03:40 PM   #34
Decay107
Turning is for Nerds
Decay107's Avatar
Drives: 35 characters is not enough
Yeah, I was getting high single digit MPG on track
Decay107 is offline   Reply With Quote
Old 08-13-2021, 03:52 PM   #35
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Geezus that is a low FD.
I think I was getting around 8-9mpg on pump gas and around 5mpg on E85 I couldn't imagine being FI and running E85 on track.
Aztec (08-26-2021)
Old 08-13-2021, 03:57 PM   #36
Originally Posted by HSUBLU View Post
You've seen mine.
♫♫ brownChickenBrownCow ♫♫
Old 08-13-2021, 04:43 PM   #37
Aztec
Aztec's Avatar
I'm putting the 4.875 gears in a separate diff and will keep the 4.1 FD diff for longer/faster tracks like PIR.
Daily driving shorter gears is a blast, I had 4.56 in my FRS and it completely changed the character of the car for the better. It did leave me between gears sometimes that's why i'm going even shorter for maximum tom foolery. 4.875 is around 20% higher torque to the wheels & RPMs. Top of 5th is still around 110mph which is generally plenty for most tracks.
Gas mileage with the SC is DEFINITELY worse lol. I'm averaging 15mpg but that's mostly due to datalogging for Zach and him needing a heavy foot to properly diagnose fuel trims & ratios. It pulls all the way to redline
On a side-note, I am signed up for ORP Sept 20th
And then going to The Ridge up in Shelton on Oct 2nd
I'm also running 265/35/18 tires square :O
NEW CAR!🚨🏎️⛽
The Following User Says Thank You to Aztec For This Useful Post:
Old 08-13-2021, 04:45 PM   #38
Sur
Sur's Avatar
I don’t really look at the mpg much. Honestly, the car is fun to drive and that’s all that matters to me. When I lived in Hawaii, I had a 83 k20 with a 383, 8 inch lift and 33 inch grabbers. Needless to say, I got single digit mpg. And in Hawaii, your either going uphill or downhill, no a lot of straights. Loved to drive it, but it sure was a wallet smasher.
The Following User Says Thank You to Sur For This Useful Post:
Aztec (08-13-2021)
Old 08-13-2021, 04:45 PM   #39
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I have a TT at PIR the 20th and then will be doing the Ridge on Sept 4th. They are trying to get me out on Oct 2nd but I will probably put the car away for the year by then.
I am probably going 4.44 and just going to up the rev limit to 8k with some stiffer valve springs and the rocker retention kit.
Old 08-13-2021, 04:47 PM   #40
Aztec
Aztec's Avatar
Honestly 4.44 isn't that much higher RPMs, I highly recommend doing shorter gears from OEM. They even started giving 2017+ years a OEM 4.3 FD ratio I believe
NEW CAR!🚨🏎️⛽
Old 08-13-2021, 05:02 PM   #41
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Based on my driving data it will be the best compromise for myself. I only need to shift things about 400rpm to be happy and it will save me a few shifts per lap on most laps. I went from a 4.1 to a 4.3, and now back to a 4.1.
Old 08-14-2021, 06:46 PM   #42
AnotherDude000
Drives: 2022 GR86 Neptune Blue!
Confirmed. I will be there! Excited to meet the local crew!
AnotherDude000 is offline   Reply With Quote
The Following 2 Users Say Thank You to AnotherDude000 For This Useful Post:
NoHaveMSG (08-14-2021), Ultramaroon (08-14-2021)
fun with ramen
Tofu deliveries in your area! Surok Member's Car Journals 60 11-18-2018 08:26 PM
MattR's Tofu Runner MattR Member's Car Journals 31 08-12-2015 03:00 PM
Ducky's Tofu car, [bubble] ducky369 Member's Car Journals 15 10-14-2014 07:33 AM
Tofu Delivery Vehicle for The 21st Century AxisPower Member's Car Journals 5 03-30-2014 09:15 PM
Tofu-ten AE86 at Toyota History Garage Axel Other Vehicles & General Automotive Discussions 2 02-03-2010 01:21 AM
