Drives: 2016 White Pearl BRZ Premium
Airbag light from removing Airbag controller - any effect on performance?
Hello fellow track rats!
In the process of stripping out the BRZ track car, I came to the airbag controller that lives in front of the shifter, with the yellow connectors. Looks like there are looms running to each seat belt sensors, etc. Unplugging the airbag box obviously results in an airbag light - which is a surprise, as I've had an 86Nanny in the car programmed to defeat it for a while. So without the airbag controller plugged in, even what the 86nanny is doing doesn't defeat it - which is fine by me, as it no longer sees the street. BUT - is there any effect to the car's performance with an airbag light on? Engine output, ABS, anything? I searched but mostly found "use electrical tape to cover the abs light" responses Thanks, Joe V |
Drives: Subaru BRZ
Should not affect anything performance related.
| The Following 2 Users Say Thank You to Code Monkey For This Useful Post: | Joesurf79 (05-01-2018), strat61caster (03-18-2019) |
I hope that's the case, the car is on jack stands and I haven't driven it yet without it. Some dash lights (abs / traction control warning) popped up after the car got down the street a bit when I put the steering column back together one spline off. Wasn't sure if the dash Christmas Tree would illuminate a block from the garage without the airbag module. Didn't want to get caught in limp mode and have to splice things back into the harness haha!
Drives: 2014 Silver BRZ Track Car
To your question, the airbag will not affect performance.
I removed all my airbags and the module itself because my BRZ is caged. You say that you have abs/traction control warning on because you were one tooth off in the steering. Did you fix it? Are you sure your clock spring did not come off? If the clock spring came off you will need a new one and then have the dealer clear the codes. |
#5 | |
![]() I have a rollbar, race buckets, 6 pts etc in the car. It's track only from here on out
#6 | |
Drives: 2022 LR Defender, 2015 FRS_ST5/TT5
Dealer called they are unable to communicate with the car since it has the Airbag Module removed. This is how it communicates with the ABS etc. Reading this it appears there is no correlation? First event this weekend ![]() PS: Airbag out, stripped and caged the car. Accidently removed clockspring and this is where we are at. TIA Lutfy @Joesurf79 @Code Monkey @AndyBRZ TIA
2015 FRS NASA ST/TT5
2022 LR Defender 2023 BMW M2 |
Drives: Subaru BRZ
Not an expert on it and I keep my interior stock-ish but there should be no effect on car performance.
#8 | |
Drives: Track preped NA FRS
Drives: Fr-s
There is a chance that the car needs to be re-zeroed(whatever Toyota calls it) with Techstream(try searching, the download is available). I had to do this with my car when I replaced the clockspring/angle sensor. I’d be surprised if Toyota can’t communicate with the car due to the airbag module but I guess it isn’t out of the realm of possibility.
#10 | |
Litfy
| AC climate control panel | Joesurf79 | Interior Parts (Incl. Lighting) | 12 | 06-01-2018 11:51 PM |
| WTB: FRS oem driver airbag, clock spring, both front seat belts, airbag module | 14_GT86 | Want-To-Buy Requests | 3 | 04-01-2015 12:26 AM |
| WTB Passenger Curtain Airbag + Wheel Airbag | markkisl | Want-To-Buy Requests | 4 | 08-26-2014 01:16 AM |
| HELP!! Car won't start after removing airbag XD | 6spd | Engine, Exhaust, Transmission | 10 | 04-14-2014 09:20 PM |
| Removing Airbag Warning Stickers | Jimp | Scion FR-S / Toyota 86 GT86 General Forum | 30 | 08-17-2013 11:01 PM |
