Old 08-02-2021, 02:01 PM   #1
Krazyyykevin
Krazyyykevin's Avatar
Drives: 2020 BRZ
JDL Turbo Issue
I Know its not JDL's Fault i just figured it would help if i put the kit name in the title
Hey guys i have my turbo installed and im currently tuning it through zach, but i have this issue and was wondering if anyone knows what it is, the car basically lugs at 5k rpm and does not want to go any higher even though i was told to take it up to 6800 rpm in a pull, this happens at WOT at about 5k RPM
JDL Turbo kit with gtx2860r
Krazyyykevin is offline   Reply With Quote
Old 08-02-2021, 02:56 PM   #2
BrahmaBull1990
Howdy
BrahmaBull1990's Avatar
Drives: 2020 BRZ PP
Contact Zach...
There's a point at 7,000 RPM... where everything fades. The machine becomes weightless. Just disappears. And all that's left is a body moving through space and time. 7,000 RPM. That's where you meet it. You feel it coming. It creeps up on you, close in your ear. Asks you a question. The only question that matters. Who are you?
BrahmaBull1990 is offline   Reply With Quote
The Following User Says Thank You to BrahmaBull1990 For This Useful Post:
Krazyyykevin (08-02-2021)
Old 08-02-2021, 03:01 PM   #3
Krazyyykevin
Drives: 2020 BRZ
Originally Posted by BrahmaBull1990 View Post
Contact Zach...
i did, just figured id ask if anyone knows because hes off on weekends
The Following User Says Thank You to Krazyyykevin For This Useful Post:
BrahmaBull1990 (08-02-2021)
Old 08-02-2021, 03:22 PM   #4
alphasaur
friendly
Drives: 17' 86
your tuner will be able to help, but looks like fuel cut maybe
Seek comfort in discomfort.
alphasaur is offline   Reply With Quote
The Following User Says Thank You to alphasaur For This Useful Post:
Old 08-02-2021, 08:07 PM   #5
Krazyyykevin
Drives: 2020 BRZ
tuner got back to me and, it is overboost protection lol, ig my waste gate is messing up
Old 08-02-2021, 09:46 PM   #6
jrhudson
Drives: 2016 scion frs
just cause im curious what was the boost cut?
jrhudson is offline   Reply With Quote
Old 08-02-2021, 09:46 PM   #7
Krazyyykevin
Drives: 2020 BRZ
I’m suppose to be pushing 7 psi and I was hitting 14.5
Old 08-02-2021, 10:06 PM   #8
BrahmaBull1990
Howdy
Drives: 2020 BRZ PP
In all seriousness, God bless properly working wastegates.
The Following 2 Users Say Thank You to BrahmaBull1990 For This Useful Post:
Decep (08-04-2021), Krazyyykevin (08-11-2021)
Old 08-02-2021, 10:07 PM   #9
Krazyyykevin
Drives: 2020 BRZ
I need to figure out what’s going on with mine because it’s not dumping, I saw on the box it said 7lbs on it but I feel like it might have been wrong
Old 08-02-2021, 10:13 PM   #10
BrahmaBull1990
Howdy
Drives: 2020 BRZ PP
I’m not too useful with wastegates because I have a SC, but isn’t there an adjustment spring?
Old 08-03-2021, 12:11 AM   #11
Krazyyykevin
Drives: 2020 BRZ
you open it up and change the spring inside with a stiffer / weaker one but i thought it had a 7lb one inside but the box may have been wrong, so i have to take it off and find out whats going on
Old 08-11-2021, 03:33 PM   #12
Krazyyykevin
Drives: 2020 BRZ
forgot to update this, opened up the waste gate and the diaphragm was sticking slightly and changed the spring to 5lb spring and im using an ebcs now and im hitting 7psi on the dot and its dumping correctly now
The Following 5 Users Say Thank You to Krazyyykevin For This Useful Post:
alphasaur (08-11-2021), BrahmaBull1990 (08-11-2021), Calum (08-11-2021), CSG Mike (08-12-2021), DarkPira7e (08-12-2021)
Old 08-12-2021, 06:35 PM   #13
CSG Mike
CSG Mike's Avatar
That's why overboost protection is there!
Krazyyykevin (08-12-2021)
Old 08-12-2021, 06:35 PM   #14
Krazyyykevin
Drives: 2020 BRZ
It saved my motor and I appreciate Zach for doing it
BrahmaBull1990 (08-21-2021)
Issue with pump gas on turbo setup MotoX16 Software Tuning 7 01-10-2020 08:48 PM
Turbo Issue? Strife26 Forced Induction 14 08-08-2018 07:32 PM
Brz turbo idle issue Aalyluvsjdm Forced Induction 16 07-14-2017 05:38 PM
Turbo kit mapping issue Edsc Forced Induction 2 06-28-2017 11:50 AM
Full blown turbo kit, boosted issue. Help please Xxdragn89xX Forced Induction 7 09-10-2015 09:37 AM
