Old 09-09-2015, 08:11 PM   #1
Xxdragn89xX
Drives: 2015 Subaru BRZ
Full blown turbo kit, boosted issue. Help please
Alrighty so apparently my map sensor is having issues with the new kit. Map, it's reading that the barometric pressure is too high. And at about 5k it basically shuts down. So I can't play with it.
Xxdragn89xX is offline   Reply With Quote
Old 09-09-2015, 08:17 PM   #2
May have better luck asking that here:
http://www.ft86club.com/forums/forumdisplay.php?f=78
Old 09-10-2015, 12:05 AM   #3
BRZtoni
Turbo E85
BRZtoni's Avatar
Drives: 13 wrb brz
what tune are you running?
Flex Fuel Turbo BRZ
BRZtoni is offline   Reply With Quote
Old 09-10-2015, 12:08 AM   #4
Xxdragn89xX
The full blown base map.
Old 09-10-2015, 12:59 AM   #5
The Slow One
Track Junkie
Drives: Argento Scion FR-S
you might want to consider getting a custom tune. the base map literally is only used to get you to a tuner.
The Slow One is offline   Reply With Quote
Old 09-10-2015, 03:24 AM   #6
Stock MAP on a Speed Density tune? Sounds like a base map for you to get an actual tune.
You'll need a different MAP as well. Consult with FB or your local tuner for recommendations.
Old 09-10-2015, 08:11 AM   #7
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
Or... get the 4bar map sensor from FBM. The stock map sensor isn't going to do you justice. I'm running the base map with their 4bar and it runs like a champ. A/r is on key.
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
Old 09-10-2015, 09:37 AM   #8
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
As I mentioned on Facebook my guess is that you have a tune for an aftermarket MAP sensor instead of the OEM MAP sensor. The car should run just fine on a Full Blown MAP sensor and OEM MAP sensor if you have the right tune. It has been over 2 years since I ran the Full Blown basemap, but it wasn't speed density at the time.
I need help with Full Blown Turbo Kit Mikeez Forced Induction 71 11-10-2014 07:40 PM
Any body have a p&l turbo kit for sale or full blown turbo Anthony7515 Want-To-Buy Requests 2 06-06-2014 05:43 PM
fs feeler full blown turbo kit minus turbo kingkai23 Engine, Exhaust, Bolt-Ons 10 03-11-2014 02:59 PM
Full Blown Turbo Kit! Unleashed Engine, Exhaust, Bolt-Ons 70 10-09-2013 09:46 AM
WTB: Full Blown turbo kit (used) whitefrs Engine, Exhaust, Bolt-Ons 12 03-29-2013 09:15 PM
