Old 07-04-2016, 05:26 PM   #1
wrxdrifter
Drives: .
SRS airbag code help
Hey guys so I'm trying to repair my cars SRS system.
The back story
The passenger side roof airbag and the passenger side seat air bag deployed, also the passenger side seat belt locked up after an accident.
What I've done so far
I have replaced the passenger seat, passenger roof airbag, and have gotten the seat belt repaired by a seat belt repair shop. But now when I scan for the SRS codes via Autolink L619 SRS scan tool I'm getting 8 current codes, these codes are as follows.
-B16f1
-B11f6
-B1901
-B1821
-B1831
-B1693
-B1650
-B1655
Some of these codes are driver side errors even though the driver side was untouched and no airbags deployed on the driver side.
Does anyone have any ideas what I should be replacing?
wrxdrifter is offline   Reply With Quote
Old 07-04-2016, 05:51 PM   #2
redlined600
redlined600's Avatar
Drives: Fr-s
Have you tried clearing them to see if the same codes re appear?
Old 07-04-2016, 05:53 PM   #3
wrxdrifter
Drives: .
Yes I did, unfortunately they all still appear.
Old 07-04-2016, 06:14 PM   #4
P3tras
Drives: Subaru BRZ '13 WRB
After accident error codes are "hard-coded" into airbag computer (it's behind HVAC controls) and cannot be removed via OBD. Officially SRS computer needs to be replaced by a new one (or one that was not involved in an accident). It is possible to reflash it, but it needs to be removed and brought to airbag shop that has tools to reflash firmware in it.
P3tras is offline   Reply With Quote
The Following User Says Thank You to P3tras For This Useful Post:
wrxdrifter (07-05-2016)
Old 07-04-2016, 06:43 PM   #5
wrxdrifter
Drives: .
That's great info! Thank you. Now you wouldn't happen to know where that control module is located on the Frs would you?
Old 07-04-2016, 06:57 PM   #6
P3tras
Same as in BRZ, behind air conditioning control panel. To remove it you need to remove central console, all plastic parts around air conditioning controls and then control panel itself. Behind it you will see SRS control module with big yellow connector (it is held with few nuts).
Old 07-05-2016, 09:39 AM   #7
Ashikabi
Ashikabi's Avatar
Just send it in to get reflashed. Cost me $50 from srsmodule.com(pretty sure)
The Following User Says Thank You to Ashikabi For This Useful Post:
Old 07-05-2016, 04:15 PM   #8
wrxdrifter
Drives: .
Is this the module?
frs(1) by steven papania, on Flickr
Old 07-05-2016, 04:18 PM   #9
Ashikabi
Ashikabi's Avatar
Originally Posted by wrxdrifter View Post
Is this the module?
Sure is
Old 07-16-2016, 03:22 PM   #10
wrxdrifter
Drives: .
Okay just re-installed the module after getting it reset and the result is no SRS light! Thanks for the info guys!
Old 07-16-2016, 04:37 PM   #11
Ashikabi
Ashikabi's Avatar
Np
Old 10-27-2017, 01:49 PM   #12
B-R-Z
I love peanut butter
B-R-Z's Avatar
Drives: 2013 SWP BRZ Limited
Did you send it to srsmodule.com? How long was the turn-around? Is it drivable without the module (obviously airbags will not work).
Old 10-27-2017, 02:07 PM   #13
Ashikabi
Ashikabi's Avatar
I used srsmodule.com, turn around was a couple weeks I think. Car" should" run without it but IMO, you're playing with fire. I guess racecars pull it out though
Old 10-27-2017, 02:30 PM   #14
B-R-Z
B-R-Z's Avatar
I wonder if the dealership could do it for me if I took it out and brought it in. Insurance is paying for it so I don't care what it costs. Did you try a dealership before deciding on srsmodule?
Lean Code and 02 Code diagnostics. Kiske Engine, Exhaust, Transmission 12 04-28-2016 11:19 PM
WTB: 86 Airbag cover, no airbag needed stevesnj Australia Classifieds 0 02-18-2016 10:17 PM
WTB: FRS oem driver airbag, clock spring, both front seat belts, airbag module 14_GT86 Want-To-Buy Requests 3 04-01-2015 01:26 AM
WTB Passenger Curtain Airbag + Wheel Airbag markkisl Want-To-Buy Requests 4 08-26-2014 02:16 AM
FS: JDM 86 Airbag horn cover with airbag turbos86 Interior Parts (Incl. Lighting) 5 11-20-2013 02:17 AM
