Old 07-19-2021, 10:29 PM   #1
kev0
Drives: '14
Switched out window regulator. Now my window decided that this will be its max height
https://streamable.com/gwl4eu
So what I thought would be a 2 hour project turned into a 3 day nightmare. Tomorrow will be my 4th day dealing with this crap.
Anyone know why my window thinks that is the max height? It behaves like a normal window for the passenger side; the window will go down a bit when you open it, and slide back up when you close it. How it should be. My problem is that I cannot get the window to go any higher then what the video shows. There are no physical blockages causing the window to stop there. I've loosened and played around with all the nuts.
I'm losing my mind here. I'm afraid that not even an auto glass store will know how to fix it. Anyone help would be appreciated. Thanks
kev0 is offline   Reply With Quote
The Following User Says Thank You to kev0 For This Useful Post:
humfrz (07-20-2021)
Old 07-19-2021, 10:59 PM   #2
soundman98
ProCrastinationConsultant
soundman98's Avatar
there's a re-learn proceedure that you have to go through
humfrz (07-20-2021)
Old 07-19-2021, 11:44 PM   #3
kev0
Drives: '14
Tried that already. Multiple times in every way possible. I was certain that would have fixed it too..unfortunately it didn't.
Old 07-20-2021, 02:14 AM   #4
I'll ring up my good buddy down in Vantucky for you.
@Ultramaroon is our resident window expert. Since his window problem was a while back, it will fit into his long term memory span and he will most likely be able to remember and help you out.
I hope you get it figured out.
You might try unplugging your car, drain it, then plug it back in to re-set the BCU (that was Bubba's suggestion).
(what the hell was wrong with these anyway - )
kev0 (07-20-2021), soundman98 (07-20-2021)
Old 07-20-2021, 03:18 AM   #5
New to me. Hopefully others have seen and solved it. Here's some stuff I've been reading. The initialization looks touchy. Needs to be repeated a few times exactly according to procedure. There are some DT codes that need to be cleared but they don't interfere with initialization.
WINDOW / GLASS: POWER WINDOW CONTROL SYSTEM: Auto Up Operation does not Fully Close Power Window (Jam Protection Function is Activated); 2013 MY FR-S [03/2012 - ]
WINDOW / GLASS: POWER WINDOW CONTROL SYSTEM: INITIALIZATION; 2013 MY FR-S [03/2012 - ]
humfrz (07-20-2021), kev0 (07-20-2021), soundman98 (07-20-2021)
Old 07-20-2021, 05:14 PM   #6
kev0
Drives: '14
Thanks yall... just fixed it. Just had to finesse the regulator around.. It's a pretty simple process. not sure why this job took me 4 days.
The Following 3 Users Say Thank You to kev0 For This Useful Post:
bcj (07-20-2021), humfrz (07-21-2021), soundman98 (07-20-2021)
Old 07-20-2021, 07:43 PM   #7
soundman98
soundman98's Avatar
for me, that'd be because i expected it to only take 2 hours!
my trucks dome light project, that should've been a 1 day deal has turned into nearly 3 months...
The Following 3 Users Say Thank You to soundman98 For This Useful Post:
humfrz (07-21-2021), norcalpb (07-20-2021), Ultramaroon (07-20-2021)
Old 07-20-2021, 08:15 PM   #8
Whenever I start a unique task, I make a point of not estimating a time to completion. That way I can allow myself to break down the project and focus entirely on the task at hand. I expect to take a week to change a regulator because I've already done most of the sub-steps so I know how long they can take.
Old 07-21-2021, 12:58 AM   #9
When you get older, plan on it taking even longer -
Dzmitry (07-21-2021), soundman98 (07-21-2021)
Old 07-21-2021, 01:00 AM   #10
Just take the bulb out ..... and put a small flashlight in the glovebox -
Ultramaroon (07-21-2021)
Old 07-21-2021, 01:39 AM   #11
soundman98
soundman98's Avatar
Done and done. It all started with pulling the bulbs for power consumption measurements a while ago..
The Following 2 Users Say Thank You to soundman98 For This Useful Post:
humfrz (07-21-2021), Ultramaroon (07-21-2021)
Old 07-21-2021, 01:59 AM   #12
Along the journey it's good to stop and smell the burned insulation.
bcj (07-21-2021), soundman98 (07-21-2021)
Old 07-21-2021, 02:29 AM   #13
Good point. I didn't realize that his truck was British made -
bcj (07-21-2021), Ultramaroon (07-21-2021)
Old 07-21-2021, 10:10 PM   #14
soundman98
soundman98's Avatar
that's New Old Stock, back when you could still replace the smoke. now the smoke is made of unicorn tears, and cost too much to replace. cheaper to replace the wires for the end user.
humfrz (07-22-2021), Ultramaroon (07-21-2021)
DIY: Window Motor & Regulator Replacement thekevinvo DIY (Do-It-Yourself) Guides 0 09-03-2020 03:46 PM
Window height at both switch positions B-R-Z BRZ First-Gen (2012+) — General Topics 18 11-26-2017 04:22 PM
Fuel Regulator tofurun Forced Induction 9 01-09-2017 10:11 PM
Window Regulator Bolts/Washers - TSB and new parts? PollosHermanos Issues | Warranty | Recalls / TSB 3 03-08-2014 02:17 PM
Window Regulator Mounting Bolts - Noise Issue & Part Revision? PollosHermanos Issues | Warranty | Recalls / TSB 1 03-06-2014 11:39 AM
