Old 01-11-2021, 09:14 PM   #1
Plumbus
Señor Member
Plumbus's Avatar
Drives: '17 BRZ PP
Correct sway bar position/end link length?
I recently installed HKS max iv SP coilovers and am about to lower the car from .7" out-of-box drop to 1" drop, maybe 1.3" tops. Coils came with a pair of solid front shorter end links, and no rear end links. The rear sway bar points to the sky which I assume is not ideal, while the fronts look ok, but will be quite close to the front LCA once I lower (I think).
I purchased a set of front and rear RacerX end links, but I forgot to take a pic of the stock positions. The service manual doesn't mention anything as the stock setup has no adjustability, does anyone know the correct position or end link lengths for a dropped car?
This is how they look now, car is on the ground.
Plumbus is offline   Reply With Quote
end link, height, length, position, swaybar
aftermarket rear lca with oem sway bar link? B.RUDY.Z Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 09-27-2019 02:33 AM
Front -3.5 camber needs plates and bolts to avoid End Link rub, correct? BrunoS72 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 18 09-05-2018 01:35 AM
Front sway bar end link installation? Bach415 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 08-26-2018 10:56 PM
Help, installed Swifts, damaged F Sway Bar Link F1fletch DIY (Do-It-Yourself) Guides 0 02-09-2014 11:49 AM
Ajdustable front sway bar link on a coilover questions Vten Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 05-06-2013 09:39 PM
