Old 08-01-2021, 12:58 PM   #1
AEBRacing
AEBRacing's Avatar
Drives: Toyota FT86
P2M_Phase 2 Motortrend_End Link Sway Bar
Hi guys!!! anyone know the brand PHASE 2 MOTORTREND?
I am interested to buy an end link kit for front/rear sway bars, they have good prices compare with others recongnized brand.
I know they are in california, but I donīt find a lot of comments asociate with this brand
https://www.phase2motortrend.com/default.asp
AEBRacing is offline   Reply With Quote
Old 08-01-2021, 01:02 PM   #2
Calum
That Guy
Drives: 2013 asphalt FRS MT
The rip off of Motor Trend's name alone has me wondering about their validity.
Old 08-01-2021, 01:12 PM   #3
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Ebay trash by the look of it.
Old 08-01-2021, 02:01 PM   #4
AEBRacing
AEBRacing's Avatar
Drives: Toyota FT86
Ok, clearly is cheap, but I dont believe if it is enough to qualify as trash or bad quality.
If you compare with a PERRIN rear end link the cost differencis is around usd 100 (usd 85 vs 185), in my case I need to add customs tax, shipping cost to Argentina, etc etc....in case of Perrin end link the total cost is aprox usd 300 , for a pair of rear end link....for that reason I am evaluating others alterntives
I just bought PERRIN adjustble rear and front sway bars (22mm / 19mm), in order to close this mod I am looking for a kit of rear end link and not spend much money for this, but this not mean to buy a trash
Old 08-01-2021, 02:06 PM   #5
x808drifter
LMGTFY
Ok, clearly is cheap, but I dont know if it is enough to qualify as bad quality.
I just bought PERRIN adjustble rear and front sway bars (22mm / 19mm), in order to close this mod I am looking for a kit of rear end link and not spend much money for this, but it not mean to buy a trash
Let me tell you a story about how my friend nearly died because his Riceland (Raceland) coilovers failed on the freeway.
Buy once, cry once.
Old 08-01-2021, 03:16 PM   #6
fminicooper
Drives: FRS Hot Lava
Is your car lowered?
Some folks change sway bar using OEM links, all depending on hight ride.
fminicooper is offline   Reply With Quote
Old 08-01-2021, 03:26 PM   #7
AEBRacing
AEBRacing's Avatar
Drives: Toyota FT86
yes, slightly lower than OEM. I have Eibach pro kit springs, approx 1" lower than OEM
Old 08-01-2021, 04:19 PM   #8
AEBRacing
AEBRacing's Avatar
Drives: Toyota FT86
I find the following adjustable rear end link alternatives, any help or experience that you can share with me will be helpful
https://www.phase2motortrend.com/pro...sbl2086-hc.htm
https://www.perrin.com/shop/suspensi...-rear-endlinks
https://godspeedproject.com/suspensi...end-links.html
https://whitelineperformance.com/pro...lc182-link-kit
Correct sway bar position/end link length? Plumbus Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 01-11-2021 10:14 PM
aftermarket rear lca with oem sway bar link? B.RUDY.Z Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 09-27-2019 03:33 AM
Front sway bar end link installation? Bach415 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 08-26-2018 11:56 PM
Help, installed Swifts, damaged F Sway Bar Link F1fletch DIY (Do-It-Yourself) Guides 0 02-09-2014 12:49 PM
Ajdustable front sway bar link on a coilover questions Vten Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 05-06-2013 10:39 PM
