Old 07-25-2021, 05:27 PM   #15
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
Originally Posted by Lantanafrs2 View Post
6th gear at 1500rpm? I don't think I've ever tried that. I don't think I ever will try it either.
If you turn the gear indicator on and obey the shift indicator, you'll be surprised at just how low it wants to go, and once you're there, how much you don't actually need to shift, give just the slightest bit of throttle above steady state and it'll just carry on up a 10% grade like it's nothing.
Old 07-25-2021, 05:42 PM   #16
PulsarBeeerz
Drives: JRSC BRZ SOLD
That IAM must be holding at a steady 0.82.
PulsarBeeerz is offline   Reply With Quote
The Following 2 Users Say Thank You to PulsarBeeerz For This Useful Post:
Dzmitry (07-29-2021), soundman98 (07-25-2021)
Old 07-25-2021, 06:17 PM   #17
soundman98
ProCrastinationConsultant
soundman98's Avatar
i have. end up in 6th at like 30mph. people complain this motor sounds like a tractor, at that rpm, it sounds like a diesel!
i paid for a 7600 rpm redline, i'm gonna use the whole gauge!
Old 07-25-2021, 07:35 PM   #18
LimitedSlip
Senior Citizen Member
LimitedSlip's Avatar
Drives: Then-1977 Celica GT Now-2017 860SE
Originally Posted by RZNT4R View Post
It's fine under 2k, plenty tractable, it'll climb big hills in 6th at 1500 just fine.
I think I remember hearing something similar but it might have been on a Kenworth forum.
LimitedSlip is offline   Reply With Quote
The Following 3 Users Say Thank You to LimitedSlip For This Useful Post:
racingfool (07-26-2021), soundman98 (07-26-2021), Wally86 (07-27-2021)
Old 07-25-2021, 09:16 PM   #19
I bet it serves the same function as the max-efficiency upshift arrow. It actually works nicely. Boring, but efficient.
Old 07-26-2021, 12:35 AM   #20
Sasquachulator
Pavement Grey
Yeah everyone loves the feeling of perpetual torque dip with no end in sight......
Old 07-26-2021, 12:47 AM   #21
soundman98
soundman98's Avatar
and then the term 'floating heads' comes into play from all the extra forces of lugging the motor...
i wonder where all the coolant went!
Old 07-26-2021, 06:42 AM   #22
RZNT4R
If you're just driving along with traffic on 50km/h streets like what 100% of my work commute is, the torque bump below the torque dip works just as well as the torque bump above the torque dip.
The Following 2 Users Say Thank You to RZNT4R For This Useful Post:
timurrrr (07-26-2021), Ultramaroon (07-26-2021)
Old 07-26-2021, 10:52 AM   #23
racingfool
racingfool's Avatar
Drives: Miata
Originally Posted by ayau View Post
a custom iag motor isnt the same as a motor built from the factory. can't compare the break-in cycles between the two.
Please educate me on the different break-in procedures between the two.
racingfool is offline   Reply With Quote
Old 07-26-2021, 11:09 AM   #24
ayau
Drives: Some rust bucket
two completely separate manufacturers that have their own proprietary testing/building procedures.
if IAG says you need to do xyz break-in, then that only applies to their engines. applying the same break-in procedures to engines built by subaru simply because they're the "same engine" is just an over-simplified way to approach this.
if subaru doesn't specificy engine break in procedures in their manual, then don't worry about it.
The Following User Says Thank You to ayau For This Useful Post:
Old 07-26-2021, 09:40 PM   #25
Decep
Drives: 2013 FR-S Series 10
Ah shit, here we go again. Low oil pressure light
2013 FR-S 10 Series ~75k (SOLD)
RCE SS-1 Coilovers
Corsa Catback
Edelbrock Supercharger installed @ 50k
Old 07-27-2021, 12:13 AM   #26
You were hoping for a useful feature? I'm sorry. That's not how modern regular cars are made. They figured out that most people don't know what to do with useful features so they make butt warmers and touch screens instead.
soundman98 (07-27-2021), timurrrr (07-27-2021)
Old 07-27-2021, 06:48 AM   #27
RZNT4R
My favorite is Ford's oil pressure gauges where the needle only actually has two positions: low and middle.
soundman98 (07-27-2021), Ultramaroon (07-27-2021)
Old 07-27-2021, 07:50 AM   #28
Boccaccio
CAD monkey
Boccaccio's Avatar
Drives: '15 GT86 Giallo - Supercharged
Food for thought:
https://auto.jepistons.com/blog/how-...k-in-an-engine
"In WOT dyno testing, likely the rings are seated by the end of the first few runs"
And a screenshot I made from a European car community:
https://i.imgur.com/evhQVC6.png
I tend to agree, there's a limited time frame to correctly seat the piston rings against freshly honed cylinder walls. There are too many variables if the customer would be in charge of "mating the rings against the cylinder wall".
Boccaccio is offline   Reply With Quote
The Following User Says Thank You to Boccaccio For This Useful Post:
"Unable to read program. Please check SD card or the program" coconutboy Electronics | Audio | NAV | Infotainment 1 08-13-2019 06:23 PM
2013 production date cars more "reliable?" jacobzking Issues | Warranty | Recalls / TSB 64 09-30-2013 10:17 AM
What Subaru of America says about the "break-in period"... mav1178 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 21 08-07-2013 10:17 PM
The "First 86 Program" Should be revised!!! Jay Grey Scion FR-S / Toyota 86 GT86 General Forum 36 05-16-2012 11:22 AM
May 2010 Car&Driver issue FT-86 article - "25 Cars Worth Waiting For" JDMinc Scion FR-S / Toyota 86 GT86 General Forum 76 04-17-2010 03:58 AM
