Old 08-10-2021, 04:21 PM   #1
lazerking117
lazerking117's Avatar
Drives: Black 2013 Subaru BRZ Limited
b1900 SRS airbag code, Need help
As the title states. I have an SRS airbag code on my 2013 Subaru BRZ. The code is B1900, and I have tried resetting it but it comes back on when the car is shut off and turned back on again. Either there is a problem still or maybe it is handwritten in the SRS module. I am not sure.
Additionally, if anyone could help me figure out this B1900 code that would be really helpful as I am unsure what I can do to fix it. I have already tried unplugging and re-plugging the cable.
I bought my 2013 Subaru BRZ used and the last owner had a harness bar installed. The original front left hand and right hand seat belts were not removed, but the top bolts were undone and the seatbelt was wound up and tucked behind the b pillar. The guy said that it turned on once he installed the harness bar. I removed it and rebolted the seat belts. So there is no longer a harness bar and the seat belts/ seats are stock.
The B1900 code states:
Faulty Front Seat Outer Belt Left (LH) (Front Driver Side Pretensioner Squib) Front Seat Outer Belt Left (LH) harness is open or shorted Front Seat Outer Belt Left (LH) circuit poor electrical connection Faulty Center Airbag Sensor Assembly
Read more: https://www.autocodes.com/b1900_toyota.html
There seems to be nothing wrong with the seatbelt.
lazerking117 is offline   Reply With Quote
Airbag light from removing Airbag controller - any effect on performance? Joesurf79 Tracking / Autocross / HPDE / Drifting 9 03-26-2019 07:06 AM
DIY - Color Code of ID plate and code of part (SUBARU) - SB18-091 Trap63 DIY (Do-It-Yourself) Guides 0 06-14-2018 05:52 AM
SRS airbag code help wrxdrifter Electronics | Audio | NAV | Infotainment 24 10-27-2017 09:13 PM
B1821 code - Drivers Side Airbag Anal0g Electronics | Audio | NAV | Infotainment 0 09-04-2017 08:12 PM
WTB: FRS oem driver airbag, clock spring, both front seat belts, airbag module 14_GT86 Want-To-Buy Requests 3 04-01-2015 01:26 AM
