-   Issues | Warranty | Recalls / TSB (https://www.ft86club.com/forums/forumdisplay.php?f=72)
-   -   Switched out window regulator. Now my window decided that this will be its max height (https://www.ft86club.com/forums/showthread.php?t=146171)
kev0 07-19-2021 09:29 PM
https://streamable.com/gwl4eu
So what I thought would be a 2 hour project turned into a 3 day nightmare. Tomorrow will be my 4th day dealing with this crap.
Anyone know why my window thinks that is the max height? It behaves like a normal window for the passenger side; the window will go down a bit when you open it, and slide back up when you close it. How it should be. My problem is that I cannot get the window to go any higher then what the video shows. There are no physical blockages causing the window to stop there. I've loosened and played around with all the nuts.
I'm losing my mind here. I'm afraid that not even an auto glass store will know how to fix it. Anyone help would be appreciated. Thanks
soundman98 07-19-2021 09:59 PM
there's a re-learn proceedure that you have to go through
https://www.youtube.com/watch?v=MRMrwnCfR0c
kev0 07-19-2021 10:44 PM
Tried that already. Multiple times in every way possible. I was certain that would have fixed it too..unfortunately it didn't.
humfrz 07-20-2021 01:14 AM
I'll ring up my good buddy down in Vantucky for you.
@Ultramaroon is our resident window expert. Since his window problem was a while back, it will fit into his long term memory span and he will most likely be able to remember and help you out.
I hope you get it figured out.
You might try unplugging your car, drain it, then plug it back in to re-set the BCU (that was Bubba's suggestion).
(what the hell was wrong with these anyway - :iono:)
Ultramaroon 07-20-2021 02:18 AM
New to me. Hopefully others have seen and solved it. Here's some stuff I've been reading. The initialization looks touchy. Needs to be repeated a few times exactly according to procedure. There are some DT codes that need to be cleared but they don't interfere with initialization.
WINDOW / GLASS: POWER WINDOW CONTROL SYSTEM: Auto Up Operation does not Fully Close Power Window (Jam Protection Function is Activated); 2013 MY FR-S [03/2012 - ]
WINDOW / GLASS: POWER WINDOW CONTROL SYSTEM: INITIALIZATION; 2013 MY FR-S [03/2012 - ]
kev0 07-20-2021 04:14 PM
Thanks yall... just fixed it. Just had to finesse the regulator around.. It's a pretty simple process. not sure why this job took me 4 days.
soundman98 07-20-2021 06:43 PM
for me, that'd be because i expected it to only take 2 hours!
my trucks dome light project, that should've been a 1 day deal has turned into nearly 3 months...
Ultramaroon 07-20-2021 07:15 PM
Whenever I start a unique task, I make a point of not estimating a time to completion. That way I can allow myself to break down the project and focus entirely on the task at hand. I expect to take a week to change a regulator because I've already done most of the sub-steps so I know how long they can take.
https://upload.wikimedia.org/wikiped...tation.svg.png
humfrz 07-20-2021 11:58 PM
When you get older, plan on it taking even longer - :sigh:
humfrz 07-21-2021 12:00 AM
Just take the bulb out ..... and put a small flashlight in the glovebox - ;)
soundman98 07-21-2021 12:39 AM
Done and done. It all started with pulling the bulbs for power consumption measurements a while ago..
Ultramaroon 07-21-2021 12:59 AM
Along the journey it's good to stop and smell the burned insulation.
humfrz 07-21-2021 01:29 AM
Good point. I didn't realize that his truck was British made - :iono:
soundman98 07-21-2021 09:10 PM
that's New Old Stock, back when you could still replace the smoke. now the smoke is made of unicorn tears, and cost too much to replace. cheaper to replace the wires for the end user.
