Drives: 2016 scion frs
Valve clearances on built block
Hello,
I am currently assembly an IAG stage one block with my machined heads by IAG, as well. I have the LH heads on my block, and I checked the valve clearances after i torqued down the cam caps. Intake: .08mm, .13mm, .08mm,.08mm Exhaust: all .18mm The OEM specs on the shop manual are: Intake .10mm- .15mm Exhaust .20nm-.25mm A bit confused. I know that the shims/buckets need to be change but i dont understand how the labeling for the shims are. UPDATE: okay so i have figured it out. thanks to @NoHaveMSG and @bobel. I wanted to give some updates and try to simplify to process. this isn't a guide, this is just some tips or pointers or anything that i didnt know beforehand about valve clearances for FA20s. @bobel's thread should have most of the info there. You need to change the shims to the correct value. There are numbers of the side of the shims that correspond to the thickness they are. To get your correct valve clearances, you must time the motor and crank it a few times. Reason being, if you have heads that was machined at all or the valves that were replaced, the valves won't be seated in their final position until you crank the motor a few times. I did this without the motor being timed, and the clearances changed the next day by 0.2mm+/-. After i timed the motor and cranked the engine, the clearances would stay the same. After you get your measurements and shim numbers, in the service manual, there's formulas to use to determine what shims you need based on the clearances and the numbers on the side of the shims. Intake formula A =B+(C - D) x 1.54 A - what shim # you need B - what shim # you have C - valve clearance you have D - target valve clearance Example) A=2.36 + ( 0.06 - .15) x 1.54 B - 236 shim i have , so it means 2.36mm C - .06mm of clearances on that valve D - target of .15mm clearance A= 2.36 + (-0.09) x 1.54 A= 2.36 + (-0.1386) A= 2.2214 A= 222 shim required for .15mm clearance on that valve. Exhaust formula is the same but you multiply by 1.69. Exhaust formula A= B + (C - D) x 1.69 Edit 2: i assembled everything properly up to the cams and cap caps. I didnt apply silicone to the cam caps when mocking up to check clearances. Just to be clear. Edit 3: just in case someone wanted to see what measurements and shims i got. 2nd numbers and mm are what i got after final valve checking. Lh Intake 1:236 .06mm. ——2.22 ——222 — .14mm 2:236 .05mm—— 2.206——220 —- .15mm 3: 226 .11mm—- 2.1984——219 —- .15mm 4: 23?: .02mm—- 2.0998—-209 —- .15mm Exhaust 1: 220 .18—-2.0817——208— .25mm 2:220 .18mm— 2.0817—208—-.25mm 3: 224 .16mm —2.0879–208—-.25mm 4: 224 .15mm— 2.071—207—-.25mm RH Intake 1: 231 .10mm—-2.233—223 @ .14 2: 230 .11mm—-2.2384–223 @.15 3: 234 .12mm—-2.2938–229@.15 4: 232 .11mm—- 2.2584–225 @.15 Exhaust 1: 223 .17mm—-2.0948——-209 @ .24 2: 226 .18mm—-2.1417——-214@ .24 3: 228 . 13/14mm—-2.0772-207 @ .25 4: 224 .14mm——2.0541—-204 only @ .24 Last edited by jrhudson; 08-12-2021 at 02:24 PM. |
| The Following User Says Thank You to jrhudson For This Useful Post: | NoHaveMSG (08-12-2021) |
#2 |
Drives: BLue 2013 frs
https://www.ft86club.com/forums/showthread.php?t=138753
It's hard to see, but the shims SHOULD have markings on there, just difficult to see. You need the right lighting or a good flashlight. |
| The Following User Says Thank You to fableluke For This Useful Post: | jrhudson (08-01-2021) |
#3 | |
#4 | |
Drives: Crapcan
You measure your valve clearance, then you Can measure shim thickness with calipers. Then add/subtract shim thickness to get the correct clearance. So if you want .15mm but you have a valve that measures .10mm. You measure the shim and it is 2.45mm. That means you need a 2.40mm shim. You can’t just use the shim thickness from somebody else’s build and call it good. Sent from my iPhone using Tapatalk
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | Ultramaroon (08-01-2021) |
#5 |
Thanks to @NoHaveMSG, i got to this point.
Ill time the motor tomorrow and to check what shims are needed. |
| The Following 2 Users Say Thank You to jrhudson For This Useful Post: | BrahmaBull1990 (08-12-2021), NoHaveMSG (08-06-2021) |
#6 |
Timed and everything is spinning how it should.
Checked all the clearances and they were different from the clearances checked without timing and rotating the crank a few times. I did another check today after rotating the crank another few times to check if they were similar or the same and they were. I checked the clearances when I first bolted on the block and next day after that. They were at different clearances, i did another check and they were off again. So it seems to be going the same way as the results in this thread. https://www.ft86club.com/forums/showthread.php?t=139082 Valve jobs or new valves or even machining of the heads will have the valves not seated fully yet. You need to make sure they have seated properly. The way to do that is cranking the rotating assembly. Since the clearances havent changed much or at all, it seems that the valves(hopefully) have seated and given me an accurate measurement. Now got my measurements and have ordered the shims i need. After you get your measurements and shim numbers, in the service manual theres a formula to use to get exactly what shims you need based on the clearances and the numbers on the side of the shims. Intake formula A =B+(C - D) x 1.54 A - what shim # you need B - what shim # you have C - valve clearance you have D - target valve clearance Ex) A=2.36 + ( 0.06 - .15) x 1.54 B - 236 shim i have , so it means 2.36mm C - .06mm of clearances on that valve D - target of .15mm clearance A= 2.36 + (-0.09) x 1.54 A= 2.36 + (-0.1386) A= 2.2214 A= 222 shim required for .15mm clearance on that valve. Exhaust formula is the same but you multiply by 1.69. Exhaust formula A= B + (C - D) x 1.69 Last edited by jrhudson; 08-07-2021 at 10:17 PM. |
| The Following User Says Thank You to jrhudson For This Useful Post: | NoHaveMSG (08-07-2021) |
#7 |
Here is the tiny numbers on the side of the shims. They are extremely hard to see and i walked around the garage/outside til i got a good shot of those numbers.
![]() It says 224 btw meaning 2.24mm It is possible for the numbers to be worn off because i have on that says 23. Theres no shim thats just 2 digits. The numbers are barely visible and theres so sign of the 3rd digit so im guessing. |
#8 |
today I've gotten the shims i needed and assembled everything up to the timing. And everything holds around .15mm intake and .25 exhaust. There were a few exceptions that were .14mm and .24mm but thats still good enough.
| The Following User Says Thank You to jrhudson For This Useful Post: | NoHaveMSG (08-11-2021) |
#9 |
Subaru part numbers and what shim they are. this is not all of them, these are the ones i have found myself.
13218AK970 - 207 13218AL060 - 216 13218AL020 - 212 13218AL080 - 218 13218AK950 - 204 13218AK960 - 206 13218AK940 - 202 13218AL030 - 213 13218AK930 - 200 13218AL070 - 217 13218AL120 -222 13218AL170 - 227 13218AK990 - 209 13218AL190 - 229 13218AL040 - 214 13218AL130 - 223 13218AL150 -225 13218AL200 - 230 13218AL090 - 219 13218AK980 - 208 |
| The Following User Says Thank You to jrhudson For This Useful Post: | DarkPira7e (08-12-2021) |
#10 |
Howdy
Drives: 2020 BRZ PP
Mad respect for you gear-heads.
There's a point at 7,000 RPM... where everything fades. The machine becomes weightless. Just disappears. And all that's left is a body moving through space and time. 7,000 RPM. That's where you meet it. You feel it coming. It creeps up on you, close in your ear. Asks you a question. The only question that matters. Who are you?
| The Following User Says Thank You to BrahmaBull1990 For This Useful Post: | jrhudson (02-17-2022) |
#11 |
Rust bucket enthusiast
Just went through figuring this stuff out, was a real headache. Nice to have it documented somewhere!!!
| The Following User Says Thank You to DarkPira7e For This Useful Post: | jrhudson (02-17-2022) |
#12 |
This is why i updated the thread with any useful info in the simplest terms. It does show this stuff in the service manual but those sometimes make no sense or maybe im too dumb to understand.
| Turbo Built FA20 Clearances | elitegunslinger | Engine, Exhaust, Transmission | 3 | 06-23-2024 08:44 AM |
| built block options | Breadman | Engine, Exhaust, Transmission | 15 | 03-29-2021 12:57 PM |
| Crawford Built Short Block | texasbound972 | Engine, Exhaust, Transmission | 26 | 05-15-2015 03:39 PM |
| Built B18B Short Block | C130NAV | Miscellaneous | 0 | 01-04-2014 12:15 PM |
